I recently updated my hl7802 to firmware 4.5.4.0 and things were looking fine for about two days, with multiple reboots and dev work.
Then for unknown reasons the modem stopped booting and continuously refused to do so. I first attempted to reflash 4.5.4.0 to no avail, then downgrading to 4.4.6.0 which also did not boot, then to 4.3.9.0 with which the modem appears to be running healthily.
Then after reflashing to 4.5.4.0 again the modem gets stuck again in the same situation.
I’m flashing using the sft tool for Linux.
Any ideas on what I can do to resolve this situation? Is there a way to clean up and get the modem in a more pristine state than just using the sft flash tool?
Below is the modem uart log output from the initial failure, starting from last successful boot.
Secured Boot ROM Console
Boot>
U-Boot 2012.10 (Jul 22 2020 - 23:36:29)
Board: ALT1250 Ver: 0.32-TG-D0 (PMP CPU Speed 120 MHz)
DRAM: 2.5 MiB
Now running in RAM - U-Boot at: 902a4000
Boot mode 2
Flash Manufacturer/Device ID is: 0x20bb19
Enable QUAD mode
Flash: 32 MiB
*** Warning - Merge environment, using default environment
map import OK
In: serial
Out: serial
Err: serial
Configuring Flash Write Protection (offset 0x1e00)
new_ce_val = 0x3a00f8f0
Hit '\r' or '\e' key to stop autoboot: 0
Version: 2.0
Nothing to upgrade...
image part OK
[initEcho] echo application startsinitGnssAppWithLogicalSerialPort lsid=35
eLC_app_entry
>Set Off Echo for at client 0
-debug- got ATS0
Init logs:
Jan 01 00:00:00.000 [D4] [ 0.98045]Starting SNTP client...
Starting PM
Jan 01 00:00:00.000 [D4] [ 0.98168] Starting SM
Jan 01 00:00:00.000 [D4] [ 0.98356] Normal boot from u-boot
Jan 01 00:00:00.000 [D4] [ 0.98387] Cold boot
Jan 01 00:00:00.027 [D4decode_from_string: input string empty
] [ 0.125627] MCU present: 0
Jan 01 00:00:00.031 [D4] [ 0.129371] NVBACKUP automatic mode ON
Jan 01 00:00:00.078 [D4] [ 0.176707] NVBACKUP Static check OK
Jan 01 00:00:00.078 [D4] [ 0.176840] NVBACKUP Starting dynamic config files check
Jan 01 00:00:00.094 [D4] [ 0.192167] NVBACKUP dynamic files check OK
Jan 01 00:00:00.096 [D4] [ 0.194580] KCUS customization: no new version to apply
Jan 01 00:00:00.100 [D4] [ 0.198090] lwm2m FirmwareVersion is up to date
Jan 01 00:00:00.100 [D4] [ 0.198921] Setting UART timeout for: 4000msec
Jan 01 00:00:00.111 [D4] [ 0.209163] RAM start = 901fc108
Jan 01 00:00:00.111 [D4] [ 0.209216] heap start = 901fc108
Jan 01 00:00:00.111 [D4] [ 0.209233] Computed heap size=1064696
Jan 01 00:00:00.121 [D4] [ 0.219760] Calling lte driver with uart:N baudrate:921600 flow_ctrl:0
Jan 01 00:00:00.122 [D4] [ 0.220485] LTE driver init complete
Jan 01 00:00:00.122 [D4] [ 0.220526] irq_i2cDrv configured
[Jan 01 00:00:00.122] Line number[285] File ptr [0x807c7] param1[0x35d7f] param2[0x0] param3[0x0]
Jan 01 00:00:00.122 [D4] [ 0.220565] irq_i2cDrv configured
[Jan 01 00:00:00.122] Line number[285] File ptr [0x807c7] param1[0x35da3] param2[0x0] param3[0x0]
Jan 01 00:00:00.123 [D4] [ 0.221384] alt1250_usb_init()=-1
Jan 01 00:00:00.124 [D4] [ 0.222100] Calling main app init
Jan 01 00:00:00.124 [D4] [ 0.222725] Setup AT/PPP [B] & CLI/AT [A] & FW_LOG [N] & AT [N] & AT_2 [N] !
Jan 01 00:00:00.124 [D4] [ 0.222773] Setup TCP dump [N] & SFP logger [N] & LTE driver FW [N] & MUX A [N] & MUX B [N] & NMEA [N] & DATA [N]!
Jan 01 00:00:00.124 [D4] [ 0.222831] Calling createSerialSwitchApi() with switch id=4 OK !!!
Jan 01 00:00:00.124 [D4] [ 0.222853] create switch id=5 OK
Jan 01 00:00:00.124 [D4] [ 0.222874] switch id=6 not created - nmea port undefined
Jan 01 00:00:00.124 [D4] [ 0.222899] switch id=7 not created - data port undefined
Jan 01 00:00:00.124 [D4] [ 0.222924] switch id=13 not created - atSoloPort undefined
Jan 01 00:00:00.124 [D4] [ 0.222949] switch id=14 not created - atSoloPort2 undefined
Jan 01 00:00:00.125 [D4] [ 0.222986] Open UART-B base = 0xbf0a0000 cfg =0xbf020000 intrp=76
Jan 01 00:00:00.125 [D4] [ 0.223087] serialMngrOpen:656, device=B 0x902441e0
Jan 01 00:00:00.125 [D4] [ 0.223122] Setup UART B BUT don't connect to pin out
uart_flow_control_task is called HW FLOW is ON
Jan 01 00:00:00.129 [D4] [ 0.227498] hifc_register_uart_CBs was called
Jan 01 00:00:00.130 [D4] [ 0.228107] getDefaultBaudRate port 1: 921600
Jan 01 00:00:00.130 [D4] [ 0.228789] Setup UART B in Tx blocking ON SW FIFO mode
Jan 01 00:00:00.130 [D4] [ 0.228829] Setup rx_tx_interrupt_ for uart 1
Jan 01 00:00:00.130 [D4] [ 0.228865] Calling irq_moveInterruptToHW2() with uart id=1
Jan 01 00:00:00.130 [D4] [ 0.228904] Open UART-A base = 0xbf0a1000 cfg =0xbf021000 intrp=77
Jan 01 00:00:00.130 [D4] [ 0.228958] Setup rx_interrupt_only for uart 0
Jan 01 00:00:00.131 [D4] [ 0.229038] serialMngrOpen:656, device=A 0x902463b0
Jan 01 00:00:00.131 [D4] [ 0.229064] Setup UART
Jan 01 00:00:00.137 [D4] [ 0.235200] getDefaultBaudRate port 0: 115200
Jan 01 00:00:01.292 [D4] [ 1.390022] lwip_stats ready
Jan 01 00:00:01.293 [D4] [ 1.391613] Calling i2s_test_app_entry
Jan 01 00:00:01.307 [D4] [ 1.404310] SWISERVER is starting...
Jan 01 00:00:01.509 [D4] [ 1.607340] Starting Watchdog timer
Jan 01 00:00:01.513 [D4] [ 1.611557] HIFC HOST_TO_MODEM GPIO is LOW
Jan 01 00:00:01.513 [D4] [ 1.611704] HIFC configured gpio HOST_TO_MODEM=61, MODEM_TO_HOST=17 mode=C
Jan 01 00:00:01.513 [D4] [ 1.611745] Cause of last reset: 0x0
Jan 01 00:00:01.515 [D4] [ 1.613122] CLI AT cmd buff len is 3092
Jan 01 00:00:01.571 [D4] [ 1.669618] LteDriver - init task ended
Jan 01 00:00:01.617 [D4] [ 1.715808] 1st AT cmd: AT%getcfg="pw_mode"
- sent/rcv -> 0/0 Msec
Jan 01 00:00:04.654 [CRI] Fail to send At respond
+CEREG: 2
Jan 01 00:00:04.657 [CRI] Fail to send At respond
+CREG: 0
Jan 01 00:00:05.167 [CRI] Fail to send At respond
+CEREG: 0
Jan 01 00:00:05.170 [CRI] Fail to send At respond
+CREG: 0
Jan 01 00:00:05.180 [CRI] Fail to send At respond
+CEREG: 2
Jan 01 00:00:05.183 [CRI] Fail to send At respond
+CREG: 2
DRAM: 2.5 MiB
Boot mode 2
Enable QUAD mode
Flash: 32 MiB
map import OK
In: serial
Out: serial
Err: serial
Version: 2.0
Un-Protected 4 sectors
Erasing Flash.......
Erased 4 sectors
Writing to Flash... done
Protected 4 sectors
Protected 4 sectors
ERROR: 00000008
ERROR: 00000008
do_halt...
