Thank you for the response Donald.
That’s just the thing, I’m working with the provider to figure out the support. I’ve used the same modems to connect to Cat M1 & NB IoT IP just fine. It’s the NOIP part that is giving everyone trouble. Provider has also requested we try to get a newer version of the ALT1250 firmware, 03, but the available HL78xx firmware on the Source is still 02
Firmware HL7800.4.4.6
It has seemed like the modem is always using Extended PCO IE, even when I turn it off with AT+KCIOTOPT. My provider has stated this is not supported
I have just heard back from the service provider that I am trying to connect to. It seems that my HL7800 is sending an IPCP option even when I set the pdp to use no ip, like in
AT+CGDCONT=1,"Non-IP","SCEF",,,,,,,,,,,,1,1
and IPCP is not supported.
Can I turn that off? I didn’t see anything that seemed to work in the AT commands.
