I am currently trying to implement a HL7810 modem into a linux system that has been using the HL7800.
A number of AT commands which worked for the HL7800 now fail with the HL7810 with identical AT+KUSBCOMP configuration. The first key command that fails is AT+CGDCONT=?. In order to confirm that the issue is not due to the linux system I placed both modules in the Sierra Wireless dev board and communicated with the modules over a putty serial connection.
HL7800:
ATI3
HL7800.4.4.6.0
AT+CGDCONT=?
+CGDCONT: (1-15),“IP”,(0),(0),(0-1),(0-1),(0-2),(0),(0-1),(0),(0),(0),(0),(0)
+CGDCONT: (1-15),“IPV6”,(0),(0),(0-1),(0-1),(0-2),(0),(0-1),(0),(0),(0),(0),(0)
+CGDCONT: (1-15),“IPV4V6”,(0),(0),(0-1),(0-1),(0-2),(0),(0-1),(0),(0▒▒▒▒▒▒’▒▒▒’▒▒▒%"h▒▒▒▒
▒▒▒▒▒▒▒▒▒▒$h@▒(▒▒▒▒▒▒$hd▒▒e▒▒e▒▒▒▒▒0)
HL7810
ATI3
HL7810.5.4.8.0
at+cgdcont=?
+CGDCONT: (1,2),“IP”,(0),(0),(0-1),(0-1),(0-2),(0),(0-1),(0),(0),(0),(0),(0)
+CGDCONT: (1,2),“IPV6”,(0),(0),(0-1),(0-1),(0-2),(0),(0-1),(0),(0),(0),(0),(0)
+CGDCONT: (1,2),“IPV4V6”,(0),(0),(0-1),(0-1),(0-2),(0),(0-1),(0),(0),(0),(0),(0)
ATIDCONT: (1,2),“Non-IP”,(0),(0),(0-1),(0-1),(0-2),(0),(0-1),(0),(0),(0),(0),(0)▒▒▒▒▒
+CEREG: 0
As you can see this command never returns OK.
There are now avaulable firmware updates for the HL7810 that I am aware of.
Any assistance on the issue is appreciated.
