[HL7688] Firmware Update via UART from Embedded Linux (Busybox) — Procedure & Tools?
Hardware & Environment:
  • Modem: Sierra Wireless HL7688
  • Host Processor: AM335x ARM Cortex-A8
  • OS: Linux 4.4.19, Busybox environment
  • Interface: UART (host processor ↔ modem), no USB available on this platform
  • Current Modem FW: 2.15.1.0.151600.201809181425.x7160_1
  • Target FW: Latest available for HL7688
What I need:
I need to update the HL7688 modem firmware over UART from an embedded Linux/Busybox environment. USB is not an option on this platform.
Specific questions:
  1. Firmware package — I don’t currently have the .cwe/.spk package. Where can I download the latest HL7688 firmware? (I have access to the Sierra Wireless Source portal.)
  2. Flashing tool — Is fwdwl-lite or nufwdwl-uart the right tool for UART-based flashing on an embedded Linux host? Are pre-built ARM binaries available, or will I need to cross-compile for arm-linux-gnueabihf?
  3. Download mode — What is the correct procedure to put the HL7688 into firmware download/QDL mode over UART? Is AT!BOOTHOLD supported, or is a hardware reset sequence required?
  4. UART port — Should I be using the modem’s DM port or the AT command port for the flashing process?
  5. Baud rate — What baud rate should be used during the UART flash procedure?
Any pointers to AN or documentation specifically covering UART-based firmware update for the HL7688 on embedded Linux would be greatly appreciated.
have you tried download via Airvantage platform?
BTW, I saw there is AT command to download by XModem protocol:
@jyijyi Thanks, I was able to successfully update the modem firmware using the AT commands. Below are a few observations that were not mentioned in the datasheet, or that I discovered during the process:
  • AT+KSLEEP=0 — Sleep mode must be disabled; otherwise, the file transfer will not work.
  • AT+WDSI=4095 — This enables all notifications.
  • After the file transfer, I did not receive the expected +WDSI: 3. I manually issued AT+WDSR=4 and waited until +WDSI: 16 appeared.
This topic was helpful → HL7688 Firmware Archive
However, I only see the firmware version RHL7688.A.2.15.1.0.151600.201809181425.x71601signed_DWL.dwl available for download(Already my current version). Are there other versions I can test—for example, to perform upgrade/downgrade validation?
The available file is quite large (~20 MB) and takes a long time to transfer over UART. Are delta-update files available instead? If so:
  • Where can I obtain them?
  • How should they be flashed onto the modem?
have you tried higher baud rate and see if it speed up the transfer?
You can also try Airvantage to do firmware upgrade
Higher baud rates would certainly improve the firmware transfer time, but due to design constraints I am limited to using 115200. Using AirVantage isn’t an option for my setup, as the firmware update for this modem needs to be fully controlled by my own application.
Are delta-update files available? If so:
what is the current firmware version of your modules in the field?
Are you going to upgrade to 2.15.1.0?
BTW, did you report this request to your distributor?
