HL7650 Android 9 RIL 32-Bit
Hi, I’m trying to add the Android RIL to my Android 9 build from the Android RIL v9.0.10.0 zip. The integration guide says to use a bunch of libraries and applications specific to a 32-bit build. These files aren’t in the zip file, only the 64-bit ones are provided.
Is there anywhere I can find these?
Hi @nicholash
According to Sierra Wireless Android RIL V9.0.10.0 ARM 64 Release Note
“1.2.1. Supported Release Configuration
This release note is applicable to release configuration:
AndroidRIL_V9.0.10.0_ARM_64_bin
Android RIL version 9.0.10.0
ARM based processors for Android Pie (9.0) 64-bit user space
Binary only release”
You can get Android 9.0 RIL Release Note here Android 9.0 RIL Release Note
Please help to tick “Solutions” if your question is answered.
Is an ARM32 version available?
I see version 9.0.3.0 added support for the ARM 32 Hikey platform. Is this available anywhere?
Hi @nicholash
You can use Android 8.1 RIL Software 8.1.2.0 version for 32 bit.
Android RIL 9.0.3.0 version has not been published on source.sierrawireless.com
All Android RIL versions have been published here Android RIL Software
This does not have the required files. It only has the 64-bit files.
These files should exist as per the integration manual
AndroidFS/(vendor|system/vendor)/bin/swihltrace
AndroidFS/(vendor|system/vendor)/bin/slqssdk
AndroidFS/(vendor|system/vendor)/bin/SierraDMLog
AndroidFS/(vendor|system/vendor)/bin/SierraFwDl7xxx
AndroidFS/(vendor|system/vendor)/bin/SierraImgMgr
AndroidFS/(vendor|system/vendor)/bin/SierraSARTool
AndroidFS/(vendor|system/vendor)/bin/DownloadTool
AndroidFS/(vendor|system)/bin/dhcpcd
AndroidFS/(vendor|system/vendor)/lib/libsierra-ril.so
AndroidFS/(vendor|system/vendor)/lib/libsierraat-ril.so
AndroidFS/(vendor|system/vendor)/lib/libsierrahl-ril.so
AndroidFS/(vendor|system)/lib/libswims.so
AndroidFS/(vendor|system)/lib/libswiqmiapi.so
AndroidFS/(vendor|system)/lib/libDownloadTool.so
AndroidFS/system/app/com.sierra.logs/com.sierra.logs.apk
AndroidFS/system/app/swifota/swifota.apk
AndroidFS/system/app/swiomadm/swiomadm.apk
AndroidFS/system/app/simswitcher/simswitcher.apk
Notably the files that go in the “lib” folder.
Is there a release available that has these files?
Hi @nicholash
No, there isn’t.
According to Sierra Wireless Android RIL V9.0.10.0 ARM 64 Release Note:
Android RIL version 9.0.3.0 added support for the ARM 32 Hikey platform.
Please contact your distributor or submit “Contact Us” on Sierrawireless.com for support in this case.
