Sending SMS with the HL6528RD is normally easy. But sometimes I observed “CMS ERROR 2165” after transmitting the 0x1A and the SMS is not send. Looking for an explanation in the documentation of the module I did not find anything.
I can’t test it with PDU mode. It communicates with a server, which accepts only text messages.
Does this only happen on one particular network operator
These error occurs only with SIM cards of the “telekom” after several months of usage.
After replacement of the SIM with a new one (same phone number ), the error occurs again after some months.
So the question is, what happens with the SIM ?
What says the CME error code 2165 ?
After transmitting the content of the SMS the 0x1A is send. The 0x1A is send only for signaling the end of this data transmission. If the 0x1a is not transmitted, the SMS is not send - but this is normal.
The SIM with showed CMS Error:2165 shows these error once and did not connect to the network provider anymore. Registration always failed. Other SIM worked.
Would you please so kind to tell me what these error code means ?
