HL6528-G I2C Interface
i’m a bit confused about the i2c interface. As mentioned in the AirPrime_HL6528x_Product_Technical_Specification_Rev5_0.pdf pdf the HL6528 i2c works in master mode only. What i do not find in the document is multimaster mode supported ? Also when i look up the AirPrime_HL6_and_HL8_Series_AT_Commands_Interface_Guide_Rev8_0.pdf (S.636) pdf there is a at command to display the address of the I²C device… is this the address of the slave device(s) ?.. is it possible to enter more then 1 slave ? … when i enter AT+KIICADDR? i only get ERROR as a response…
can someone explain the i2c capabilities of the HL6528-G in detail ? or is there some more detailed information available ?
Thanks in advance
Having an equivalent question with HL8548-G i’would like to know if you find documentation or support on this I2C topic. Thanks in advance for your feedback.
br,
