Hi all
I had an app running serial port and tcp client.
serial port is in FCM mode, baud rate 9600, parity odd, hardware control,
I am using AT+IFC=2,2, AT+ICF=2,0 to setup the serial port.
After load the app to board, I have to unplug the serial connection to be able to receive data. It running well a few seconds, it can receive data for a while, then it couldn’t for some reason. I have to unplug the connection, then plug back, serial port receive data ok for a while.
What’s the problem? I guess is RTS/CTS holding the line. If plug the same serial cable to PC, PC receives data perfect.
