GS64 Programming
Hello, I have a Telit GT64, using the Wavecom GS64 chip, and attemtping to find some software capable of flashing it.
I have tried Developer Studio, but some of the AT commands it is sending are not being recognized, the command set seems to be different. I get the following output :
Restart
Debug informations on UART1
Gx64ACV013
init Watchdog 5 min
created AT channel, result = 0 (0=ok)
AT sending cmd->AT+CPIN?
 rsp->
ERROR
PIN 7777 [5]
Error: 0x3
AT+WMSN
ERROR
AT+CFUN=1
AT+WMSN
ERROR
AT+WMSN is not recognized on this version. No sim card in at this point which is also accounting for some errors, but makes no differnece with regards to developer studio working. There are some discrepancies such as codes used to program the flash.
THe command set for the device is here :
euromobile-ukraine.com.ua/fi … 072%29.pdf
Is there a version of firmware I can flash to this module to make it work with developer studio ? Or alternatively, is there an older verision of M2MStudio I can use this module with ?
Thanks.
Did you try contacting your distributor ? Because Airprime GR/GS64
is no longer supported.
