The FASTTRAC Suppreme modem is working, voice call setup OK, SMS service OK.
I still have a problem in configuration of the GPRS connection.
I have a SIM card with the data service from Belgian Telecom operator BASE
APN : gprs.base.be
Userid : base
Passwod : base
The GPRS access is working when the SIM card is placed in in GSM with
WAP facilities.
Following RS232 logs are taken with Hyperterminal connected to FASTTRAC Modem
Fasttrac Config & Setup
at
at+cgmi
WAVECOM MODEM
at+cgmm
MULTIBAND 900E 1800
at+whwv
Hardware Version 4.20
at+wcfm=5
+WCFM: 00000071,0
at+csq
+CSQ: 27,3
GSM SIM-PIN
at+cpin=1111
GPRS Setup
at+cgdcont=1,“IP”,“gprs.base.be”,“0.0.0.0”,0,0
at+cgqmin=1,0,0,0,0,0
at+cgqmin=1,0,0,3,0,0
atd99**1#
CONNECT 115200
~ÿ}#À!}!}!} }6}!}$}%Ü}"}&} } } } }’}"}(}"}#}$À#&´ÿ}#À!}!}!} }6}!}$}%Ü}"}&} } }ÿ}#À!}!}!} }6}!}$}%Ü}"}&} } } } }’}"}(}"}#}$À#&´
} }’}"}(}"}#}$À#&´ÿ}#À!}!}!ÿ}#À!}!}!} }6}!}$}%Ü}"}&} } } } }’}"}(}
“}#}$À#&´ÿ}#À!}!}!} }6}!}$}%Ü}"}&} } } } }’}"}(}"}#}$À#&´ÿ}#À!
Ü}”}&} } } } }’}"}(}"}#}$À#&´ÿ}#À!}!}!} }6}!}$}%Ü}"}&} } } } }’}"}(}"}#}$À#&´~ÿ}#À!}!}!} }6}!}$}%Ü}"}&} } }
} }’}"}(}"}#}$À#&´~
NO CARRIER
In the context command i enter the APN name “gprs.base.be” provided by ISP provider
BASE.
To setup the Internet Access Point i need also to enter the Userid/Passw combination
“base/base”.
After the connection towards th ISP is done, i need also to specify the destinaton
IP-Address an the PORT number of the server where i want to send data via the
GPRS modem.
I can not find the AT command to enter this data, Userid/Passw combination and Destination IP-Address.
Searching on the web, i found that for IP releated commands you need to enter
the AT# commands. But i can not find any reference to this commands in the Fasttrac
user manuals.
After entering the connect AT command “atd99**1#”. I get some non ASCII characters back
from Fasttrac followed by “No CARRIER” after ±10s.
Is it possible to get assistance to setup the GPRS connection with FASTTRAC suppreme
modem.
