G400 SYSLOG via AT*REMOTELOG
Hi all.
I have remote syslog working on my RV50X but also want to make this work on a couple of GX400.
the manual states AT*REMOTELOG=SYSLOG SERVER IP,PORT with the port being optional (default 514, which I use).
Would the correct format be:
AT*REMOTELOG=SYSLOG SERVER myserver.com
or
AT*REMOTELOG=SYSLOG myserver.com
And would this be for UDP or TCP (as I need tcp).
my commands are accepted with OK, but nothing arrives at my server
any help would be appreciated
firmware 4.4.9
Hi @renzo.karsdorp,
Welcome to our community!
In the Software Guide, use the command AT*REMOTELOG=SYSLOG SERVER IP,PORT.
Have you tried configuring the SERVER IP as an IP address instead of the character “myserver.com”?
After successful configuration, please share the log file in the Admin > Log > View log section with me.
Hi Jerdung
thanks for the response. I have tried the actual IP address instead of the host name.
unfortunaltely no luck. I cannot upload files so forgive my screendump below.
333.333.333.333 = syslog server
444.444.444.444 = my login ip
555.555.555.555 = WAN IP
Nov 27 08:23:24 debug ALEOS_WAN_RMON: Notify for : 112
Nov 27 08:23:43 info ALEOS_UI_AT: ->
Nov 27 08:23:48 info ALEOS_UI_AT: ->[AT*REMOTELOG=SYSLOG 333.333.333.333, 514]
Nov 27 08:23:53 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:23:53 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:23:53 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:23:53 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:23:53 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:23:53 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:23:53 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:23:56 debug ALEOS_SERVICES_ACEmanager: 444.444.444.444 - - “POST /cgi-bin/Embedded_Ace_Get_Task.cgi” 200 OK
Nov 27 08:24:01 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:24:01 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:24:01 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:24:01 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:24:02 info ALEOS_WAN_SCR: WAN Keepalive issue ping. Retry 5
Nov 27 08:24:02 debug ALEOS_WAN_RMAN: New ka traffic Nb = 3
Nov 27 08:24:03 debug ALEOS_WAN_SCR: Keep Alive Ping OK
Nov 27 08:24:03 info ALEOS_WAN_SCR: WAN Keepalive Sleeping 300 seconds
Nov 27 08:24:05 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:24:05 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:24:05 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:24:05 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:24:05 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:24:05 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:24:05 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 0
Nov 27 08:24:05 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 0
Nov 27 08:24:06 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:24:06 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:24:06 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:24:06 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:24:06 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 190115755
Nov 27 08:24:32 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:24:32 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:24:32 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:24:32 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:24:32 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:24:32 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:24:32 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:24:35 debug ALEOS_SERVICES_ACEmanager: 444.444.444.444 - - “POST /cgi-bin/Embedded_Ace_Get_Task.cgi” 200 OK
Nov 27 08:24:35 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Nov 27 08:24:40 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:24:40 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:24:40 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:24:40 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:24:44 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:24:44 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:24:44 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:24:44 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:24:44 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:24:44 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:24:44 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 0
Nov 27 08:24:44 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 0
Nov 27 08:24:45 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:24:45 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:24:45 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:24:45 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:24:45 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 190115755
Nov 27 08:25:01 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:25:01 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:25:01 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:25:01 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:25:01 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:25:01 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:25:01 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:25:07 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:25:07 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:25:07 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:25:07 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:25:07 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:25:07 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:25:07 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 0
Nov 27 08:25:07 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 0
Nov 27 08:25:07 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:25:07 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 190115755
Nov 27 08:25:19 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:25:19 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:25:19 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:25:19 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:25:19 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:25:19 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:25:19 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:25:24 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:25:24 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:25:24 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:25:24 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:25:24 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:25:24 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:25:24 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 0
Nov 27 08:25:24 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 0
Nov 27 08:25:24 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:25:24 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 190115755
Nov 27 08:26:01 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:26:01 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:26:01 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:26:01 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:26:01 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:26:01 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:26:01 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:26:07 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:26:07 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:26:07 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:26:07 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:26:07 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:26:07 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:26:07 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 0
Nov 27 08:26:07 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 0
Nov 27 08:26:07 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:26:07 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 190115755
Nov 27 08:26:15 debug ALEOS_SERVICES_ipMan: ipManProcessMSCIID: ipManPhase=0 serverUpdateNeeded=FALSE, msciid 10105
Nov 27 08:26:21 debug ALEOS_WAN_RMON: Notify for : 112
Nov 27 08:26:48 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:26:48 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:26:48 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:26:48 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:26:48 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:26:48 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:26:48 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:26:49 debug ALEOS_SERVICES_ACEmanager: 444.444.444.444 - - “POST /xml/GetIdleTime.xml” 200 OK
Nov 27 08:26:50 debug ALEOS_SERVICES_ACEmanager: 444.444.444.444 - - “POST /xml/GetIdleTime.xml” 200 OK
Nov 27 08:26:55 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:26:55 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:26:55 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:26:55 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:26:55 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:26:55 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:26:55 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 0
Nov 27 08:26:55 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 0
Nov 27 08:26:55 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:26:55 info ALEOS_WAN_RMON: PLMN: Optus, 50502, LAC: 39251, Cell Id: 190115755
Nov 27 08:26:59 debug ALEOS_WAN_RMON: Notify for : 2000
Nov 27 08:26:59 debug ALEOS_WAN_RMON: SWI_NOTIFY_NetworkStatus:
Nov 27 08:26:59 debug ALEOS_WAN_RMON: Maps GSM RSSI to bar code
Nov 27 08:26:59 debug ALEOS_WAN_RMON: Notify for : 2026
Nov 27 08:26:59 debug ALEOS_WAN_RMON: SWI_NOTIFY_ServiceIcon: HSPA+
Nov 27 08:26:59 debug ALEOS_WAN_RMON: Notify for : 2031
Nov 27 08:26:59 debug ALEOS_WAN_RMON: SWI_NOTIFY_GsmSystemStatus CellID: 61355
Nov 27 08:26:59 alert Embedded_Ace_Reset.cgi: ALEOS_SYSTEM: Reboot issued from UI…
Nov 27 08:26:59 alert ALEOS_SYSTEM_SCR_aleosreboot: Uptime → 08:26:59 up 19 min, 1 user, load average: 0.13, 0.19, 0.22
Nov 27 08:26:59 alert ALEOS_SYSTEM_SCR_aleosreboot: Sending Shutdown to DMNR
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: AppTask CEventDispatcher event CMultiDatabaseEvent
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: CEventDispatcher handling db event id=53212, value=1
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: CEventDispatcher handling db event cache update complete id=53212, value=1
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: ObserverList id=53212 notifying 1
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: ObserverList id=53212 notifying CForeignAgent
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: CForeignAgent: Shut down
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: IDatabaseObserver Converted id=53212 → 0x92998
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: IDatabaseObserver sending CForeignAgentShutdownEvent to CForeignAgent
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: AppTask CForeignAgent event CForeignAgentShutdownEvent
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: CForeignAgent: state=CForeignAgentDisableState, handling event CForeignAgentShutdownEvent
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: CForeignAgentDisableState accepting CForeignAgentShutdownEvent
Nov 27 08:26:59 debug ALEOS_NETSERV_Sys: CEventDispatcher notified observers of db event id=53212
Nov 27 08:27:01 info ALEOS_EVENTS_dpRptSend: Updating LATS destination IP to ‘192.168.1.100’
Nov 27 08:27:04 info ALEOS_SECURITY_SCR: Stopping Firewall.
Nov 27 08:27:04 info ALEOS_SECURITY_SCR: Starting Firewall
Nov 27 08:27:05 info ALEOS_SECURITY_SCR: DMZ State:1 DMZ IP: 192.168.1.2
Nov 27 08:27:06 info ALEOS_SECURITY_SCR: Creating port forwarding rule from external port range 22500 to 22500
Nov 27 08:27:06 info ALEOS_SECURITY_SCR: Creating port forwarding rule from external port range 80 to 80
Nov 27 08:27:06 info ALEOS_SECURITY_SCR: Creating port forwarding rule from external port range 50011 to 50011
Nov 27 08:27:10 info ALEOS_SECURITY_SCR: ALEOS using ports: 12345,17335,17345,17346,17347,161
Nov 27 08:27:10 info ALEOS_SECURITY_SCR: ALEOS additional ports: Event_server ports(5), TAIP ports (4), XORA ports (4) and Status_updr port (1)
Nov 27 08:27:10 info ALEOS_SECURITY_SCR: Firewall execution completed
Nov 27 08:27:10 alert ALEOS_SYSTEM_SCR_aleosreboot: *** Start of last 50 lines in dmesg ***
Nov 27 08:27:10 alert ALEOS_SYSTEM_SCR_aleosreboot: *** End of last 50 lines in dmesg ***
Nov 27 08:27:38 alert ALEOS_SYSTEM_SCR_rc.syslog: _ _ _ _ _
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_rc.syslog: / \ / \ / \ / \ / \
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_rc.syslog: | A | L | E | O | S |
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_rc.syslog: _/ _/ _/ _/ _/
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_rc.syslog: Sierra Wireless
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_rc.syslog: Copyright 2009-2020
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_rc.syslog: Version: 4.4.9.003
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_rc.syslog: Code-1
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_rc.syslog: Serial no: CA13313052010-05
Nov 27 08:27:39 info ALEOS_SYSTEM_WDlog: Change log level to 6
Nov 27 08:27:39 info ALEOS_SYSTEM_WDlog: Starting Monitor Process
Nov 27 08:27:39 notice ALEOS_SYSTEM_WDlog: HW Watchdog enabled.
Nov 27 08:27:39 notice ALEOS_SYSTEM_WDlog: New HW Watchdog timeout: 240 seconds
Nov 27 08:27:39 alert ALEOS_SYSTEM_startup: rc.platform Extracting ALEOS…
Nov 27 08:27:39 alert ALEOS_SYSTEM_startup: rc.radioinit Loading Sierra Radio Module Drivers…
Nov 27 08:27:39 alert ALEOS_SYSTEM_startup: rc.swiwd Watchdog Started - Not in DVT mode
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_fw_rm_resume: No Radio Firmware update pending
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_fw_rm_check: Checking Radio Firmware version
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_fw_rm_check: * Radio Type : MC8705
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_fw_rm_check: * Radio ID (CMNO): OSM001
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_fw_rm_check: * Radio PRI ID : 9993760
Nov 27 08:27:39 alert ALEOS_SYSTEM_SCR_fw_rm_check: * Radio FW Vers : T3_5_6_7AP R813 CNSHZ-ED-XP0031 2014/11/10 18:11:43
Nov 27 08:27:39 info ALEOS_SYSTEM_SM: Initializing…
Nov 27 08:27:39 info ALEOS_SYSTEM_SM: Adding container:‘Config11.smc’, shadow:‘Config12.smc’, capacity:‘393216’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Both container and shadow are good
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Container ‘Config11.smc’ size: ‘178556’, read offset:‘60’, write offset:‘178556’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Shadow ‘Config12.smc’ size: ‘262172’, read offset:‘60’, write offset:‘262172’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Adding container:‘SnF11.smc’, shadow:‘SnF12.smc’, capacity:‘153600’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Container ‘SnF12.smc’ size: ‘60’, read offset:‘60’, write offset:‘60’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Shadow ‘SnF11.smc’ size: ‘60’, read offset:‘60’, write offset:‘60’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Adding container:‘SnF21.smc’, shadow:‘SnF22.smc’, capacity:‘153600’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Container ‘SnF21.smc’ size: ‘13496’, read offset:‘60’, write offset:‘13496’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Shadow ‘SnF22.smc’ size: ‘102416’, read offset:‘60’, write offset:‘102416’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Adding container:‘SnF31.smc’, shadow:‘SnF32.smc’, capacity:‘153600’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Container ‘SnF32.smc’ size: ‘60’, read offset:‘60’, write offset:‘60’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Shadow ‘SnF31.smc’ size: ‘60’, read offset:‘60’, write offset:‘60’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Adding container:‘SnF41.smc’, shadow:‘SnF42.smc’, capacity:‘153600’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Container ‘SnF42.smc’ size: ‘60’, read offset:‘60’, write offset:‘60’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Shadow ‘SnF41.smc’ size: ‘60’, read offset:‘60’, write offset:‘60’
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Running…
Nov 27 08:27:40 info ALEOS_SYSTEM_SM: Retrieving records from ‘Config11.smc’ (index ‘7’)…
Nov 27 08:27:41 info ALEOS_SYSTEM_SM: Record counts: read ‘7115’ good records, ‘0’ bad records
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: Enabling MSCIIDs for GSM Radio
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: Enabling MSCIIDs Serial Port
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: Enabling MSCIIDs for GPS
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: QualcommDM Reserve Status = 0
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: Read XcardID = 6
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: Serial0 Reserve Status = 0
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: Serial1 Reserve Status = 0
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: X-Digital Reserve Status = 0
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: X-Analog Reserve Status = 0
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: X-Accel Reserve Status = 0
Nov 27 08:27:41 alert ALEOS_SYSTEM_MSCIEn: Enabling MSCIIDs for Wi-Fi XCard
Nov 27 08:27:43 info ALEOS_SYSTEM_SCR: Check Reset Configuration
Nov 27 08:27:43 info ALEOS_SYSTEM_SCR: No reset backup configuration
Nov 27 08:27:43 info ALEOS_SYSTEM_csmMigrator: csmMigrator: Migration complete.
Nov 27 08:27:44 info ALEOS_SYSTEM_SM: Retrieving records from ‘SnF21.smc’ (index ‘1’)…
Nov 27 08:27:44 info ALEOS_SYSTEM_SM: Record counts: read ‘530’ good records, ‘0’ bad records
Nov 27 08:27:44 notice ALEOS_WAN_CMAN: ConnectionManager::getInstance()
Nov 27 08:27:44 debug ALEOS_WAN_RMAN: New ka traffic Nb = 0
Nov 27 08:27:44 debug ALEOS_WAN_RMAN: processMSCIID: find OSM = 0, isOpenSim = 1
Nov 27 08:27:44 debug ALEOS_WAN_RMAN: —> PK15PDPRadioManager::isRoWRadioModule begin
Nov 27 08:27:44 debug ALEOS_WAN_RMAN: —> PK15PDPRadioManager::isCwsQmiRadioModule begin
Nov 27 08:27:44 debug ALEOS_WAN_RMAN: checkIfCwsReady: isRowRM = 1, isCwsQmi = 0, isOpenSim = 1, isCwsReady = 1
Nov 27 08:27:45 info ALEOS_WAN_SCR: rc.cellradio starting normally
Nov 27 08:27:45 alert ALEOS_WAN_SCR: IPV4 Disconnect Handled
Nov 27 08:27:46 debug ALEOS_WAN_SCR: Verifying Radio Enumeration
Nov 27 08:27:47 info ALEOS_SECURITY_SCR: Stopping Firewall.
Nov 27 08:27:47 alert ALEOS_WAN_SCR: Radio Enumerated Successfully
Nov 27 08:27:47 info ALEOS_SECURITY_SCR: Starting Firewall
Nov 27 08:27:47 info ALEOS_LAN_SCR: Configuring eth0 for link setting 0
Nov 27 08:27:48 debug ALEOS_LAN_SCR: Configuring eth0 for autoneg on
Nov 27 08:27:48 info ALEOS_WAN_SCR: rc.cellradio: Radio Serial Port handshake success after 4 loops
Nov 27 08:27:49 info ALEOS_WAN_SCR: SIM is in ready state
Nov 27 08:27:49 notice ALEOS_WAN_SCR: SIM ready after 1 loop(s) - continuing
Nov 27 08:27:50 info ALEOS_WAN_SCR: Cellular Radio Initialization Started
Nov 27 08:27:50 info ALEOS_WAN_linkmon: Change log level to 7
Nov 27 08:27:50 debug ALEOS_WAN_linkmon: ******************
Nov 27 08:27:50 debug ALEOS_WAN_linkmon: *** ***
Nov 27 08:27:50 info ALEOS_WAN_linkmon: *** linkmon ***
Nov 27 08:27:50 debug ALEOS_WAN_linkmon: compiled on Mar 2 2020 at time 13:54:52
Nov 27 08:27:50 info ALEOS_WAN_linkmon: dvtFlag=-1.
Im starting to suspect that my upto date linux mint rsyslog, might not allow the older syslog of the G400.
Hi @renzo.karsdorp,
GX400 does not have Remote Logging functionality. If you want to use Remote Logging, you can consider replacing them with other devices (Eg: GX450).
well that is sneaky. it is stated in the manual on page 440 (https://usatcorp.com/pdf/4118543_ALEOS_4.4.4.pdf
Hi @renzo.karsdorp,
Regarding the AT*REMOTELOG command, you can only use this command locally.
Thanks for your reply Jerdung.
With locally you mean SSH from the local LAN, not the WAN port?
or
Remotelog can only log to a local syslog?
