FX30S[WP7702] Downgrade the FW 15.1 to the FW 9.1 Version
HI @jyijyi
Can we Downgrade the FW version 15.1 to the FW Version 9.1 for the FX30S WP7702 Module??
Thanks and Regards
Manu
I guess this is depending on whether your FX30 (WP7702) is using old memory component.
BTW, you can give a try to see.
HI @jyijyi
Can you Tell me using the SKU1105032 can be Downgraded??
As I have tested in the FX30S WP7702 **SKU 1104542 it can be Downgraded Successfully From the 15.1 to Release 9.1
ati3
Model: FX30S(WP7702)
Revision: SWI9X06Y_02.36.08.09 c094f4 jenkins 2022/06/24 03:14:28
IMEI: 354723090164020
IMEI SV: 8
FSN: VU026200491610
+GCAP: +CGSM
at+creg?
ERROR
ati8
Legato Ver: 21.05.0_0e0fd5f3fc5f6169e2516f22304da11c
Yocto Ver: SWI9X06Y_03.00.13.00 2022-12-27_09:10:00
OS Ver: Linux version 4.14.253 (oe-user@oe-host) ( gcc version 9.3.0 (GCC), GNU ld (GNU Binutils) 2.34.0.20200220) #1 PREEMPT Tue Dec 27 08:09:00 UTC 202
LK Ver: SWI9X06Y_03.00.13.00
RootFS Ver: SWI9X06Y_03.00.13.00 2022-12-27_09:10:00
UserFS Ver: unknown
MCU Ver: 002.015
at
AT
ATI3
Revision: SWI9X06Y_02.16.06.00 7605a6 jenkins 2018/06/20 17:56:12
IMEI SV: 2
FSN: VU026200491610
+GCAP: +CGSM
ATI8
Legato Ver: 18.06.1_7bc924287cc41a0157bd414af840e754
Yocto Ver: SWI9X06Y_02.18.05.00 2018-07-20_21:00:21
OS Ver: Linux version 3.18.44 (jenkins@jenkins) (gcc version 6.2.0 (GCC) ) #2 PREEMPT Fri Jul 20 21:01:16 UTC 2018
LK Ver: SWI9X06Y_02.18.05.00
RootFS Ver: SWI9X06Y_02.18.05.00 2018-07-20_21:00:21
UserFS Ver: unknown
MCU Ver: 002.009
Manu
no, i cannot tell as this is depending on whether your FX30 (WP7702) is using old memory component in AT!BSINFO
hi @jyijyi
-> If not downgrading with the New Memory Component how to procced ??
Manu
what do you mean?
Do you mean you cannot type AT!BSINFO to get the memory type?
HI @jyijyi
AT!BSINFO
Product: FX30S(WP7702)
Revision: 40
Main: MDM9206 (000)
Radio: WTR2965
Power: PMD9607 (002)
Flash: MT29F4G08ABBEA3W 512MB x8 (44/0/0) (2048 blocks of 64 pages/block 4096B page size)
Here it is How can we now it’s an Older Memory Type??
Thanks and Regards
Manu
i think this is old memory type
Have you tried to downgrade to previous FW?
hi @jyijyi
Yes it would be Downgrade to the FW 15.1 to the Release 9.1
After Downgrade the Below see the FW version will change but in the ATI8 Response it would be in the same as legato version of 15.1 Can i know the Reason??
AT
AATI3
IMEI: 354723091613843
IMEI SV: 2
FSN: AT602408341010
+GCAP: +CGSM
ATI8
Legato Ver: 21.05.0.54b96444_0a6e18078edde5151619cb964564694d
Yocto Ver: SWI9X06Y_03.00.13.00 2022-12-28_08:23:43
OS Ver: Linux version 4.14.253 (oe-user@oe-host) ( gcc version 9.3.0 (GCC), GNU ld (GNU Binutils) 2.34.0.20200220) #1 PREEMPT Wed Dec 28 07:40:21 UTC 2022
LK Ver: 1.3.0_1aea4d8ec8
RootFS Ver: SWI9X06Y_03.00.13.00 2022-12-28_08:23:43
UserFS Ver: unknown
MCU Ver: 002.015
Manu
how about downgrading to other FW version like R15, R14 or R11?
https://source.sierrawireless.com/resources/airlink/software_downloads/fx30-firmware/fx30-firmware-catm/#sthash.CaWbU7CH.dpbs
hi @jyijyi
I need an Release 9.1 FW ?? I have another Dought can i have downloaded the FW version form the Below website is is correct ??
source.sierrawireless.com/resources/airprime/software/wp77xx/wp77xx-firmware-release-9,-d-,1/
Thanks and Regards
Manju
didn’t you are using FX30?
hi @jyijyi
Yes I am using the FX30S inside that WP7702 is there right ?? so i am using the link
MANU
then why don’t you use FX30 firmware if you are using FX30 device?
BTW, what is the return of the “AT!OEMAUTH?” command in your module?
I want to check if there is secure boot enabled for your device.
Hi @jyijyi
AT!OEMAUTH?
!OEMAUTH: Disabled
OEM cert hash: Not provisioned
Manu
ok, then it is not secure boot enabled for custom image.
hi @jyijyi
- → No issue Right to use the FW from WP7702 Link
- → Need to check
Manu
I remember R&D recommends using FX30 firmware for FX30 device
hi @jyijyi
Okay Thanks ,can i know how to reset the Modem to FACTORY Default FW version??
Manu
how about using AT!RMARESET command?
