I am testing Sierra Verizon ECC SIMs using an FX30S.
I loaded the latest Verizon Firmware found on the
Sierra source site:
FX30_WP77xx_full_R14.1.1.002-verizon-SWI9X06Y_02.22.12.00.cwe
The firmware was installed without any issue.
The default PDP contexts after the FW update did not have any APN specified for context Id #1.
I found the APN refernced on the Airvantage account setup page as: “num.vzwentp” and set up context #3 using the refernced APN.
So the context configuration is:
Context1 : None specified
Context 2 : VZWADMIN
Context 3 : “num.vzwentp”
Context 4 : VZWAPP
Context 5 : VZW800
Context 6 : VZWCLASS6
I am able to create data connection using legato cm data connect.
My test requires using the 9 pin serial connection on the FX30S.
Running chat session, I am able to establish a ppp connection; the ppp0 interface comes up and I have an IP address. However, I am not able to ping 8.8.8.8 on the ppp0 interface.
I had this same issue testing Sierra AT&T ECC SIMs and was able to get pings to work by specifying PDP type as IPV4 when setting the APN i.e.: at+cgdcont=1,“IP”,“<ATT_APN_NAME>”
I attempted to do the same with VZN context 3 with “num.vzwentp” , but was not able get pings to
succeed. ( I tried both “IP” and “IPV4V6”)
So, I have a couple of requests:
First,
Could I get the correct PDP context setup for (context IDs 1-6) using Sierra Verizon ECC SIM?
Second,
I suspect that I am missing some ppp configuration required to handle dual stack (IPV4V6). Could I get an example for a correct recommended working example for chat scripts for ppp connection from linux host that correctly supports dual stack (IPV4V6) configurations.
Thanks a lot for your help.
