Hi there, I have the SIerra Wireless FX30S gateway that came as part of the Electriq Solar battery BMS management solution.
I’m trying to connect using my windows laptop I down loaded the Driver file mentioned in your website. Which is this one https://source.sierrawireless.com/resources/legato/drivers-for-wp75xx_wp76xx_wp8548-series-modules---build-4836/#sthash.dsfnUvr3.dpbs
It doesn’t seem to work. MY laptop is Win 11 and this driver is from over 5 to 6 years ago. So not sure if I need to use an old windows version for using this driver.
I need to connect to the FX30S so that I could transfer , update some of the files that are tied to the Battery management system.
So appreciate your help.
how about using this one which is newer version?
Thank you Very much, It connects now
THANKS SO MUCH!!!
The web site still delivers an old version, that WIn11 rejects because of an expired signature. Fingers crossed this one works.
Nope. Still fails.
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
An Application Control policy has blocked this file.
Signature no longer valid.
Are you trying on this driver (build 5413)?
https://source.sierrawireless.com/resources/airprime/software/drivers/windows/q/m2m_windows_drivers_qmi_latest_release/#sthash.tSyRoHO1.dpbs
BTW, do you mean the ECM driver has problem as this discussion thread?
Ah, no… thanks!!! 5087 was “latest” release on the page I found. I’ll try 5413 and will reply with status.
BTW, SOURCE even 5087 was only availalbe from your link… going through SOURCE to find FX30 device drivers gives really old version.
No luck. Latest WP77xx does not include the USB-to-ethernet driver.
you can search WP7702 instead of FX30:
https://source.sierrawireless.com/resources//#tags=WP7702|Firmwares+%26+drivers
Ah… ECM driver is apparently the one I’m struggling with. We need USB-to-ethernet to “build” a modem for customers.
The WP77* drivers don’t seem to include that.
I read your other posts on that subject… is there any solution in sight? Are we still needing to bypass Windows security to support FX30?
the solution could be one of the following:
- contact distributor to get a new ECM driver (internal ticket number: HSWOEMP-6006)
- rebuild NCM driver in yocto image to use NCM driver instead of ECM driver
- use USB raw data port to dial up so that user can SSH via USB raw data port
Hi Mike, Is this a recent email or an old one from last year?
Ramana
Someone replied to your post.
| mike.brearton
August 17 |
This is current. Aug 2026.
My research suggests the Microsoft change rejecting the driver didn’t happen until early 2026
Wow okay. I went with the full goodwe route so it is connevted through the wifi device of goodwe.
Ramana
There is new driver uploaded in SOURCE website, you can try that:
Awesome. Thanks… good to know.
As you suggested, we got updated drivers directly from support in Australia. I won’t risk checking these ones (if it ain’t broke), but good to know Semtech is awake.
