FX30S GPRS dial command
Hi guys,
We were supplying Insys GSM Small 2.0 as part of our product, but it is extinct so I’m looking for a replacement. I have a FX30S, but it’s not accepting my ATD command. Here’s my setup and dial attempts:
AT
ATZ
ATH
AT+CSQ
+CSQ: 12,0
AT+CGDCONT=1,“IP”,“myapn.com”
ATD991#
ERROR
ATD#GPRS
ERROR
ATD
99
1#
ERROR
ATD99*1
ERROR
ATD
99
ERROR
I’ve looked in the manual, but it’s not telling me much, nor are searches on these forums and elsewhere. What am I missing?
Thanks for your help,
Cheers,
ScottCr
How about
atd*99***1#
Also how is at!gstatus?
Hi jyiyji, thanks for the look-in. ATD*99***1# is my default dial string, it also returns error.
at!gstatus?
!GSTATUS:
Current Time:  241              Temperature: 22
Modem Mitigate Level: 0         ModemProc Mitigate Level: 0
Reset Counter: 1                Mode:        ONLINE
System mode:   LTE              PS state:    Not attached
LTE band:      No band          LTE bw:      1.4 MHz
LTE Rx chan:   0                LTE Tx chan: 4294967295
LTE CA state:  INACTIVE
EMM state:     Deregistered     Attach Needed
RRC state:     RRC Releasing
IMS reg state: No Srv
PCC RxM RSSI:  0                RSRP (dBm):  0
PCC RxD RSSI:  0                RSRP (dBm):  0
Tx Power:      0                TAC:         FFFF (65535)
RSRQ (dB):     0                Cell ID:     FFFFFFFF (4294967295)
SINR (dB):     0
Interesting that gstatus look all negative. I believe the SIMs are not enabled for 4G yet, but the modem then should drop back to 2G by default (3G is also blocked because the customer was having reliability issues).
Check at!selrat? And see if it is lte only.
at!selrat?
!SELRAT: 12, GSM and LTE Only
So it should do GSM.
Going down the SELRAT rabbit hole, I also checked:
AT+KSRAT?
+KSRAT: 9
I set AT+KSRAT=0, but still get the error on dialling ATD99**1#
Can we set to gsm only in at! selrat
It must be attached before atd99**1#
+KSRAT options:
(RAT index):
• 0—All RATs, automatic
• 1—GSM only
• 2—UMTS only
• 4—UMTS and GSM
• 5—LTE only
• 7—LTE and UMTS
• 9—LTE and GSM
So I tried:
AT+KSRAT=1
ATD*99***1#
ERROR
AT+KSRAT=2
ERROR
AT+KSRAT=4
ATD*99***1#
ERROR
AT+KSRAT=5
ATD*99***1#
ERROR
AT+KSRAT=7
ATD*99***1#
ERROR
AT+KSRAT=9
ATD*99***1#
ERROR
Please also check at! gstatus? After setting technology
AT+KSRAT=0
AT!GSTATUS?
!GSTATUS:
Current Time:  3146             Temperature: 25
System mode:   GSM              PS state:    Attached
GSM band:      GSM900
GSM channel:   35
GMM (PS) state:REGISTERED       NORMAL SERVICE
MM (CS) state: IDLE             NORMAL SERVICE
Serving cell:  35 (GSM900     )
RX level (dBm):-82.6250         LAC:         0130 (304)
GPRS state:    GPRS READY       Cell ID:     0000090E (2318)
ATD*99***1#
ERROR
AT+KSRAT=1
AT!GSTATUS?
!GSTATUS:
Current Time:  3160             Temperature: 26
GSM band:      GSM900
GSM channel:   43
RX level (dBm):-90.6875         LAC:         0130 (304)
ATD*99***1#
ERROR
AT+KSRAT=2
ERROR
AT+KSRAT=4
AT!GSTATUS?
!GSTATUS:
Current Time:  3193             Temperature: 25
GSM band:      GSM900
GSM channel:   38
RX level (dBm):-84.5625         LAC:         0130 (304)
ATD*99***1#
ERROR
AT+KSRAT=5
AT!GSTATUS?
!GSTATUS:
Current Time:  3212             Temperature: 25
System mode:   LTE              PS state:    Attached
EMM state:     Registered       PLMN Search
RRC state:     RRC Idle
Tx Power:      0                TAC:         0000 (0)
RSRQ (dB):     0                Cell ID:     00000000 (0)
SINR (dB):     0
ATD*99***1#
ERROR
AT+KSRAT=7
AT!GSTATUS?
!GSTATUS:
Current Time:  3230             Temperature: 26
LTE band:      No band          LTE bw:      Unknown
RRC state:     RRC Idle
Tx Power:      0                TAC:         3FED (16365)
RSRQ (dB):     -2320            Cell ID:     836C7304 (2204922628)
SINR (dB):     0
ATD*99***1#
ERROR
AT+KSRAT=9
AT!GSTATUS?
!GSTATUS:
Current Time:  3247             Temperature: 26
System mode:   GSM              PS state:    Not attached
GSM band:      GSM900
GSM channel:   40
GMM (PS) state:Registering      NORMAL SERVICE
Serving cell:  38 (GSM900     )
RX level (dBm):-98.8750         LAC:         0130 (304)
GPRS state:    GPRS IDLE        Cell ID:     00004644 (17988)
ATD*99***1#
ERROR
How about using usb AT port to dial up?
i believe you are using fs30s cat m device which is having wp76 module inside, i can make a test on wp76 mangoh board here.
no ERROR is found for usb dial up on WP7608:
ati3
Model: WP7608
Revision: SWI9X07Y_02.28.03.03 000000 jenkins 2019/05/21 03:33:04
IMEI: 352913090100734
IMEI SV: 6
FSN: XG805285330204
+GCAP: +CGSM
at!gstatus?
!GSTATUS:
Current Time: 67 Temperature: 31
Reset Counter: 4 Mode: ONLINE
IMS reg state: UNKNOWN IMS mode: Not Support
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
LTE band: B3 LTE bw: 20 MHz
LTE Rx chan: 1385 LTE Tx chan: 19385
RRC state: RRC Idle
PCC RxM RSSI: -70 RSRP (dBm): -95
PCC RxD RSSI: -94 RSRP (dBm): -133
Tx Power: 0 TAC: 0462 (1122)
RSRQ (dB): -5 Cell ID: 06745D16 (108289302)
SINR (dB): 15.8
atd99**1#
CONNECT 150000000
at!selrat?
!SELRAT: 00, Automatic
+CREG: 1,“FFFE”,“6745D15”,7
+CGREG: 1,“FFFE”,“6745D15”,7
+WDSI: 0
at+ksrat?
+KSRAT: 0
at+ksrat=?
+KSRAT: (0,1,2,4,5,7,9)
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,“hkcsl”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 10,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 11,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 12,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 13,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 14,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 15,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 16,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IP”,“hkcsl”,“0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“sos”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1
+CGDCONT: 4,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 5,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 6,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 7,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 8,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 9,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
USB is not an option. We need this modem to connect to an RTU, which does not have a USB port. I need a drop-in replacement for the Insys GSM Small 2.0. If a £200 modem fails, I need to replace it with another £200 modem, not rebuild the entire £5000 panel to get a modem working.
ati
Model: FX30S(WP7702)
Revision: SWI9X06Y_02.16.06.00 7605a6 jenkins 2018/06/20 17:56:12
IMEI: 354723090118331
IMEI SV:  2
FSN: VU911670061310
+GCAP: +CGSM
This is just to see if problem only happened to uart.
I will make a try to wp77 on mangoh board later.
BTW, no ERROR is found for my WP77 to dial up on GSM network:
ati9
Model: WP7702
Revision: SWI9X06Y_02.22.12.00 eaf79c jenkins 2019/04/24 18:48:27
IMEI: 352653090002791
IMEI SV: 3
FSN: VU735370340201
+GCAP: +CGSM,+DS
ati8
Legato Ver: 18.09.2_2a5c6ae47c6da6f1483bc7eac5d48fa1_modified
Yocto Ver: SWI9X06Y_02.22.12.00 2019-04-24_20:46:59
OS Ver: Linux version 3.18.44 (jenkins@jenkins) (gcc version 6.2.0 (GCC) ) #2 PREEMPT Wed Apr 24 20:48:03 UTC 2019
LK Ver: SWI9X06Y_02.22.12.00
RootFS Ver: SWI9X06Y_02.22.12.00 2019-04-24_20:46:59
UserFS Ver: unknown
MCU Ver: 002.011
at!gstatus?
!GSTATUS:
Current Time: 398 Temperature: 28
GSM band: DCS1800
GSM channel: 530
Serving cell: 530 (DCS1800 )
RX level (dBm):-83.5000 LAC: 046B (1131)
GPRS state: GPRS STANDBY Cell ID: 0000EDD4 (60884)
at!selrat?
at+ksrat?
+KSRAT: 9
at
atd99**1#
CONNECT 150000000
I’ve noticed that your firmware is a higher rev than mine:
Mine:
AT+GMR
But when I look at the firmware release page at https://source.sierrawireless.com/resources/airlink/software_downloads/fx30-firmware/fx30-firmware-3g/, the release version is called R14.0.4.002, which doesn’t correlate with the reported format.
When I look in the firmware image, I can see it’s tagged
SWI9X15Y_07.12.09.00 r34123 CARMD-EV-FRMWR1 2017/04/26 23:34:19
Would you recommend I upgrade to this firmware? Is there a significant difference between SWI9X06Y and SWI9X15Y, and are they compatible?
Also, I have been trying to get more detailed error reports, but it appears they are not supported, does this sound right?
AT!SCACT=1
+CME ERROR: no network service
ATDT*99***1#
ERROR
AT+CEER
ERROR
I think you downloaded the wrong FW.
Didn’t you should download the fw from here which is for FX30S(WP7702)?
https://source.sierrawireless.com/resources/airlink/software_downloads/fx30-firmware/fx30-firmware-catm/#sthash.7q6izMfZ.dpbs
Hi jyijyi, either I’m having a very blonde moment, or your documentation is seriously lacking. I’ve just spent an hour reading and Googling, but I cannot find a solid way to upgrade the firmware. The manual just says:
SSH on USB:
1. Copy FX30_WP8548_full_R14.0.4.002.cwe to the FX30 file system using scp.
2. Open an SSH session.
3. Execute fwupdate download FX30_WP8548_full_R14.0.4.002.cwe .
With some intuition I found the modem is at 192.168.2.2 when connected via USB, but what is the SCP username and password??
