FX30s firmware images for ReleaseR15.0.5.002
I am trying to understand the different firmware images produced by Yocto for Release15 (fx30_catm)
While I understand there are carrier specific images, for Products like FX30s with eUICC (eSim) variants, is the correct image Generic ? Or Sierra ?
FX30_WP77xx_full_R15.0.5.002_5145594a-att-SWI9X06Y_02.36.06.00.cwe
FX30_WP77xx_full_R15.0.5.002_5145594a-generic-SWI9X06Y_02.36.08.09.cwe
FX30_WP77xx_full_R15.0.5.002_5145594a-generic_gcf-SWI9X06Y_02.36.06.00.cwe
FX30_WP77xx_full_R15.0.5.002_5145594a-sierra-SWI9X06Y_02.36.06.00.cwe
FX30_WP77xx_full_R15.0.5.002_5145594a-telstra-SWI9X06Y_02.36.08.02.cwe
FX30_WP77xx_full_R15.0.5.002_5145594a-verizon-SWI9X06Y_02.22.12.00.cwe
Are you going to use physical SIM card (what operator) or use the eSIM?
I will only be using e-SIM for this product going forward. I have a smart e-sim already enabled and active. Carrier shows Sierra when I set AT!IMPREF=“AUTO-SIM”
I flashed the Generic Firmware : FX30_WP77xx_full_R15.0.5.002_5145594a-generic-SWI9X06Y_02.36.08.09.cwe
AT!IMAGE?
FW 1 GOOD 1 0 0 ?? 02.36.06.00?
FW 2 GOOD 2 0 0 ?? 02.36.08.09?
FW 3 GOOD 1 0 0 ?? 02.22.12.00?
Max FW images: 3
Active FW image is at slot 2
PRI FF GOOD 0 0 0 001.067_000 02.36.06.00_ATT
PRI FF GOOD 0 0 0 001.079_000 02.36.08.09_GENERIC
PRI FF GOOD 0 0 0 001.049_000 02.36.08.09_SIERRA
PRI FF GOOD 0 0 0 001.059_001 02.36.08.01_TELSTRA
PRI FF GOOD 0 0 0 001.042_000 02.22.12.00_VERIZON
Max PRI images: 50
AT!IMPREF?
!IMPREF:
preferred fw version: 00.00.00.00
preferred carrier name: AUTO-SIM
preferred config name: AUTO-SIM_000.000_000
preferred subpri index: 002
current fw version: 02.36.08.09
current carrier name: SIERRA
current config name: SIERRA_001.049_000
current subpri index: 002
I think you can try “FX30_WP77xx_full_R15.0.5.002_5145594a-sierra-SWI9X06Y_02.36.06.00.cwe”
switching to Sierra seemed to go down to an older firmware and profile. Both versions connected to the network in NA.
FROM
Firmware Version: SWI9X06Y_02.36.08.09 c094f4 jenkins 2022/06/24 03:14:28
TO
Firmware Version: SWI9X06Y_02.36.06.00 63d944 jenkins 2020/12/10 19:12:28
current fw version: 02.36.06.00
current config name: SIERRA_001.043_001
then you might need to wait for the official release of R15 including Sierra PRI in Source website
