I loaded the firmware (SWI9X15Y_07.12.09.00) from sierra wireless (source.sierrawireless.com/resou … rerelease/) to my Fx30s . However, the uart is not working.
I have /dev/ttyHS0 on the card and the uart setting is :
" AT!MAPUART?
!MAPUART: 17,0 "
When I send the data, there is no signal sent out. (I probed on the bus with Oscilloscope.)
It is working ok with the same setup when I loaded a costumed firmware.
Do I miss any set up when I load the formal release one?
Currently only version R13.1.2.004 is available which has a known issue with the serial port, but a new version, R13.1.3.001 will be posted in the next day or so.
For the MAPUART=17 setting, UART1 uses /dev/ttyHSL0, not /dev/ttyHS0
We eventually need to add extra packages to the image (python3 and some of the python3 modules). I find only the “linux OS source” that is to build SWI9X15Y_07.12.09.00 firmware from source.sierrawireless.com/resou … downloads/ . It is not the one for fx30 you pointed .
The logs you showed for the HSL drivers are normal when you have both UARTs disabled. If you need to use RS485 on UART1 then you need to run an AT command:
