WP7702-FX30S R15.1 missing /dev/ttyGS0
swi-fx30-catm_4.2.0 │ SDK for FX30-CATM (Release 15.1.0.004 + Legato 21.05.0)
at!usbcomp?
Config Index: 1
Config Type: 1 (Generic)
Interface bitmask: 0008014D (diag,nmea,modem,rmnet0,ecm,rawdat)
at!mapuart?
!MAPUART: 15,17
In previous releases /dev/ttyGS0 used to be there but now it is not, did something change in Yocto?
how about /dev/ttyGS1?
root@fx30:~# microcom /dev/ttyAT
ati3
Model: WP7702
Revision: SWI9X06Y_02.36.06.00 63d944 jenkins 2020/12/10 19:12:28
IMEI: 352653090612345
IMEI SV:  6
FSN: VU213430812345
+GCAP: +CGSM
ati8
Legato Ver: 19.11.5.a1621d58_27c4cd8552e17e79fdc3b0c91ff8bce9
Yocto Ver:  SWI9X06Y_02.36.08.00 2021-05-14_12:13:48
OS Ver: Linux version 3.18.140 (oe-user@oe-host) () #1 PREEMPT Fri May 14 11:13:23 UTC 2021
LK Ver: 1.3.0_9c047c35f7
RootFS Ver: SWI9X06Y_02.36.08.00 2021-05-14_12:13:48
UserFS Ver: unknown
MCU Ver: 002.015
at!entercnd="A710"
at!usbcomp?
Config Index: 1
root@fx30:~# ls /dev/ttyG*
/dev/ttyGS1
Thanks for your reply,
I don’t have any /dev/ttyG*
ati3
Model: FX30S(WP7702)
IMEI: 354723090332155
IMEI SV: 6
FSN: VU145400171210
+GCAP: +CGSM
ati8
Legato Ver: 21.05.0_7ce68b6acae153785e8d19e4069e5c0c
Yocto Ver: SWI9X06Y_03.00.13.00 2023-05-30_18:31:33
OS Ver: Linux version 4.14.253 (oe-user@oe-host) ( gcc version 9.3.0 (GCC), GNU ld (GNU Binutils) 2.34.0.20200220) #1 PREEMPT Fri May 26 18:30:22 UTC 2023
LK Ver: 1.3.0_1aea4d8ec8
RootFS Ver: SWI9X06Y_03.00.13.00 2023-05-30_18:31:33
UserFS Ver: unknown
MCU Ver: 002.015
at!entercnd=“A710”
at!usbcomp?
Config Index: 1
root@fx30s:~# ls /dev/ttyG*
ls: /dev/ttyG*: No such file or directory
root@fx30s:~# modprobe g_serial
modprobe: module g_serial not found in modules.dep
root@fx30s:~#
how about using FW 14.1?
Thanks, but that is not an option at this point.
It looks like linux 4.14 changed to use configfs for the usb_gadget,
/home/mango/m21/swi-linux-src/meta-swi-wp/meta-swi-wp/recipes-bsp/system-core/files/composition-sierra_dev
#!/bin/sh
Copyright (c) 2013, The Linux Foundation. All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of The Linux Foundation nor the names of its
contributors may be used to endorse or promote products derived from
this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED “AS IS” AND ANY EXPRESS OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE DISCLAIMED. IN NO
EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
DESCRIPTION: DIAG+ADB+ECM
configure_android_gadget()
local gadget_fs=/sys/class/android_usb/android${num}
#echo $mode > /sys/bus/platform/devices/usb_bam/enable
echo 0 > ${gadget_fs}/enable
echo $vid > ${gadget_fs}/idVendor
echo $pid > ${gadget_fs}/idProduct
echo $devclass > ${gadget_fs}/bDeviceClass
echo $devsubclass > ${gadget_fs}/bDeviceSubClass
echo $devprotocol > ${gadget_fs}/bDeviceProtocol
echo $diagstr > ${gadget_fs}/f_diag/clients
echo $serialstr > ${gadget_fs}/f_serial/transports
echo QTI,BAM_DMUX > ${gadget_fs}/f_rmnet/transports
echo BAM_DMUX > ${gadget_fs}/f_usb_mbim/mbim_transports
echo $compstr > ${gadget_fs}/functions
echo $remotewakeup > ${gadget_fs}/remote_wakeup
echo $manufacturer > ${gadget_fs}/iManufacturer
echo $product > ${gadget_fs}/iProduct
echo $serial > ${gadget_fs}/iSerial
compstr=`grep -w ffs ${gadget_fs}/functions || true`
if [[ $mode = "hsusb" && ! -z "$compstr" && -d ${gadget_fs}/f_ffs ]] ; then
    echo adb > ${gadget_fs}/f_ffs/aliases
fi
echo 1 > ${gadget_fs}/enable
configure_configfs_gadget()
local configfs_home=/sys/kernel/config/usb_gadget
local gadget_home=${configfs_home}/g$((num+1))
local strings_home=${gadget_home}/strings/0x409
local config_home=${gadget_home}/configs/c.$((num+1))
local cstring_home=${config_home}/strings/0x409
local gdev=ls -1 /sys/class/udc/
local supported=" serial:gser.0" " modem:cser.dun.0" " ecm:ecm.usb0" " ncm:ncm.ncm" " diag:diag.diag" " nmea:cser.nmea.1" " rmnet:rmnet_bam.rmnet_bam_dmux" " usb_mbim:mbim.mbim" " ffs:ffs.adb" " rawdat:cser.raw.2" " storage:mass_storage.0"
# Disable gadget in case it was enabled
if [ -w ${gadget_home}/UDC ]; then
    if [ ! -z `cat ${gadget_home}/UDC` ]; then
        echo "" > ${gadget_home}/UDC
    fi
fi
if [ ! -d ${configfs_home} ]; then
    mount none /sys/kernel/config -t configfs
    mkdir ${gadget_home}
fi
echo "0x$vid" > ${gadget_home}/idVendor
echo "0x$pid" > ${gadget_home}/idProduct
mkdir -p ${strings_home}
echo ${manufacturer} > ${strings_home}/manufacturer
echo ${product} > ${strings_home}/product
if [ -s "/etc/adb_devid" ] && [ "$( cat /etc/adb_devid )" != "" ]; then
    cat /etc/adb_devid > ${strings_home}/serialnumber
else
    serial_no=`egrep -o "androidboot\.serialno=[0-9a-fA-F]+" /proc/cmdline |cut -f2 -d=`
    if [ ! -z ${serial_no} ]; then
        echo $serial_no > ${strings_home}/serialnumber
    else
        cat /proc/sys/kernel/random/boot_id | cut -d- -f5 > ${strings_home}/serialnumber
    fi
    cat ${strings_home}/serialnumber > /etc/adb_devid
fi
mkdir -p ${config_home}
# Update bmAttributes if remotewakup enabled.
# Referring include/uapi/linux/usb/ch9.h,
# D7:     Reserved (set to one)
# D6:     Self-powered
# D5:     Remote Wakeup
# D4...0: Reserved (reset to zero)
[ $remotewakeup == "1" ] && echo 0xA0 > ${config_home}/bmAttributes
# Replace "serial" in compstr with the interface list (nmea, modem);
# Translate interface list into function names.
# smdnmea --> nmea
# smd     --> modem (if CMUX over USB disabled)
# tty     --> modem (if CMUX over USB enabled)
# rawdat  --> rawdat
local serialif=`echo "${serialstr}"| sed -r -e 's/smdnmea/nmea/g' -e 's/(smd|tty)/modem/g'`
# update compstr to replace "serial" with the interface list.
compstr="${compstr/serial/${serialif}}"
# Space separated list
complist=`echo ${compstr} | sed -e 's/,/ /g'`
# Clear and symlink gadget configuration files, build configuration string
cd ${gadget_home}
idx=0
configuration=""
rm -f configs/c.$((num+1))/f*
for comp in ${complist}; do
    match=`echo ${supported} | xargs -n1 | grep -i "${comp}"`
    if [ -n "${match}" ]; then
        idx=$((idx+1))
        func=`echo ${match} | cut -f 2 -d':'`
        name=`echo ${func} | cut -f 1 -d'.'`
        if [ ${idx} -eq 1 ]; then
            configuration="${name}"
        else
            configuration="${configuration}_${name}"
        fi
        mkdir -p functions/${func}
        ln -s functions/${func} configs/c.$((num+1))/f${idx}
    fi
done
cd
# Write configuration string
mkdir -p ${cstring_home}
echo "${configuration}" > ${cstring_home}/configuration
if echo "${compstr}" | grep -wq "ffs"; then
    # mount FunctionFS and start adb daemon
    mkdir -p /dev/usb-ffs/adb
    mount -o uid=2000,gid=2000 -t functionfs adb /dev/usb-ffs/adb
    mount -o remount,gid=5,mode=620 /dev/pts
    mkdir -p /system/bin 2>/dev/null && ln -s /bin/sh /system/bin/sh
    # change directory to root directory to align to msm-3.18 "adb shell" entry point
    cd /
    start-stop-daemon -S -b -a /sbin/adbd
    cd -
    sleep 1
fi
# Enable gadget
echo "${gdev}" > ${gadget_home}/UDC
set_frmnet_module_param()
local frmnet_module_param1=/sys/module/g_android/parameters/num_rmnet_swi
local frmnet_module_param2=/sys/module/usb_f_rmnet_bam/parameters/num_rmnet_swi
if [ -w "${frmnet_module_param1}" ]; then
    frmnet_module_param=${frmnet_module_param1}
elif [ -w "${frmnet_module_param2}" ]; then
    frmnet_module_param=${frmnet_module_param2}
else
    return
fi
numnet=$(/usr/bin/ud_getusbinfo NUMNET)
if [ $? -eq 0 ]; then
    echo $numnet > ${frmnet_module_param}
fi
echo “Switching to composition sierra_dev (1199:68C0)”
if [ “x$1” = “xy” ]; then
num=“1”
mode=“hsic”
else
num=“0”
mode=“hsusb”
fi
vid=$(/usr/bin/ud_getusbinfo VID)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets VID failed”
vid=1199
fi
pid=$(/usr/bin/ud_getusbinfo PID)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets PID failed”
pid=68C0
fi
devclass=$(/usr/bin/ud_getusbinfo DEVC)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets DEVC failed”
devclass=239
fi
devsubclass=$(/usr/bin/ud_getusbinfo DEVS)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets DEVS failed”
devsubclass=2
fi
devprotocol=$(/usr/bin/ud_getusbinfo DEVP)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets DEVP failed”
devprotocol=1
fi
diagstr=$(/usr/bin/ud_getusbinfo DIAGSTR)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets DIAGSTR failed”
diagstr=‘diag’
fi
serialstr=$(/usr/bin/ud_getusbinfo SERIALSTR)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets SERIALSTR failed”
serialstr=‘smd,tty’
fi
compstr=$(/usr/bin/ud_getusbinfo COMPSTR)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets COMPSTR failed”
compstr=‘diag,ffs,serial’
fi
filter out adb gadget if adbd is not installed
if [ ! -x /sbin/adbd ]; then
compstr=echo $compstr | sed -e s/^ffs,//g -e s/,ffs//g -e s/^ffs$//g
fi
remotewakeup=$(/usr/bin/ud_getusbinfo REM)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets REM failed”
remotewakeup=1
fi
manufacturer=$(/usr/bin/ud_getusbinfo MANU)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets MANU failed”
manufacturer=‘Sierra Wireless, Incorporated’
fi
product=$(/usr/bin/ud_getusbinfo PROD)
if [ $? -ne 0 ];
then
echo “ud_getusbinfo gets PROD failed”
product=‘AR758x’
fi
serial=$(/usr/bin/ud_getusbinfo SER)
if [[ $? -ne 0 || “${serial}” == “” ]];
then
echo “ud_getusbinfo gets SER failed or SN is blank”
serial=‘0123456789ABCDEF’
fi
Pass number of rmnets, to driver
Check if configfs gadget is supported and configure accordingly
configfs_g_support=zcat /proc/config.gz |grep CONFIG_USB_CONFIGFS=y
configfs_fs_support=zcat /proc/config.gz |grep CONFIG_CONFIGFS_FS=y
if [[ “x${configfs_g_support}” = “x” || “x${configfs_fs_support}” = “x” ]]
then
else
fi
root@fx30s:/dev# ls -ls
0 crw-rw---- 1 root root 235, 0 Dec 31 1969 android_mbim
0 crw-rw---- 1 root root 242, 5 Dec 31 1969 apr_apps2
0 crw-rw---- 1 root root 242, 3 Dec 31 1969 at_mdm0
0 crw-rw---- 1 root root 242, 4 Dec 31 1969 at_mdm1
0 crw-rw---- 1 root root 242, 6 Dec 31 1969 at_mdm2
0 crw-rw---- 1 root root 506, 1 Dec 31 1969 at_usb0
0 crw-rw---- 1 root root 506, 0 Dec 31 1969 at_usb1
0 crw-rw---- 1 root root 506, 2 Dec 31 1969 at_usb2
0 drwxr-xr-x 3 root root 60 Dec 31 1969 bus
0 crw------- 1 root root 5, 1 Dec 31 1969 console
0 crw-rw---- 1 root root 10, 59 Dec 31 1969 cpu_dma_latency
0 crw-rw---- 1 root root 241, 0 Dec 31 1969 diag
0 brw-rw---- 1 root root 254, 0 Dec 31 1969 dm-0
0 brw-rw---- 1 root root 254, 1 Dec 31 1969 dm-1
0 crw-rw---- 1 root root 236, 1 Dec 31 1969 dpl_ctrl
0 crw-rw-rw- 1 root root 1, 7 Dec 31 1969 full
0 crw-rw---- 1 root root 254, 0 Dec 31 1969 gpiochip0
0 crw-rw---- 1 root root 254, 4 Dec 31 1969 gpiochip4
0 crw-rw---- 1 root root 10, 183 Dec 31 1969 hwrng
0 crw-rw---- 1 root root 89, 4 Dec 31 1969 i2c-4
0 crw-rw---- 1 root root 248, 0 Dec 31 1969 iio:device0
0 prw------- 1 root root 0 Dec 31 1969 initctl
0 drwxr-xr-x 2 root root 60 Dec 31 1969 input
0 crw-rw-rw- 1 root root 10, 63 Dec 31 1969 ion
4 -rw-r–r-- 1 root root 2 May 30 09:40 ipa
0 crw-rw---- 1 root root 1, 11 Dec 31 1969 kmsg
0 srw-rw-rw- 1 root root 0 Dec 31 1969 log
0 crw-rw---- 1 root root 10, 237 Dec 31 1969 loop-control
0 brw-r----- 1 root disk 7, 0 Dec 31 1969 loop0
0 brw-r----- 1 root disk 7, 7 Dec 31 1969 loop7
0 drwxr-xr-x 2 root root 80 Dec 31 1969 mapper
0 crw-r----- 1 root kmem 1, 1 Dec 31 1969 mem
0 crw-rw---- 1 root root 10, 56 Dec 31 1969 memory_bandwidth
0 drwxrwxrwt 2 root root 40 Dec 31 1969 mqueue
0 crw-rw---- 1 root root 256, 0 Dec 31 1969 msm-rng
0 crw-rw---- 1 root root 10, 54 May 30 09:40 msm_audio_cal
0 crw-rw---- 1 root root 10, 53 May 30 09:40 msm_rtac
0 crw-rw---- 1 root root 253, 0 Dec 31 1969 msm_sps
0 crw-rw---- 1 root root 90, 0 Dec 31 1969 mtd0
0 crw-rw---- 1 root root 90, 19 Dec 31 1969 mtd9ro
0 brw-rw---- 1 root root 31, 0 Dec 31 1969 mtdblock0
0 brw-rw---- 1 root root 31, 9 Dec 31 1969 mtdblock9
0 drwxr-xr-x 2 root root 60 Dec 31 1969 net
0 crw-rw---- 1 root root 10, 58 Dec 31 1969 network_latency
0 crw-rw---- 1 root root 10, 57 Dec 31 1969 network_throughput
0 prw-rw-rw- 1 root root 0 May 31 08:45 nmea
0 crw-rw-rw- 1 root root 1, 3 Dec 31 1969 null
0 crw-rw---- 1 root root 108, 0 Dec 31 1969 ppp
0 crw-rw---- 1 root root 249, 0 Dec 31 1969 pps0
0 crw-rw-rw- 1 root tty 5, 2 May 31 11:48 ptmx
0 drwxr-xr-x 2 root root 0 Dec 31 1969 pts
0 crw-rw---- 1 root root 2, 176 Dec 31 1969 ptya0
0 crw-rw---- 1 root root 2, 175 Dec 31 1969 ptyzf
0 brw-r----- 1 root disk 1, 0 Dec 31 1969 ram0
0 brw-r----- 1 root disk 1, 9 Dec 31 1969 ram9
0 crw-rw---- 1 root root 245, 1 Dec 31 1969 ramdump_microdump_modem
0 crw-rw---- 1 root root 245, 0 Dec 31 1969 ramdump_modem
0 crw-rw-rw- 1 root root 1, 8 Dec 31 1969 random
0 prw–w---- 1 root rebooter 0 May 31 08:45 rebooterdev
0 crw-rw---- 1 root root 236, 0 Dec 31 1969 rmnet_ctrl
0 lrwxrwxrwx 1 root root 9 Dec 31 1969 root → gpiochip0
0 crw-rw---- 1 root root 250, 0 Dec 31 1969 rtc0
0 drwxrwxrwx 2 root root 40 Dec 31 1969 shm
0 crw-rw---- 1 root root 10, 62 Dec 31 1969 sierra_smem
0 crw-rw---- 1 root root 10, 61 Dec 31 1969 sierra_ssmem
0 crw-rw---- 1 root root 242, 8 Dec 31 1969 smd10
0 crw-rw---- 1 root root 242, 10 Dec 31 1969 smd11
0 crw-rw---- 1 root root 242, 11 Dec 31 1969 smd21
0 crw-rw---- 1 root root 242, 1 Dec 31 1969 smd22
0 crw-rw---- 1 root root 242, 7 Dec 31 1969 smd7
0 crw-rw---- 1 root root 242, 9 Dec 31 1969 smd8
0 crw-rw---- 1 root root 242, 12 Dec 31 1969 smd_pkt_loopback
0 crw-rw---- 1 root root 242, 0 Dec 31 1969 smdcntl0
0 crw-rw---- 1 root root 242, 2 Dec 31 1969 smdcntl8
0 drwxr-xr-x 2 root root 1140 May 30 09:40 snd
0 crw-rw---- 1 root root 246, 0 Dec 31 1969 subsys_modem
0 crw-rw-rw- 1 root tty 5, 0 Dec 31 1969 tty
0 lrwxrwxrwx 1 root root 9 Dec 31 1969 ttyAT → /dev/smd8
0 crw-rw---- 1 root dialout 243, 0 Dec 31 1969 ttyHS0
0 crw------- 1 root root 243, 1 Dec 31 1969 ttyHS1
0 crw-rw-rw- 1 root tty 3, 175 Dec 31 1969 ttyzf
0 crw-rw---- 1 root root 10, 60 Dec 31 1969 tzdev
0 crw-rw---- 1 root root 511, 0 Dec 31 1969 ubi0
0 crw-rw---- 1 root root 508, 1 Dec 31 1969 ubi4_0
0 crw-rw---- 1 root root 10, 55 Dec 31 1969 ubi_ctrl
0 brw-rw---- 1 root root 253, 0 Dec 31 1969 ubiblock0_0
0 brw-rw---- 1 root root 253, 3 Dec 31 1969 ubiblock2_1
0 crw-rw---- 1 root root 10, 223 Dec 31 1969 uinput
0 crw-rw-rw- 1 root root 1, 9 Dec 31 1969 urandom
0 crw-rw---- 1 root root 239, 0 Dec 31 1969 usbmon0
0 crw-rw---- 1 root root 239, 1 Dec 31 1969 usbmon1
0 crw-rw---- 1 root tty 7, 0 Dec 31 1969 vcs
0 crw-rw---- 1 root tty 7, 1 Dec 31 1969 vcs1
0 crw-rw---- 1 root tty 7, 128 Dec 31 1969 vcsa
0 crw-rw---- 1 root tty 7, 129 Dec 31 1969 vcsa1
0 crw-rw-rw- 1 root root 1, 5 Dec 31 1969 zero
I have not figured out what the script is actually doing ?
but this seems to be where the configuration takes place?
It seems that at_usb2 is the same as ttyGS0
on the Ubuntu host /dev/ttyUSB3 receives from WP7702 /dev/at_usb2
echo -e “HELLO” > /dev/at_usb2
That is fine by me to use /dev/at_usb2 instead of /dev/ttyGS0,
but is there any documentation describing how all this relates?
I don’t see any information regarding this in here:
But I think you can use /dev/at_usb2 for the raw data port.
/dev/at_usb2 seems to be working.
I still have /dev/ttyHS0 and /dev/ttyHS1 even though the guide says ttyMSMx ?
are you using UART in data mode?
I don’t see /dev/ttyHS port in WP77 R15:
ati8
Legato Ver: 21.05.0_0e0fd5f3fc5f6169e2516f22304da11c
Yocto Ver:  SWI9X06Y_03.00.13.00 2022-12-27_09:10:00
OS Ver: Linux version 4.14.253 (oe-user@oe-host) ( gcc version 9.3.0 (GCC), GNU ld (GNU Binutils) 2.34.0.20200220) #1 PREEMPT Tue Dec 27 08:09:00 UTC 2022
LK Ver: SWI9X06Y_03.00.13.00
RootFS Ver: SWI9X06Y_03.00.13.00 2022-12-27_09:10:00
UserFS Ver: unknown
MCU Ver: 002.015
ati3
Model: WP7702
Revision: SWI9X06Y_02.36.08.09 c094f4 jenkins 2022/06/24 03:14:28
IMEI SV:  8
FSN: VU213430812345
+GCAP: +CGSM
at!mapuart?
!MAPUART: 15,16
root@fx30:~# ls /dev/ttyH*
ls: /dev/ttyH*: No such file or directory
root@fx30:~# ls /dev/ttyM*
/dev/ttyMSM1
ati8
Legato Ver: 21.05.0_90ad1cb36b659e0fdb3937a52fc7f920
UserFS Ver: unknown
MCU Ver: 002.015
ati3
IMEI SV: 6
FSN: VU145400171210
+GCAP: +CGSM
at!mapuart?
!MAPUART: 15,17
I am using ATT firmware
Not sure what you mean by UART in data mode?
Does your project need to use uart?
Yes it is using both of them and it works fine with the ttyHSx i was just wondering why it is not ttyMSMx as the documentation says?
I don’t see problem.
you can use the FW here:
https://source.sierrawireless.com/resources/airlink/software_downloads/fx30-firmware/fx30-firmware-catm/#sthash.1fK4jcLN.dpbs
/dev/ttyMSM1
ati3
Model: WP7702
IMEI SV:  6
FSN: VU213430812345
+GCAP: +CGSM
ati8
Legato Ver: 21.05.0.54b96444_0a6e18078edde5151619cb964564694d
Yocto Ver:  SWI9X06Y_03.00.13.00 2022-12-28_08:23:43
OS Ver: Linux version 4.14.253 (oe-user@oe-host) ( gcc version 9.3.0 (GCC), GNU ld (GNU Binutils) 2.34.0.20200220) #1 PREEMPT Wed Dec 28 07:40:21 UTC 2022
RootFS Ver: SWI9X06Y_03.00.13.00 2022-12-28_08:23:43
UserFS Ver: unknown
MCU Ver: 002.015
at!mapuart?
!MAPUART: 15,16
root@fx30:~# ^C
at!impref?
!IMPREF:
 preferred fw version:    02.36.06.00
 preferred carrier name:  ATT
 preferred config name:   ATT_001.067_005
 preferred subpri index:  000
 current fw version:      02.36.06.00
 current carrier name:    ATT
 current config name:     ATT_001.067_005
 current subpri index:    000
