FX30(WP7607-1) eth0 missing, bricked?
First time with this FX30, Was attempting to get the FX30 to be on a fresh state to re flash my firmware.
Messed around and tried a couple of things like AT!RMARESET=OEM and rm -rf /data/*. Thinking factory reset would bring everything back to default if i messed up.
Now I’m only able to see 192.168.2.2 on ecm0 but eth0 is non existence now with the 192.168.13.31.
Appreciate any help!
From the user guide, there is a page showing how to do factory reset:
you can see here on how to erase the userapp partition:
You can also upgrade the firmware and see if there is any improvement:
https://source.sierrawireless.com/resources/airlink/software_downloads/fx30-firmware/fx30-firmware-cat1/#sthash.SZNpDhzT.dpbs
Hello, thanks for the quick feedback,
Factory reset wouldn’t bring the eth0 up as well. I tried a couple of times.
also I tried to update the firmware with AT!BOOTHOLD but this was what I get
from the release note, it shows how to upgrade firmware:
Awesome. I didn’t catch this. let me give it a try
do i copy it on /tmp? when its about done the connection just hangs and i have to reset the modem for it to come back alive again. I think its having not enough space
yes , you can copy to /tmp folder
i tried twice, and it failed when the transfer bar turns full green
How about transfer to /home/root ?
You might also check “df -h” for the storage space
am i doing df -h right?
looks like tmp has 76.2M should be able to take the 66M+ file
Yes, should be enough
/home/root is also big enough
ok i try again on home/root/ now
ok it managed to stick this time!
Session all ended and I’m hoping it comes back
Am I doing it right?
after more than 30mins its not coming back, I gave up and did a AT!RESET after that a AT!RMARESET=1
Now its back! really not sure what happened there but thank you so much!! :slight_smile:
