Hello All.
for my application I need to apply set some metadata parameters of the device (known as “custom properties” in the Octave dashboard) for the device that was already provisioned before.
From Octave API docs I found it is only possible doing so using Bulk Provision Device API call. If I do that on previously provisioned device I get Error 400 stating “Device already exists in Octave”.
Is there any other way to set metadata rather than removing the device and re-provisioning it using Bulk Provision Device?
For instance, since I can set this Azure device ID from the Octave dashboard (see picture) it means there’s some API function which allows doing so
Thanks.
