My host PC environment is Windows running my dev environment under VirtualBox.
I would like to reflash the Fx30 with a clean image but swiflash is not working from a VM.
I cannot make use of “fwupdate” since my device is currently not reaching a stable state where I could have an SSH.
Would you have an EXE version of an official Fx30 firmware?
Or the windows equivalent for swiflash?
In this case, I cannot make use of scp to connect to my Fx30.
Loading the WPX5 image I mentioned earlier (WP85xx & WP75xx Firmware Packages - Release 14) is not helping as the USER1 seems to be not erased. So the faulty password remains.
I have to say that I already have loaded the “WP85xx & WP75xx Firmware Packages - Release 14” firmware… so the “reset to factory” (erasing USER1) pressing the external push button does not work.
I would need and EXE image I could run from Windows which would erase the USER1. Can you point me to such image?
Try doing a factory reset, but you’ll need the FX30 firmware installed. Be aware that you’ll lose any customizations you’ve made to /etc or files store in ~
Unplug the FX30
Press and hold the reset button (there’s a little hole beside the power connector)
