Fwupdate command is missing in yocto_wp76xx.4k.cwe binary
Hi Jyijyi,
I have downloaded Release 16 and compiled. And i installed build_bin/tmp/deploy/images/swi-mdm9x28-wp/yocto_wp76xx.4k.cwe into our custom target. The fwupdate command is missing. How can i include fwupdate command in yocto_wp76xx.4k.cwe binary?
Raghavan.
Fwupdate command is in legato.cwe, not in yocto image.
BTW, the default R16 should have the fwupdate:
root@swi-mdm9x28-wp:~# cm info
Device:                        WP7609
IMEI:                          359782080100399
IMEISV:                        E
FSN:                           WA803370010610
Firmware Version:              SWI9X07Y_02.37.03.00 73df45 jenkins 2020/04/08 10:59:14
Bootloader Version:            SWI9X07Y_02.37.03.00 73df45 jenkins 2020/04/08 10:59:14
MCU Version:                   002.015
PRI Part Number (PN):          9908102
PRI Revision:                  001.000
Carrier PRI Name:              GENERIC
Carrier PRI Revision:          002.095_000
SKU:                           1103843
Last Reset Cause:              Power Down
Resets Count:                  Expected: 132    Unexpected: 242
root@swi-mdm9x28-wp:~# fwupdate -h
Invalid command '-h'
NAME:
    fwupdate - Download or Query modem firmware
SYNOPSIS:
    fwupdate help
    fwupdate downloadOnly FILE
    fwupdate query
    fwupdate install
    fwupdate checkStatus
    fwupdate markGood
    fwupdate download FILE
DESCRIPTION:
    fwupdate help
      - Print this help message and exit
    fwupdate query
      - Query the current firmware version. This includes the modem firmware version, the
        bootloader version, and the linux kernel version.
        This can be used after a download and modem reset, to confirm the firmware version.
      - Download the given CWE file; if '-' is given as the FILE, then use stdin.
        Waits for another command after a successful download.
      - Check the status of the downloaded package (DualSys platform only)
    fwupdate install
      - Install the downloaded firmware.
        Single System: Trigger reset to initiate install.
        Dual System: Swap and reset to run the downloaded firmware or go back to the old system
        if the running system is not marked good.
    fwupdate markGood
      - Mark good the current system (DualSys platform only)
      - do download, install and markGood in one time
        After a successful download, the modem will reset
