The following documents have processes or procedure that are either outdated or incomplete. These documents form the basis of your board support package and must be updated
(see prior comment about boot- images being disabled)
The secure boot document references the boot- images so again, this need to be edited to reflect the change and a new procedure must be written (the little kernel is packaged separately in appsboot*.cwe images; how are the keys updated their as well )
Steps like the following are unacceptable as even the referenced file is uncommented. Package the signed images into CWE images. For details, refer to the following script in the build system output – meta-swi/meta-swi-mdm9x28/recipes-core/images/mdm9x28-image-cwe.inc.
The overall feedback is that these guides should show commands and expected outputs for all steps.
How did you make the image that needed to be signed ( download the R16, extract, type make wp77xx, etc.)
Insecure and Improper Release channel
A random forum comment is not where you should have a Secure Boot document
Anyone can attach a docx file in this forum with wrong instructions in an attempt to subvert the security we are trying to implement.
Developers should not have to fish in forums to find critical information
Version Compatibility Updates
You don’t need to rewrite the guide, but you should mention somewhere that these steps work with release WP77XX R15 and WP76XX R17, especially because you jumped major revisions for the Linux kernel (4.14) and yocto environments (3.1) since the guide was released. I see a lot of commits in meta-swi regarding signing since WP76XX R16 as well.
Regarding the other forum post, basically the same points:
Forum is not an acceptable critical documentation release channel
If you used COTs tools, like Docker and Yocto, as they were intended (IE: inheritance mechanisms) you would have to document significantly less
Until then, you need to formally document all steps. You can’t bait my managers with official documentation with Sierra letterhead and then switch it out for random word documents in a forum.
