I downloaded SWI9X06Y_02.22.12.00 Source
and compiled it, but I got error.
Log is below"
WARNING: Unable to get checksum for linux-quic SRC_URI entry sierra: [Errno 2] No such file or directory: '/home/test/workspace/yocto/kernel/./arch/arm/mach-msm/sierra/sierra' | ETA: 0:00:06
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:11
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: android-signing-native-1.0-r1 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-WGYkBrfTN3"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/test/workspace/yocto/poky/scripts/native-intercept:/home/test/workspace/yocto/build_bin/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/test/workspace/yocto/poky/scripts:/home/test/workspace/yocto/build_bin/tmp/sysroots/x86_64-linux/usr/bin/x86_64-linux:/home/test/workspace/yocto/build_bin/tmp/sysroots/x86_64-linux/usr/bin:/home/test/workspace/yocto/build_bin/tmp/sysroots/x86_64-linux/usr/sbin:/home/test/workspace/yocto/build_bin/tmp/sysroots/x86_64-linux/usr/bin:/home/test/workspace/yocto/build_bin/tmp/sysroots/x86_64-linux/sbin:/home/test/workspace/yocto/build_bin/tmp/sysroots/x86_64-linux/bin:/home/test/workspace/yocto/poky/scripts:/home/test/workspace/yocto/poky/bitbake/bin:/usr/local/bin:/bin:/usr/bin"; export HOME="/home/test"; git -c core.fsyncobjectfiles=0 ls-remote git://github.com/braddu/android-signing.git failed with exit code 128, output:
fatal: unable to connect to github.com:
github.com[0: 20.27.177.113]: errno=Connection refused
ERROR: android-signing-native-1.0-r1 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/test/workspace/yocto/build_bin/tmp/work/x86_64-linux/android-signing-native/1.0-r1/temp/log.do_fetch.64354
ERROR: Task (/home/test/workspace/yocto/meta-swi/meta-swi-mdm9xxx/recipes-bsp/android-signing/android-signing-native.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 748 tasks of which 714 didn't need to be rerun and 1 failed.
How can I fix it?
I think error is in here.
Thanks!!!
Hi @jyijyi ,
Thanks for your help.
I modify android-signing-native.bb file and let it use https and it worked.
Hi @jyijyi ,
I got other problem
WARNING: Unable to get checksum for linux-quic SRC_URI entry sierra: [Errno 2] No such file or directory: '/home/test/workspace/yocto/kernel/./arch/arm/mach-msm/sierra/sierra' | ETA: 0:00:07
ERROR: linux-quic-3.18.44-r1 do_populate_sysroot: runstrip: ''arm-poky-linux-gnueabi-strip' --remove-section=.comment --remove-section=.note '/home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/sysroot-destdir/usr/src/kernel/scripts/basic/fixdep'' strip command failed with 1 (b'arm-poky-linux-gnueabi-strip:/home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/sysroot-destdir/usr/src/kernel/scripts/basic/fixdep: File format not recognized\n')
ERROR: linux-quic-3.18.44-r1 do_populate_sysroot: runstrip: ''arm-poky-linux-gnueabi-strip' --remove-section=.comment --remove-section=.note '/home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/sysroot-destdir/usr/src/kernel/scripts/kconfig/mconf'' strip command failed with 1 (b'arm-poky-linux-gnueabi-strip:/home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/sysroot-destdir/usr/src/kernel/scripts/kconfig/mconf: File format not recognized\n')
ERROR: linux-quic-3.18.44-r1 do_package: objcopy failed with exit code 1 (cmd was 'arm-poky-linux-gnueabi-objcopy' --only-keep-debug '/home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/package/usr/src/kernel/scripts/basic/fixdep' '/home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/package/usr/src/kernel/scripts/basic/.debug/fixdep'):
arm-poky-linux-gnueabi-objcopy:/home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/package/usr/src/kernel/scripts/basic/fixdep: File format not recognized
ERROR: linux-quic-3.18.44-r1 do_package: Function failed: split_and_strip_files
ERROR: Logfile of failure stored in: /home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/temp/log.do_package.100943
ERROR: Task (/home/test/workspace/yocto/meta-swi/meta-swi-mdm9x28/recipes-kernel/linux/linux-quic_git.bb:do_package) failed with exit code '1'
What does it mean “File format not recognized” ?
Hi @jyijyi ,
my build information is below:
Build Configuration:
BB_VERSION = "1.32.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "arm-poky-linux-gnueabi"
MACHINE = "swi-mdm9x28-wp"
DISTRO = "poky-swi-ext"
DISTRO_VERSION = "2.2.3"
TUNE_FEATURES = "arm armv7a vfp neon"
TARGET_FPU = "softfp"
meta
meta-poky
meta-yocto-bsp = "HEAD:e6aadcc2a04ae4e85b1cb00c5c9ce1c0f76ee871"
meta-python
meta-networking
meta-oe = "HEAD:b40116cf457b88a2db14b86fda9627fb34d56ae6"
common = "HEAD:d29b389387fb0c5a12c8f8285f31bc89418a734f"
meta-fortune = "HEAD:b40116cf457b88a2db14b86fda9627fb34d56ae6"
meta-swi-mdm9xxx
meta-swi-mdm9x28 = "HEAD:d29b389387fb0c5a12c8f8285f31bc89418a734f"
meta-swi-mdm9xxx-bin
meta-swi-mdm9x28-bin
meta-swi-mdm9x28-wp-bin
meta-swi-mdm9x28
common = "HEAD:4f585ea5a8949b79b566860a667d1f082aafeec0"
If you want me use R16 version I need more time.
By the way the system I already compiled before I do make clean.
You mean for WP77 yocto build? Can you build now?
Hi @jyijyi ,
I built WP77 before I do make clean.
But now I can’t build success, so I don’t know why.
didn’t you should
make clean and then build wp77?
Hi @jyijyi ,
I don’t understand why I didn’t should make clean or I should make clean again ?
then execute make MACH=mdm9x28 PROD=wp ?
didn’t you are compiling the wp77 yocto source? OR FX30?
For WP77, you can try:
make clean
make
Hi @jyijyi ,
I use two computer to build WP77 and FX30.
In FX30 I need set github do you know how to setup it?
In WP77 I do make clean then make image_bin now.
Hi @jyijyi
In FX30 I got the same error
Something went wrong when trying to connect to ssh://git@github.com/legatoproject/manifest
does this help to set it to http?
larry1:
rying
Hi @jyijyi ,
I use “leaf getsrc legato” where can I modify it ?
Hi @jyijyi ,
In WP77 I try again and got the same error
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:02:04
ERROR: linux-quic-3.18.44-r1 do_package: objcopy failed with exit code 1 (cmd was 'arm-poky-linux-gnueabi-objcopy' --only-keep-debug '/home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/package/usr/src/kernel/scripts/kconfig/mconf' '/home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/package/usr/src/kernel/scripts/kconfig/.debug/mconf'):
arm-poky-linux-gnueabi-objcopy:/home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/package/usr/src/kernel/scripts/kconfig/mconf: File format not recognized
ERROR: Logfile of failure stored in: /home/test/workspace/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/linux-quic/3.18.44-r1/temp/log.do_package.83191
NOTE: Tasks Summary: Attempted 942 tasks of which 0 didn't need to be rerun and 1 failed.
How do I fix it ?
I have no idea to fix it.
you can try with WP76 FW16.0.1 yocto build and see if it has problem.
this is to make sure your PC is OK to build image.
if you just wanna get the legato source, you can use VSCode+LEAF plugin to download
larry1
May 9, 2023, 12:46am
20
Hi @jyijyi ,
Following your suggestion use R16.0.1 in WP76xx, I got many like the error
ERROR: dtbtool-native-git-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/home/test/workspace/yocto/poky/scripts/native-intercept:/home/test/workspace/yocto/build_bin/tmp/sysroots-uninative/i686-linux/usr/bin:/home/test/workspace/yocto/poky/scripts:/home/test/workspace/yocto/build_bin/tmp/work/i686-linux/dtbtool-native/git-r0/recipe-sysroot-native/usr/bin/i686-linux:/home/test/workspace/yocto/build_bin/tmp/work/i686-linux/dtbtool-native/git-r0/recipe-sysroot-native/usr/bin:/home/test/workspace/yocto/build_bin/tmp/work/i686-linux/dtbtool-native/git-r0/recipe-sysroot-native/usr/sbin:/home/test/workspace/yocto/build_bin/tmp/work/i686-linux/dtbtool-native/git-r0/recipe-sysroot-native/usr/bin:/home/test/workspace/yocto/build_bin/tmp/work/i686-linux/dtbtool-native/git-r0/recipe-sysroot-native/sbin:/home/test/workspace/yocto/build_bin/tmp/work/i686-linux/dtbtool-native/git-r0/recipe-sysroot-native/bin:/home/test/workspace/yocto/poky/bitbake/bin:/home/test/workspace/yocto/build_bin/tmp/hosttools"; export HOME="/home/test"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror https://codeaurora.org/device/qcom/common /home/test/workspace/yocto/build_bin/downloads/git2/codeaurora.org.device.qcom.common --progress failed with exit code 128, output:
Cloning into bare repository '/home/test/workspace/yocto/build_bin/downloads/git2/codeaurora.org.device.qcom.common'...
fatal: unable to access 'https://codeaurora.org/device/qcom/common/': server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
ERROR: dtbtool-native-git-r0 do_fetch: Fetcher failure for URL: 'git://codeaurora.org/device/qcom/common;branch=jb_rb5.1;protocol=https'. Unable to fetch URL from any source.
ERROR: dtbtool-native-git-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/test/workspace/yocto/build_bin/tmp/work/i686-linux/dtbtool-native/git-r0/temp/log.do_fetch.22324
ERROR: Task (/home/test/workspace/yocto/meta-swi/meta-swi-mdm9x28/recipes-bsp/dtbtool/dtbtool-native_git.bb:do_fetch) failed with exit code '1'
and I added “protocol=https” It seems the same how to I solve it ?
BTW I also got many WARNING like below:
Now at patch 0001-Adding-MDM-specific-code-under-_PLATFORM_MDM_.patch
WARNING: wpa-supplicant-2.6-r0 do_patch:
Some of the context lines in patches were ignored. This can lead to incorrectly applied patches.
The context lines in the patches can be updated with devtool:
devtool modify <recipe>
devtool finish --force-patch-refresh <recipe> <layer_path>
Then the updated patches and the source tree (in devtool's workspace)
should be reviewed to make sure the patches apply in the correct place
and don't introduce duplicate lines (which can, and does happen
when some of the context is ignored). Further information:
http://lists.openembedded.org/pipermail/openembedded-core/2018-March/148675.html
https://bugzilla.yoctoproject.org/show_bug.cgi?id=10450
Does this make any difference?
