Hi @claudio.baldini,
I’ve pulled and built the swi-fx30-catm_2.0.0 and it runs without issue. I’m using a Ubuntu 16.04 machine, but 18.04 should be fine as well.
Here is the procedure I used:
Create a workspace folder:
$ mkdir leaf-fx30-catm_2.0.0
$ cd leaf-fx30-catm_2.0.0
Initialize the workspace for Leaf
$ leaf init
Setup the workspace
$ leaf setup -p swi-fx30-catm_2.0.0
Pull the yocto workspace
$ leaf getsrc swi-linux
Edit the FX30 Makefile
$ cd swi-linux-src/
$ vi Makefile
Modify the Makefile to change pulling Legato from gerrit.legato.io to github:
Original:
$ repo init -u ssh://${LEAF_GERRIT_USER}@gerrit.legato.io:29418/manifest \
New:
$ repo init -u ssh://git@github.com/legatoproject/manifest \
Execute make to pull the Legato source code, but do not build the entire workspace
$ make
Once the Legato source code has been pulled, the yocto build will start. Cancel the build by pressing:
$ ctrl-c
Copy the Legato proprietary binaries from the leaf-data metadata to the Legato source folder
$ cd…
$ cp -r ./leaf-data/current/fx30-catm-legato/apps/proprietary ./legato-src-fx30-catm/legato/apps/
Confirm the proprietary folder is present
$ ls legato-src-fx30-catm/legato/apps/
Perform a clean, and then build the image
$ cd swi-linux-src/
$ make clean
$ make
BR,
Chris
