FTP wip_getFile Problem
Hi there,
i got a strange problem trying to download a file from FTP.
After connecting to GPRS, connecting to FTP and trying to download a file I receive a WIP_CERR_CSTATE error.
This sees strange to me, because i am waiting for all appropriate events.
Here’s my code:
After being connectd to GPRS (WIP_BEV_IP_CONNECTED), open FTP communication channel:
void SOCK_FTP_hdl_c(wip_event_t *event, void *context)
    ftp_channel_c = event->channel;
    switch(event->kind)
        case WIP_CEV_OPEN:
            TRACE((TL_SOCK, "SOCK_FTP_hdl_c(): WIP_CEV_OPEN"));
            wip_getFileSize(ftp_channel_c, "test.php");
        break;
        case WIP_CEV_DONE:
            TRACE((TL_SOCK, "SOCK_FTP_hdl_c(): WIP_CEV_DONE"));
            //START DOWNLOADING HERE
            break;
Now wip_getFile:
ftp_channel_d = wip_getFile(ftp_channel_c, "test.php", FTP_hdl_d, "");
Now in the handler for this channel (FTP_hdl_d):
void DOTA_FTP_hdl_d(wip_event_t *event, void *context)
    ftp_channel_d = event->channel;
    switch(event->kind)
        case WIP_CEV_OPEN:
            TRACE((TL_DOTA, "DOTA_FTP_hdl_d(): WIP_CEV_OPEN"));
            break;
        case WIP_CEV_WRITE:
            TRACE((TL_DOTA, "DOTA_FTP_hdl_d(): WIP_CEV_WRITE"));
            break;
        case WIP_CEV_READ:
            TRACE((TL_DOTA, "DOTA_FTP_hdl_d() %d bytes readable", event->content.read.readable));
            //read file
            u32 nread;
            u8 buf[256];
            while ( (nread = wip_read(ftp_channel_d,buffer, sizeof(buffer)-1)) > 0)
So in my Trace, everything is normal, until the data channel for FTP is opened. Then I receive the WIP_CEV_OPEN, the WIP_CEV_WRITE and after this i get error -999 (WIP_CERR_CSTATE).
Strange: If I remove the while statement around the wip_read function, the error does not happen…
Any ideas?
  • What function returns you this error?
  • Are you sure you get a WIP_CEV_WRITE when you try to read a file?
  • You do a getFileSize(); do you wait for the response before attempting a getFile()?
Hmm - sees your last question was the key.
I am now waiting for the WIP_CEV_DONE in the comm channel for the result of the filesize (event->content.done.aux).
After that creating the data channel with wip_getfile and receiving bytes works quite fine:
nread += wip_read(ftp_channel_d, FTP_file_buffer+nread, FTP_bufsize-nread);
Anyway - thanks for your reply!
