Hello there,
I’m developing an application with the M2M example “ftp_put” and I set up all the parameters and it works great. What I’m trying to do now, is to make this “upload process” to be cyclic, I want to upload i.e. the same file every hour but with different information in it, that’s why I want to make it cyclic.
For now I’m just working on the cyclic part, when I get it, I’ll see through the file information/name stuff.
Here’s mi code…
/* appli.c - Copyright Wavecom S.A. (c) 2006 */
/* DISCLAIMER OF WARRANTY */
/* This Software is provided free of charge on an 'as is' basis. No warranty */
/* is given by Wavecom S.A. in relation to the Software of the uses to which */
/* it may be put by you, the user, or its merchantability, fitness or */
/* suitability for any particular purpose or conditions; and/or that the use */
/* of the Software and all documentation relating thereto by the Licensee */
/* will not infringe any third party copyright or other intellectual property*/
/* rights. Wavecom S.A. shall furthermore be under no obligation */
/* to provide support of any nature for the Software and the Documentation. */
/* LIMIT OF LIABILITY */
/* In no event shall Wavecom S.A. be liable for any loss or damages */
/* whatsoever or howsoever caused arising directly or indirectly in */
/* connection with this licence, the Software, its use or otherwise except to*/
/* the extent that such liability may not be lawfully excluded. */
/* Notwithstanding the generality of the foregoing, Wavecom S.A. expressly */
/* excludes liability for indirect, special, incidental or consequential loss*/
/* or damage which may arise in respect of the Software or its use, or in */
/* respect of other equipment or property, or for loss of profit, business, */
/* revenue, goodwill or anticipated savings. */
/* File : appli.c
* This is the main ADL entry point:
* Before WIP application appli_entry_point() is called, any or none
* of the flags could be activated for a bearer type configuration:
* The TCP/IP stack will be initialized over a :
* [OVER_UART_PPP_SERV]: PPP UART server connection mode
* [OVER_UART_PPP_CLIENT]: PPP UART client connection mode
* [OVER_GSM_PPP_SERV]: PPP GSM DATA server connection mode
* [OVER_GSM_PPP_CLIENT]: PPP GSM DATA client connection mode
* [OVER_GPRS]: GPRS connection mode
* Date | Author | Revision | Description
* 22.05.06 | FFT | 1.0 | Initial revision.
* 24.07.06 | RFN | | Increased wm_apmCustomStackSize
* | | | for compiling with ARM
* 24.10.06 | APH | | Added the GSM bearers
#include "adl_global.h"
#include "wip.h"
/* Defines */
* Activate any or none of the concerned following
* flags for the proper case configuration.
//#define OVER_UART_PPP_SERV
//#define OVER_UART_PPP_CLIENT
//#define OVER_GSM_PPP_SERV
//#define OVER_GSM_PPP_CLIENT
//#define OVER_ETHERNET
#define OVER_GPRS
/* Prototypes */
void cfg_uart_ppp_client( void (*entry_point) (void));
void cfg_uart_ppp_serv ( void (*entry_point) (void));
void cfg_gsm_ppp_client ( void (*entry_point) (void));
void cfg_gsm_ppp_serv ( void (*entry_point) (void));
void cfg_gprs ( void (*entry_point) (void));
void cfg_eth ( void (*entry_point) (void));
void appli_entry_point ( void);
/* Mandatory variables */
/* wm_apmCustomStackSize */
#ifdef OVER_ETHERNET
const u16 wm_apmCustomStackSize = 8192;
/* Ethernet driver uses high level interrupt handler */
const u32 wm_apmIRQLowLevelStackSize = 1024;
const u32 wm_apmIRQHighLevelStackSize = 1024;
#elif __OAT_API_VERSION__ >= 400
const u16 wm_apmCustomStackSize = 4096;
#else
u32 wm_apmCustomStack[1024];
const u16 wm_apmCustomStackSize = sizeof(wm_apmCustomStack);
#endif
void my_function(u8 ID, void * Context){
int r;
TRACE (( 1, "Embedded Application : Main" ));
/* Initialize the stack */
r = wip_netInitOpts(
WIP_NET_OPT_DEBUG_PORT, WIP_NET_DEBUG_PORT_UART1, /* WIP traces on UART1 */
//WIP_NET_OPT_DEBUG_PORT, WIP_NET_DEBUG_PORT_UART2,
//WIP_NET_OPT_DEBUG_PORT, WIP_NET_DEBUG_PORT_TRACE,
WIP_NET_OPT_END);
/* Depending on the activated flag, take the proper config */
#if defined( OVER_UART_PPP_SERV)
/* Initialize PPP server over UART */
cfg_uart_ppp_serv( appli_entry_point);
#elif defined( OVER_UART_PPP_CLIENT)
/* Initialize PPP client over UART */
cfg_uart_ppp_client( appli_entry_point);
#elif defined( OVER_GSM_PPP_SERV)
/* Initialize PPP server over GSM */
cfg_gsm_ppp_serv( appli_entry_point);
#elif defined( OVER_GSM_PPP_CLIENT)
/* Initialize PPP client over GSM */
cfg_gsm_ppp_client( appli_entry_point);
#elif defined( OVER_GPRS)
/* Initialize GPRS connection */
cfg_gprs( appli_entry_point);
#elif defined( OVER_ETHERNET)
/* initialize Ethernet connection */
cfg_eth( appli_entry_point);
#else
/* Don't initialize any bearer; only
* localhost=127.0.0.1 will be reachable. */
appli_entry_point();
#endif
/* Function : adl_main */
/* Object : Customer application initialisation */
/* Variable Name |IN |OUT|GLB| Utilisation */
/* InitType | x | | | Application start mode reason */
adl_tmrSubscribe ( TRUE, 600, ADL_TMR_TYPE_100MS, my_function );
Something else… in the Traces I can see “(cfg_gprs) Enter.” every time I call the timer to activate the upload process, but it uploads nothing.
Any ideas, is it possible to do something like that??
THANKS!!
