Firmawre Update to MC7430 EM7430 and MC7431
I am trying to update firmwares into those modules using the FDT2.exe tool. Going through the steps shown on 2174314 FDT AppNote r1.pdf manual and others posts carefully, it still does not put two firmwares for two different carriers into the module.
fdt2.exe -d g5k -force -f SWI9X30C_02.36.00.00.cwe SWI9X30C_02.36.00.00_KDDI_001.052_001.nvu SWI9X30C_02.38.00.00.cwe SWI9X30C_02.38.00.00_DOCOMO_001.058_000.nvu -log C:\FDTlogs
works, but it does not put both 02.36.00.00.cwe and 02.38.00.00.cwe software into 2 slots. Console with at!image? outputs:
at!image?
FW 1 EMPTY 0 0 0
FW 2 GOOD 1 0 0 ?? 02.38.00.00?
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 255
PRI FF GOOD 0 0 0 001.058_000 02.38.00.00_DOCOMO
PRI FF GOOD 0 0 0 001.052_001 02.36.00.00_KDDI
Max PRI images: 50
and
fdt2.exe -d g5k -force -f SWI9X30C_02.36.00.00.cwe SWI9X30C_02.36.00.00_KDDI_001.052_001.nvu SWI9X30C_02.38.00.00.cwe SWI9X30C_02.38.00.00_DOCOMO_001.058_000.nvu -mi -impref SWI9X30C_02.36.00.00_KDDI_001.052_001.nvu SWI9X30C_02.38.00.00_DOCOMO_001.058_000.nvu -log C:\FDTlogs
does not work, it gives us errors:
Primary error code: 51 - Failed to switch device to BOOT&HOLD mode. Secondary error code: 201 - Failed to switch device to QDL mode. Device error code: 0x0 - Unknown device error code.
What is the proper way to put two firmwares into two slots, 1 and 2, with FDT2.exe tool?
how about download two times with only one firmware each time?
BTW, you can also see here:
I saw other user can make it work in EM7565:
