The firmware you have is really old, am surprised it is not rebooting when you issue the command, you need to contact your commercial channel to get the latest greatest.
In fact i have 2 identical EM7565 modems (one inside a system, and one external for dev) and i have one which returns ERROR to the AT!SCACT=1,1 command (internal, it is probably in USB3) , and one which reboot (external, it is probably in USB2 ).
I tried this modem with NetwokManager/ModemManager on Ubuntu Xenial, and it worked.
So i tracked AT commands sent by the ModemManager, and i found that it does not use the AT!SCACT=1,1 command.
But it uses the following command : ATD*99***1#
Do you have any idea/explanations why it uses this way.
I’ll ask for a new firmware version.
Do you think the commands i used for the EM7455 will work for the EM7565 (with latest firmware) ??
The reason that the modem manager uses atd is because it is the mechanism used for modems to perform a call/data connection since the 70’s so it universally works regardless of whether you are using a v42bis analogue modem all the way through to the latest greatest LTE pro one. However it was never designed with the sort of speeds or interfaces in mind that we have now so there are draw backs meaning that most of the other methods are either OEM or chipset proprietary.
Re the commands that you have mentioned above yes they will work, I have tested them on my unit using Vodafone UK this morning (minus the username and password although I checked this command is also supported) and it worked fine.
FYI last night we produced release 9 so you should try to get this although release 8 will work perfectly well (has a minor bug that it puts the unit into MBIM when upgraded but you can easily change that with at+usbcomp).
As I say release 9 has just come out and you need to go through your commercial channel for support which you should have because they have only really been available on request to this point (some did get into Digikey for general buying but other wise it would have been through the authorised distribution network).
R9 will get onto the source within the next couple of weeks.
