I am not able to get data session on EM7565 using sierra Linux QMI SDK version 04.00.11 (SLQS04.00.11).
However, I can get data session on EM7565 using at!scact=1,1 AT command
Does SLQS04.00.11 support EM7565?
EM7565 firmware version:
Model: EM7565
Revision: SWI9X50C_01.00.02.00 6ff48a jenkins 2017/09/29 05:54:26
MEID: 35926008010494
IMEI: 359260080104943
IMEI SV: 2
FSN: UF742486640306
+GCAP: +CGSM
at!priid?
PRI Part Number: 9907344
Revision: 001.001
Customer: Generic-M2M
Carrier PRI: 9999999_9907259_SWI9X50C_01.00.02.00_00_GENERIC_001.012_000
Using AT & T SIM card, APN setting is:
+CGDCONT: 1,“IP”,“broadband”,“0.0.0.0”,0,0,0,0
I am using Sierra Linux QMI driver version S2.31N2.50
GobiSierial - 2.31
GobiNet - 2.50 and compiled as RAWIP mode
/dev/qcqmi0 get created correctly.
dmesg shows that GobiNet works fine:
[ 12.159077] GobiNet: 2018-02-28/SWI_2.50
[ 12.185253] GobiNet 1-2:1.8 eth0: register ‘GobiNet’ at usb-0000:00:15.0-2, GobiNet Ethernet Device, d2:fe:b4:a7:3f:53
[ 12.193926] USB Speed : USB 2.0
[ 12.196644] usbcore: registered new interface driver GobiNet
[ 12.215830] usbcore: registered new interface driver GobiSerial
[ 12.219053] usbserial: USB Serial support registered for GobiSerial
[ 12.220423] GobiSerial 1-2:1.0: GobiSerial converter detected
[ 12.227034] usb 1-2: GobiSerial converter now attached to ttyUSB0
[ 12.230230] GobiSerial 1-2:1.2: GobiSerial converter detected
[ 12.239674] usb 1-2: GobiSerial converter now attached to ttyUSB1
[ 12.242063] GobiSerial 1-2:1.3: GobiSerial converter detected
[ 12.248148] usb 1-2: GobiSerial converter now attached to ttyUSB2
[ 12.248222] GobiSerial: 2017-12-22/SWI_2.31:GobiSerial
[ 17.380558] GobiNet 1-2:1.8 enp0s21f0u2i8: renamed from eth0
[ 17.983052] creating qcqmi0
[ 17.991379] RawIP mode
When I use at!scact=1,1 command, I can get data session and IP address using dhclient,
and opersatet and carrier shows network interface is up:
cat /sys/bus/usb/devices/1-2/1-2:1.8/net/enp0s21f0u2i8/operstate
up
cat /sys/bus/usb/devices/1-2/1-2:1.8/net/enp0s21f0u2i8/carrier
1
However, when I use SLQS04.00.11 library functions, I cannot get data session.
Here is the log:
Cell modem scan and initialize success:
2018-04-11T17:28:09.862784+00:00 hyperlinc /sbin/cellqmid: ******* Cell modem daemon started. Version=[243.20180411.165237] *******
2018-04-11T17:28:09.889408+00:00 hyperlinc SWI0 SDK Process: SU:Process Started, version: SLQS04.00.11
2018-04-11T17:28:09.890245+00:00 hyperlinc SWI0 SDK Process: SU:7 -> task started
2018-04-11T17:28:09.890948+00:00 hyperlinc SWI0 SDK Process: QM:Task started
2018-04-11T17:28:09.892706+00:00 hyperlinc SWI0 SDK Process: SU:12 -> task started
2018-04-11T17:28:09.893663+00:00 hyperlinc SWI0 SDK Process: UDIAG:DS Shell launched
2018-04-11T17:28:09.894581+00:00 hyperlinc SWI0 SDK Process: UDIAG:DS Shell launched
2018-04-11T17:28:09.897715+00:00 hyperlinc SWI0 SDK Process:
2018-04-11T17:28:09.900711+00:00 hyperlinc SWI0 SDK Process:
2018-04-11T17:28:09.906351+00:00 hyperlinc SWI0 SDK Process: SU:17 -> task started
2018-04-11T17:28:09.914383+00:00 hyperlinc SWI0 SDK Process: >>MM sn or usb [0] 1-2
2018-04-11T17:28:09.915823+00:00 hyperlinc SWI0 SDK Process: ttyUSB0 device found on USB Interface 0
2018-04-11T17:28:09.916624+00:00 hyperlinc SWI0 SDK Process: ttyUSB0 device found on USB Interface 0
2018-04-11T17:28:09.917324+00:00 hyperlinc SWI0 SDK Process: ttyUSB1 device found on USB Interface 2
2018-04-11T17:28:09.917998+00:00 hyperlinc SWI0 SDK Process: ttyUSB1 device found on USB Interface 2
2018-04-11T17:28:09.918686+00:00 hyperlinc SWI0 SDK Process: ttyUSB2 device found on USB Interface 3
2018-04-11T17:28:09.919400+00:00 hyperlinc SWI0 SDK Process: ttyUSB2 device found on USB Interface 3
2018-04-11T17:28:09.920033+00:00 hyperlinc SWI0 SDK Process: swi_ossdkusbscan/1518: 3 tty interfaces successfully scanned
2018-04-11T17:28:09.920778+00:00 hyperlinc SWI0 SDK Process: qcqmi0 device found on USB Interface 8
2018-04-11T17:28:09.921510+00:00 hyperlinc SWI0 SDK Process: qcqmi0 device found on USB Interface 8
2018-04-11T17:28:09.922034+00:00 hyperlinc SWI0 SDK Process: swi_ossdkusbscan/1544: 1 qmi interfaces successfully scanned
2018-04-11T17:28:09.922625+00:00 hyperlinc SWI0 SDK Process: swi_ossdkusbscan/1556: 4/4 interfaces successfully scanned
2018-04-11T17:28:09.923275+00:00 hyperlinc SWI0 SDK Process: swi_ossdkusbscan: drivers ready!
2018-04-11T17:28:09.923702+00:00 hyperlinc SWI0 SDK Process: QM:qm_map_instances_to_device_files: USEP_QMI: 0 USEP_QMI2: -1 USEP_QMI3: -1
2018-04-11T17:28:09.924053+00:00 hyperlinc SWI0 SDK Process: QM:qm_map_instances_to_device_files: USEP_QMI4: -1 USEP_QMI5: -1 USEP_QMI6: -1
2018-04-11T17:28:09.924486+00:00 hyperlinc SWI0 SDK Process: QM:qm_map_instances_to_device_files: USEP_QMI7: -1 USEP_QMI8: -1
2018-04-11T17:28:09.924857+00:00 hyperlinc SWI0 SDK Process: QM:qm_ds_handle_app_dev_ready: devstate 1
2018-04-11T17:28:09.925238+00:00 hyperlinc SWI0 SDK Process: QM-DCS:SDK<-DCS Notif: ch/Msgid/Msglen/Svctype: 1/0014/0/248
2018-04-11T17:28:09.925811+00:00 hyperlinc SWI0 SDK Process: QM-DCS:SDK<-DCS Notif: ch/Msgid/Msglen/Svctype: 3/0014/0/248
2018-04-11T17:28:09.926338+00:00 hyperlinc SWI0 SDK Process: QM-DCS:SDK<-DCS Notif: ch/Msgid/Msglen/Svctype: 5/0014/0/248
2018-04-11T17:28:10.867286+00:00 hyperlinc /sbin/cellqmid: SLQS_init: APP<->SDK IPC init successful
But start data session fails(using SLQSStartStopDataSession SDK function):
2018-04-11T17:28:11.391743+00:00 hyperlinc /sbin/cellqmid: Will Establish Connection on Auto Profile
2018-04-11T17:28:11.392649+00:00 hyperlinc /sbin/cellqmid: Establishing Connection…
2018-04-11T17:28:11.393586+00:00 hyperlinc /sbin/cellqmid: SLQSStartStopDataSession returned 57353(0xe009), rcv4:0(0x0), rcv6:0(0x0)
2018-04-11T17:28:11.394088+00:00 hyperlinc /sbin/cellqmid: session id: 0, v4 session id: 0, v6 session id: 0, failureReason: 0, failureReasonv4: 0, failureReasonv6: 0, verbFailReasonType: 0, verbFailReason: 0
2018-04-11T17:28:21.400897+00:00 hyperlinc SWI0 SDK Process: QM:qmqmireq/1523: Request: QMI Instance 0
2018-04-11T17:28:21.402012+00:00 hyperlinc SWI0 SDK Process: QM:SDK->Mdm: request received : ipcch/svctype/xactionlen/clientnum: 0/0003/4/2
2018-04-11T17:28:21.402775+00:00 hyperlinc SWI0 SDK Process: QM:SDK->Mdm: request validated : ipcch/svctype/xactionlen/clientnum: 0/0003/4/2
2018-04-11T17:28:21.403566+00:00 hyperlinc SWI0 SDK Process: QM:qmqmireq/1637: WDS Request: Active Client 2, WDS Client 0
2018-04-11T17:28:21.438289+00:00 hyperlinc SWI0 SDK Process: USB read: bytes2read = 93, read 93 bytes
2018-04-11T17:28:21.439295+00:00 hyperlinc SWI0 SDK Process: QM:SDK<-Mdm Resp: ch/Msgid/Msglen/client: 0/0024/90/2
2018-04-11T17:28:21.440065+00:00 hyperlinc SWI0 SDK Process: QM:qmqmireq/1523: Request: QMI Instance 0
2018-04-11T17:28:21.440892+00:00 hyperlinc SWI0 SDK Process: QM:SDK->Mdm: request received : ipcch/svctype/xactionlen/clientnum: 0/0003/9/2
2018-04-11T17:28:21.441651+00:00 hyperlinc SWI0 SDK Process: QM:SDK->Mdm: request validated : ipcch/svctype/xactionlen/clientnum: 0/0003/9/2
2018-04-11T17:28:21.442371+00:00 hyperlinc SWI0 SDK Process: QM:qmqmireq/1637: WDS Request: Active Client 2, WDS Client 0
2018-04-11T17:28:21.501374+00:00 hyperlinc SWI0 SDK Process: USB read: bytes2read = 35, read 35 bytes
2018-04-11T17:28:21.502287+00:00 hyperlinc SWI0 SDK Process: QM:SDK<-Mdm Resp: ch/Msgid/Msglen/client: 0/0020/32/2
2018-04-11T17:28:21.503034+00:00 hyperlinc /sbin/cellqmid: Determine Signal Interface
2018-04-11T17:28:21.503805+00:00 hyperlinc /sbin/cellqmid: Radio Interface is LTE
2018-04-11T17:28:21.504403+00:00 hyperlinc /sbin/cellqmid: Will Establish Connection on Fixed Profile ID: [1] [1]
2018-04-11T17:28:21.505005+00:00 hyperlinc /sbin/cellqmid: Establishing Connection…
2018-04-11T17:28:21.505653+00:00 hyperlinc /sbin/cellqmid: SLQSStartStopDataSession returned 57353(0xe009), rcv4:0(0x0), rcv6:0(0x0)
2018-04-11T17:28:21.506343+00:00 hyperlinc /sbin/cellqmid: session id: 0, v4 session id: 0, v6 session id: 0, failureReason: 0, failureReasonv4: 0, failureReasonv6: 0, verbFailReasonType: 0, verbFailReason: 0
2018-04-11T17:28:31.511891+00:00 hyperlinc SWI0 SDK Process: QM:qmqmireq/1523: Request: QMI Instance 0
2018-04-11T17:28:31.512945+00:00 hyperlinc SWI0 SDK Process: QM:SDK->Mdm: request received : ipcch/svctype/xactionlen/clientnum: 0/0003/4/2
2018-04-11T17:28:31.513718+00:00 hyperlinc SWI0 SDK Process: QM:SDK->Mdm: request validated : ipcch/svctype/xactionlen/clientnum: 0/0003/4/2
2018-04-11T17:28:31.514400+00:00 hyperlinc SWI0 SDK Process: QM:qmqmireq/1637: WDS Request: Active Client 2, WDS Client 0
2018-04-11T17:28:31.516780+00:00 hyperlinc SWI0 SDK Process: USB read: bytes2read = 93, read 93 bytes
2018-04-11T17:28:31.517783+00:00 hyperlinc SWI0 SDK Process: QM:SDK<-Mdm Resp: ch/Msgid/Msglen/client: 0/0024/90/2
2018-04-11T17:28:31.518451+00:00 hyperlinc SWI0 SDK Process: QM:qmqmireq/1523: Request: QMI Instance 0
2018-04-11T17:28:31.519080+00:00 hyperlinc SWI0 SDK Process: QM:SDK->Mdm: request received : ipcch/svctype/xactionlen/clientnum: 0/0003/9/2
2018-04-11T17:28:31.519733+00:00 hyperlinc SWI0 SDK Process: QM:SDK->Mdm: request validated : ipcch/svctype/xactionlen/clientnum: 0/0003/9/2
2018-04-11T17:28:31.520378+00:00 hyperlinc SWI0 SDK Process: QM:qmqmireq/1637: WDS Request: Active Client 2, WDS Client 0
2018-04-11T17:28:31.582278+00:00 hyperlinc SWI0 SDK Process: USB read: bytes2read = 35, read 35 bytes
2018-04-11T17:28:31.583323+00:00 hyperlinc SWI0 SDK Process: QM:SDK<-Mdm Resp: ch/Msgid/Msglen/client: 0/0020/32/2
SLQSStartStopDataSession always return 0xe009 (0xE009 - IPV4 and IPV6 is down). Failure reason is 0.
You can see that in my code I tried both auto-profile and fixed profile at 1 and 1.
The input parameter I give in SLQSStartStopDataSession are:
pTechnology = 1 if LTE / UMTS /GSM
pTechnology = 2 if CDMA
ipfamily = 0x04 (I only need IPv4)
When doing auto-profile:
pProfileId3GPP = NULL
pProfileId3GPP2 = NULL
When doing fixed profile:
pProfileId3GPP = 1
pProfileId3GPP2 = 1
But they both fail.
Do I have to do something special for profile setting, or modem setup?
Shuo
