At this moment we are testing the HL series evaluation board on Windows 10 and installed the drivers. We use the the USB1_Main connector which gives about 5 COM ports (no idea why around 5). Last week it worked nice with hypertherminal.
A few days later we installed drivers for our USB->Serial converter from FTI (UT232R). Not used for the evaluation board.
Now we are testing some AT command to our evaluation board (via the USB1_Main, UT232R disconnected form PC) but the response now has a lot of garbage.
Response of AT+IPR=?
ùé-[y[AT+IPR=?éù“F“-[y\
+IPR: (),(300,1200,2400,4800,9600,19200,38400,57600,115200,230400,460800,500000,
750000,921600,1843200,3000000,3250000,6000000)
Fù-[y\
Does someone know why?
Resetted PC and evaluation board but nothing helps.
Did you use CMUX before? If so the garbage characters could be the control characters around the serial data.
You might be connecting to the wrong serial port that has been enumerated, they all look like com ports but have different functions. As per the AT command manual (at+kusbcomp) there are different configurations (shown below), 0 is the default.
0 7 CDC-ACM mode, (PID: 0x0020)
USB0 – AT / NMEA / modem port
USB1 – Mobile Analyzer traces port
USB2 – 3G traces port
USB3 – AT / NMEA / modem port
USB4 – AT / NMEA / modem port
USB5 – AT / NMEA / modem port
USB6 – On-chip traces port
1 3 CDC-ACM and 3 CDC-ECM mode, (PID: 0x0302)
ECM1 – Network adapter port
ECM2 – Network adapter port
ECM3 – Network adapter port
USB1 – AT / NMEA / modem port
USB2 – Mobile Analyzer traces port
USB3 – 3G traces port
2 5 CDC-ACM and 1 CDC-ECM mode, (PID: 0x0303)
The control characters are a bit odd, I am not sure why you are seeing them if not for one of the reasons below, you will need to contac your local tech support to delve a little deeper.
Re the IP connection, I presume you want to use the on board IP stack? I have attached a zip file with a couple of terterm scripts which should help you see how to do this.
Thanks! I will try with the scripts. I will use the on board IP stack. Unless it’s not suitable for me. My uC does probably not support CDC-ECM only ACM so I have to see how to solve.
