I’m looking to try to load a configuration file [some adress and number where to send data by email/gprs… (mostly string and int or double)] in the Q2686 by the USB port with using something like Labview to build the user interface on the computer (when I plug the dev board to my computer, I can see COM3).
Must I have to write my own AT commands or something else?
If someone have an idea to start, that can be cool
NB: Can we use classical COM1 (RS232) and the USB port in same time on the Q2686 devboard??
You can create your own AT commands, or you could use the Flow Control Manager (FCM), and create your own custom protocol.
If you create your own AT commands, they could be used on any port - not just USB.
I don’t know if there are any specific restrictions on the particular devboard that you have, but the Q2686 itself is perfectly capable of using both USB and UART simultaneously.
I try the sdk sample, I can send AT command trough the USB port, but I receive echo on the RS232 com port (UART1) :mrgreen: !!!
So, how to specify that the response port is to be the USB port ??
My bad, no is not the behavior of the sample, and I now I have to modify the sample (what I’m doing since yesterday…).
At this time, I can send my own AT command from my PC to the Q2686 through the USB port, BUT it send answer on the UART1 (RS232 port com) and I would like it send it through the USB… Now I’m looking for help to make this.
Description Resource Path Location Type
incompatible type for argument 2 of 'adl_atSendStdResponse' appli.c cmd_at_perso_pour_sendreceive_pc_par_USB/src 144 C/C++ Problem
Already done, this is the adl_atSendStdResponse descpirtion:
@brief Additional Port parameter to adl_atSendStdResponse() API
@par Description:
Additional Port parameter definition for response sending function adl_atSendStdResponse()
#define adl_atSendStdResponsePort(_t,_p,_r) adl_atSendStdResponse(ADL_AT_PORT_TYPE(_p,_t),_r)
That refering to ADL_AT_PORT_TYPE macro, so:
@brief Macro to specify Response destination port and type
@par Description:
The _port argument has to be a defined value of the adl_port_e type, and this required port has to be available (cf. the AT/FCM port Service) ; sending a response on an Open AT® the GSM or GPRS based port will have no effects).
@note:
- With the ADL_AT_UNS type value, if the ADL_AT_PORT_TYPE macro is not used, the unsolicited response will be broadcasted on all currently opened ports.
- If the ADL_AT_PORT_TYPE macro is not used with the ADL_AT_RSP & ADL_AT_INT types, responses will be by default sent on the UART 1 port. If this port is not opened, responses will not be displayed.
#define ADL_AT_PORT_TYPE(_port_,_type_) ( u16 ) ( _port_ << 8 | _type_ )
Where finaly, adl_port_e type is evoked, and, in adl_port.h:
/* Ports identifiers */
typedef enum
ADL_PORT_NONE,
ADL_PORT_UART1,
ADL_PORT_UART2,
ADL_PORT_USB,
ADL_PORT_MAX = ADL_PORT_USB,
ADL_PORT_UART1_VIRTUAL_BASE = 0x10, // Base for UART1 virtual ports
ADL_PORT_UART2_VIRTUAL_BASE = 0x20, // Base for UART2 virtual ports
ADL_PORT_USB_VIRTUAL_BASE = 0x30, // Base for USB virtual ports
ADL_PORT_BLUETOOTH_VIRTUAL_BASE = 0x40, // Base for BlueTooth virtual ports
ADL_PORT_GSM_BASE = 0x50, // GSM CSD call data port
ADL_PORT_GPRS_BASE = 0x60, // GPRS session port
ADL_PORT_RDMS_VIRTUAL_BASE = 0x70, // Base for RDMS virtual port (internal messages)
ADL_PORT_RDMS_SERVER_VIRTUAL_BASE, // Base for RDMS virtual port (messages with server)
ADL_PORT_OPEN_AT_VIRTUAL_BASE = 0x80 // Base for Open-AT application tasks
} adl_port_e;
there is ADL_PORT_USB :mrgreen: so, I don’t now what I must to do.
NB I tryed to replace AD_PORT_USB by ADL_PORT_USB_VIRTUAL_BASE in my adl_atSendStdResponse but it’s the same.
to send a text string. The failure code is from adl_atSendStdResponse, not from adl_atSendStdResponsePort. Be carefull, this function recieve a adl_strID_e as second parameter (the third in adl_atSendStdResponsePort), where you are sending an ascii string.
It depends on what you want to do, if you want to send standard AT responses (OK, BUSY,NO ANSWER…) use “adl_atSendStdResponsePort”. If you want to send “custom-made” responses use “adl_atSendResponsePort”.
