Hey everyone
New installation of VS2005 along with openAT 3.16 is not working.
It is a new computer, but until now I’ve this same configuration on another/older computer, working just fine.
Windows XP professional is running on the new one, but home edition on the older one.
I have Visual C++ 6.0 installed as well, and that is OK, I can build the projects there.
When I build my applications or samples (Hello world) in VS05 it doesn’t complete and presents this error:
Error 7 Error result 1 returned from ‘C:\WINDOWS\system32\cmd.exe’. Project
The following is part of the build output:
1>make: uname: Command not found
1>! var ikke ventet på dette tidspunkt.
1>make: #---------------------------------------: Command not found
1>make: *** […/out/gcc_Hello_World.dep] Error 127
1>/cygdrive/C/OpenAT/IDE/IDE/1.02.03/bin/wmmake: line 1: basename: command not found
1>/cygdrive/C/OpenAT/IDE/IDE/1.02.03/bin/wmmake: line 448: cp: command not found
1>Done.
1>[ error #1] Build error.
1>umount: /: No such file or directory
1>umount: /usr/bin: No such file or directory
1>Project : error PRJ0002 : Error result 1 returned from ‘C:\WINDOWS\system32\cmd.exe’.
1>Build log was saved at “file://d:\Work\Projects_OpenAT\Samples\HelloWorld_VS\arm\out\BuildLog.htm”
1>Hello_World - 1 error(s), 1 warning(s)
========== Build: 1 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Does it make sense to anyone? There are too many “not found”, “no such file” events there… so lack of configuration of any kind.
I can’t recall this error message when I tried out with VS05 on my old computer, first time. I haven’t re-installed VS05 neither…
I’ve tried to compare System paths on both computers, but not successfully being able to find anything useful…
palsson
