I’ve spent some time trying to debug this. I have two modems, both with T-Mobile SIMs. One won’t pick up a data connection, ModemManager has an error about cannot disable multiplex support. Everything else looks similar between the two devices. Any thoughts about what’s happening?
Modem with issue: mmcli bearer output
$ mmcli -m 0 -b 0
General | path: /org/freedesktop/ModemManager1/Bearer/0
| type: default
Status | connected: no
| connection error name: org.freedesktop.ModemManager1.Error.Core.Unsupported
| connection error message: Cannot disable multiplex support
| suspended: no
| multiplexed: no
| ip timeout: 20
Properties | apn: fast.t-mobile.com
| roaming: allowed
| ip type: ipv4v6
Statistics | attempts: 13
| attempts: 13
Modem with issue: AT Commands
ATI3
Model: EM9291
Revision: SWIX65C_02.15.01.00 5268b2 jenkins 2023/11/17 22:12:47
IMEI: 3***7
IMEI SV: 2
FSN: 8***1
+GCAP: +CGSM
AT!IMPREF?
!IMPREF:
preferred fw version: 00.00.00.00
preferred carrier name: AUTO-SIM
preferred config name: AUTO-SIM_000.000_000
preferred subpri index: 000
current fw version: 02.15.01.00
current carrier name: GENERIC
current config name: GENERIC_030.054_001
current subpri index: 000
AT+CFUN?
+CFUN: 1
AT!PCINFO?
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0, NVCRIT:0, RFCAL:0, MMWCAL:0, RFC_INIT:0
LPM persistence - None
AT!GSTATUS?
!GSTATUS:
Current Time: 5215 Temperature: 33
Thermal Mitigation Level: 0
Reset Counter: 1 Mode: ONLINE
System mode: NR5G PS state: Attached
MM5G state: Registered Normal Service
RRC state: RRC Idle
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
NR5G TAC: 59ed00 NR5G Cell ID: 147AF9137 (5497655607)
NR5G band: n41 NR5G Carrier ID: 0
NR5G dl bw: 40 MHz NR5G ul bw: 40 MHz
NR5G Tx Power: --- NR5G Tx chan: 0
NR5G Rx chan: 530124
NR5G dl MIMO: 4 NR5G ul MIMO: 1
NR5G(sub6) Rx0 RSSI (dBm): -78.9 NR5G(sub6) Rx1 RSSI (dBm): -49.9
NR5G(sub6) Rx2 RSSI (dBm): --- NR5G(sub6) Rx3 RSSI (dBm): ---
NR5G RSRP (dBm): -77 NR5G RSRQ (dB): -11
NR5G SINR (dB): 23.5
AT+CPIN?
+CPIN: READY
AT+CGDCONT?
+CGDCONT: 1,"IPV4V6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
AT!UIMS?
!UIMS: 0
AT!SELRAT?
!SELRAT: 00, Automatic
AT!BAND?
Index, Name
00, All bands
Modem without issue: AT commands
ATI3
Model: EM9291
IMEI: 3***3
IMEI SV: 2
FSN: 8***1
+GCAP: +CGSM
AT!IMPREF?
!IMPREF:
AT+CFUN?
+CFUN: 1
AT!PCINFO?
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0, NVCRIT:0, RFCAL:0, MMWC0
AT!GSTATUS?
!GSTATUS:
Current Time: 27772 Temperature: 27
LTE band: B66 LTE bw: 10 MHz
LTE Rx chan: 67086 LTE Tx chan: 132622
RRC state: RRC Idle
IMS reg state: REGISTERED IMS mode: Normal
IMS Srv State: FULL SMS,NO VoIP
PCC Rx0 RSSI: -68.9 PCC Rx0 RSRP: -97.8
PCC Rx1 RSSI: -97.6 PCC Rx1 RSRP: -134.5
PCC Tx Power: --- TAC: 6a44 (27204)
RSRQ (dB): -12.0 Cell ID: 07F1F016 (133296150)
SINR (dB): 4.4
NR5G band: --- NR5G bw: ---
NR5G Tx Power: --- NR5G Tx chan: ---
NR5G Rx chan: --- NR5G RSRP (dBm): ---
NR5G RSRQ (dB): --- NR5G SINR (dB): ---
AT+CPIN?
+CPIN: READY
at+cgdcont?
at!uims?
!UIMS: 0
at!selrat?
at!band?
Index, Name
00, All bands
