EM9191 unstable after possible bad firmware update
I have a EM9191 that is constantly resetting itself and will not start up it’s 5G radio.
I have a separate EM9191 that behaves as I would imagine, is rock solid, and always connects to 5G without complaint.
There is a possibility that the first EM9191 unit was flashed with newer firmware from the driver here instead of the correct one.
I have a feeling this is related to the issue because it is the only variable I can see that may have changed.
I would ask if it is possible to completely re-image the modem rather than the standard firmware flashing process; something lower level that might be able to undo the damage a bad, but supposedly successful, flash would entail.
Otherwise I have tried rmareset and nvrestore and neither options seem to clear things out enough to bring the modem back to working order after flashing the latest fw release.
What do you mean by “constantly resetting itself and will not start up it’s 5G radio” but you can still “tried rmareset and nvrestore”?
Does the module really keep resetting?
Thank you for your reply,
So by resetting I meant rebooting. The modem will reboot about every 10-20 seconds from what I can tell.
The caveat being that whenever I remove the SIM, the modem is more stable, and I am able to do some troubleshooting with at commands.
I Just so happened to notice that the 5G radio never engages because it seems that stability improves when I disable the 5G radio with SELRAT.
Seems to be power issue
Have you used usb adpator instead of usb power?
That’s what I thought as well.
I currently have an auxiliary power of 5v 4a available to the modem.
To add insult to injury, a different EM9191 works perfectly in the same enclosure, with the same power being applied to it.
Does at!gcdump show anything?
What fw are you using now?
Model: EM9191
Revision: SWIX55C_03.09.14.00 5571c0 jenkins 2022/07/28 20:38:23
IMEI: REDACTED
IMEI SV: 23
FSN: 8W1193001003A1
+GCAP: +CGSM
No crash data available
Echo doesn’t seem to be working, but commands are working fine atm.
How about fw 03.09.11.00 or 03.09.06.00
I’ve tried 01.07.19.00, 02.08.01.00, 03.09.06.00, 03.09.14.00, I will try 03.09.11.00 now and report back.
cd /D “%~dp0”
fdt2.exe -d g5k -resettimeout 3 -timeout 15 -f SWIX55C_03.09.11.00-002.cwe SWIX55C_03.09.11.00-001_GENERIC_030.044_001.nvu -mi -impref SWIX55C_03.09.11.00-002.cwe SWIX55C_03.09.11.00-001_GENERIC_030.044_001.nvu
Device reboots constantly if powering on with sim inserted.
Removed SIM
ati3
Model: EM9191
Revision: SWIX55C_03.09.11.00 7bf975 jenkins 2022/06/10 20:36:01
IMEI: REDACTED
IMEI SV: 22
FSN: 8W1193001003A1
+GCAP: +CGSM
at!gcdump
Still no crash data despite the modem constantly rebooting if I connect it with the SIM inserted.
at!gstatus?
!GSTATUS:
Current Time: 37 Temperature: 25
Thermal Mitigation Level: 0
Reset Counter: 1 Mode: LOW POWER MODE
at!gstatus?
!GSTATUS:
Current Time: 49 Temperature: 24
Inserted SIM at this Point
at!gstatus?
!GSTATUS:
Current Time: 63 Temperature: 25
Reset Counter: 1 Mode: ONLINE
System mode: NR5G PS state: Not attached
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
NR5G TAC: 7c9300 NR5G Cell ID: 316
NR5G band: n41 NR5G Carrier ID: 0
NR5G dl bw: 100 MHz NR5G ul bw: 100 MHz
NR5G Tx Power: 21 NR5G Tx chan: 528000
NR5G Rx chan: 528000
NR5G dl MIMO: 1 NR5G ul MIMO: 1
NR5G(sub6) RxM RSSI (dBm): -36.9 NR5G(sub6) RxD RSSI (dBm): -42.6
NR5G(sub6) RxM1 RSSI (dBm): -42.1 NR5G(sub6) RxD1 RSSI (dBm): -32.8
NR5G RSRP (dBm): — NR5G RSRQ (dB): —
NR5G SINR (dB): —
Device rebooted on its own here.
It’s back to boot looping.
How about using 5g NSA (endc) instead of 5g SA
5G at my location is SA, I tried the below though.
at!band?
Index, Name
00, All bands
at!selrat=?
!SELRAT: Index, Name
00, Automatic
01, UMTS 3G Only
04, LTE Only
05, 5G Only
0E, UMTS and LTE Only
0F, LTE and NR5G only
10, WCDMA and NR5G only
at!selrat=0F
at!nrinfo?
!NRINFO:
Connectivity Mode: —
NR5G Cell ID: —
NR5G band: — NR5G Carrier ID: —
NR5G dl bw: — NR5G ul bw: —
NR5G Tx Power: — NR5G Tx chan: —
NR5G Rx chan: —
NR5G dl MIMO: — NR5G ul MIMO: —
NR5G(sub6) RxM RSSI (dBm): — NR5G(sub6) RxD RSSI (dBm): —
NR5G(sub6) RxM1 RSSI (dBm): — NR5G(sub6) RxD1 RSSI (dBm): —
NR5G(mmw) Rx0 RSSI (dBm): — NR5G(mmw) Rx1 RSSI (dBm): —
NR5G SINR (dB): —
at!gstatus?
!GSTATUS:
Current Time: 36 Temperature: 25
LTE band: B2 LTE bw: 5 MHz
LTE Rx chan: 1075 LTE Tx chan: 19075
RRC state: RRC Connected
PCC RxM RSSI: -75 PCC RxM RSRP: -102
PCC RxD RSSI: -55 PCC RxD RSRP: -84
PCC Tx Power: 23 TAC: 7c93 (31891)
RSRQ (dB): -10.5 Cell ID: 00ed4670 (15550064)
SINR (dB): 15.4
NR5G band: — NR5G bw: —
NR5G Rx chan: — NR5G RSRP (dBm): —
NR5G RSRQ (dB): — NR5G SINR (dB): —
Device is bootlooping through all of the above commands. ENDC wont engage only LTE.
Then seems you only make this module to be lte only
Do you have any recommendation on how to make it operate in 5G SA or ENDC?
I’m still curious if there is a way to rewrite the entire modem, as it is acting so oddly, but I’m assuming someone else might need to chime in on that.
I upgrade from fw 01.07.19 to 03.09.xx, i don’t see such problem
I am wondering if particular 5G band is making the crash, you can lock to particular band to see what happens.
Here is an example to lock to n66 band:
//lock 5G n66 and LTE all band (new SKU:1104903)
at!band=13,1,"TEST",1,0000A7E2BB0F38DF,0000000000000042
at!band=13,1,"TEST",3,0000000000000000,0000000000000002
at!band=13,1,"TEST",4,0000000000000000,0000000000000002
at!band=13
at+cfun=0
at+Cfun=1
//lock 5G n66 and LTE all band (old SKU: 1104629)
at!band=13,1,"TEST",1,0000A3E2BB0F38DF,0000000000000042
at!band=13
at+cfun=0
at+Cfun=1
10, n71 NSA
0 - GW: 0000000000000000
1 - LTE: 0000A3E2BB0F38DF 0000000000000042
3 - NRNSA: 0000000000000000 0000000000000040
4 - NRSA: 0000000000000000 0000000000000000
11, n41 NSA
3 - NRNSA: 0000010000000000 0000000000000000
12, n41 SA
1 - LTE: 0000000000000000 0000000000000000
3 - NRNSA: 0000000000000000 0000000000000000
4 - NRSA: 0000010000000000 0000000000000000
13, n71 SA
4 - NRSA: 0000000000000000 0000000000000040
I setup the above masks for this test.
09(LTE Only), device works flawlessly.
10, device connects to n71 and appears to work fine until I run a speedtest and the it shuts down for about 5 seconds and comes back up. I close telnet connection during this downtime.
11, device reboots after about 15 seconds without any input from me.
12, Constant reboots when sim inserted, cannot get a telnet connection because of constant reboots.
13, connects fine, no reboots when idle, similar outcome where it eventually resets after I run a speed test to put a load on it.
and to reiterate, I have a power supply connected to this modem and a different modem works perfectly fine in the same enclosure.
Does anything stick out to you with this data?
I was thinking it reboots on particular 5g band, but seems it reboots whenever using 5g
Can you also paste at!flog?
at!entercnd=“A710”
at!flog?
!FLOG:
Class long:
00000,1980/01/06 00:00:00.000,SWIX55C_01.07.0,COMMENT=Log created,LOG_VERSION=1. 0
00000,1980/01/06 00:00:00.000,SWIX55C_01.07.0,NV_REBUILD=START,COMMENT=FW ver: S WIX55C_01.07.08.01 000000 jenkins 2020/11/24 06:30:01,FILE=DEFAULTS
00000,1980/01/06 00:00:00.000,SWIX55C_01.07.0,NV_DEFAULT=FW ver: SWIX55C_01.07.0 8.01 000000 jenkins 2020/11/24 06:30:01
00000,1980/01/06 00:00:00.000,SWIX55C_01.07.0,NV_REBUILD=COMPLETE,COMMENT=defaul ted 93, restored 0, skipped 0, failed 0,STATUS=PASS
00619,1980/01/06 00:00:00.000,SWIX55C_02.08.0,COPY_FROM_BACKUP=/swir/nvdelta/NVU P_GENERIC.010,STATUS=PASS
00619,1980/01/06 00:00:00.000,SWIX55C_02.08.0,IMAGE_SW,CURR=02.08.01.00 GENERIC_ 030.047_000,PREF=02.08.01.00 GENERIC_020.007_002,CALC=02.08.01.00 GENERIC_020.00 7_002,COMMENT=START
00619,1980/01/06 00:00:00.000,SWIX55C_02.08.0,IMAGE_SW,CURR=02.08.01.00 GENERIC_ 020.007_002,PREF=02.08.01.00 GENERIC_020.007_002,CALC=02.08.01.00 GENERIC_020.00 7_002,COMMENT=COMPLETE,STATUS=PASS
00620,1980/01/06 00:00:00.000,SWIX55C_,BOOT_HOLD=3,
00621,1980/01/06 00:00:00.000,C3091400,COPY_FROM_BACKUP=/swir/nvdelta/NVUP_GENER IC.010,STATUS=PASS
00621,1980/01/06 00:00:00.000,C3091400,IMAGE_SW,CURR=03.09.14.00 GENERIC_020.007 _002,PREF=03.09.14.00 GENERIC_030.047_000,CALC=03.09.14.00 GENERIC_030.047_000,C OMMENT=START
00621,1980/01/06 00:00:00.000,C3091400,IMAGE_SW,CURR=03.09.14.00 GENERIC_030.047 _000,PREF=03.09.14.00 GENERIC_030.047_000,CALC=03.09.14.00 GENERIC_030.047_000,C OMMENT=COMPLETE,STATUS=PASS
00667,1980/01/06 00:00:00.000,C3091400,BOOT_HOLD=3,
00668,1980/01/06 00:05:28.140,C3091100,COPY_FROM_BACKUP=/swir/nvdelta/NVUP_GENER IC.010,STATUS=PASS
00668,1980/01/06 00:05:28.140,C3091100,IMAGE_SW,CURR=03.09.11.00 GENERIC_030.047 _000,PREF=03.09.11.00 GENERIC_030.044_001,CALC=03.09.11.00 GENERIC_030.044_001,C OMMENT=START
00668,1980/01/06 00:05:28.140,C3091100,IMAGE_SW,CURR=03.09.11.00 GENERIC_030.044 _001,PREF=03.09.11.00 GENERIC_030.044_001,CALC=03.09.11.00 GENERIC_030.044_001,C OMMENT=COMPLETE,STATUS=PASS
Class med:
00000,1980/01/06 00:00:00.000,SWIX55C_01.07.0,RESET=HARD,COMMENT=Count 1
00001,1980/01/06 00:00:00.000,SWIX55C_01.07.0,RESET=HARD,COMMENT=Count 2
00002,1980/01/06 00:00:00.000,SWIX55C_01.07.0,RESET=HARD,COMMENT=Count 3
00003,1980/01/06 00:00:00.000,SWIX55C_01.07.0,RESET=HARD,COMMENT=Count 4
00004,1980/01/06 00:00:00.000,SWIX55C_01.07.0,RESET=HARD,COMMENT=Count 5
00541,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 495
00543,1980/01/06 00:00:00.000,SWIX55C_01.07.1,RESET=HARD,COMMENT=Count 496
00546,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 497
00549,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 498
00551,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 499
00553,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 500
00558,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 501
00559,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 502
00560,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 503
00562,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 504
00568,1980/01/06 00:00:00.000,SWIX55C_01.07.1,RESET=HARD,COMMENT=Count 505
00569,1980/01/06 00:00:00.000,SWIX55C_01.07.1,RESET=HARD,COMMENT=Count 506
00573,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 507
00576,1980/01/06 00:00:00.000,SWIX55C_02.08.0,RESET=HARD,COMMENT=Count 508
00577,1980/01/06 00:00:00.000,SWIX55C_02.08.0,RESET=HARD,COMMENT=Count 509
00578,1980/01/06 00:00:00.000,SWIX55C_02.08.0,RESET=HARD,COMMENT=Count 510
00579,1980/01/06 00:00:00.000,SWIX55C_02.08.0,RESET=HARD,COMMENT=Count 511
00580,1980/01/06 00:00:00.000,SWIX55C_02.08.0,RESET=HARD,COMMENT=Count 512
00581,1980/01/06 00:00:00.000,SWIX55C_02.08.0,RESET=HARD,COMMENT=Count 513
00582,1980/01/06 00:00:00.000,SWIX55C_02.08.0,RESET=HARD,COMMENT=Count 514
00583,1980/01/06 00:00:00.000,SWIX55C_02.08.0,RESET=HARD,COMMENT=Count 515
00585,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 516
00586,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 517
00587,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 518
00588,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 519
00589,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 520
00593,1980/01/06 00:00:00.000,SWIX55C_01.07.1,RESET=HARD,COMMENT=Count 521
00595,2022/10/21 15:11:31.810,SWIX55C_02.08.0,NV_BACKUP=START,COMMENT=index 4
00595,2022/10/21 15:11:35.714,SWIX55C_02.08.0,NV_BACKUP=COMPLETE,COMMENT=index 4,STATUS=PASS
00599,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 522
00600,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 523
00605,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 524
00608,2022/10/21 17:08:41.695,SWIX55C_01.07.1,NV_BACKUP=START,COMMENT=index 4
00608,2022/10/21 17:08:45.417,SWIX55C_01.07.1,NV_BACKUP=COMPLETE,COMMENT=index 4,STATUS=PASS
00615,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 525
00616,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 526
00617,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 527
00620,1980/01/06 00:00:00.000,SWIX55C_02.08.0,RESET=HARD,COMMENT=Count 528
00622,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 529
00623,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 530
00624,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 531
00625,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 532
00626,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 533
00627,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 534
00628,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 535
00629,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 536
00630,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 537
00631,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 538
00632,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 539
00633,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 540
00634,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 541
00635,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 542
00636,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 543
00637,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 544
00638,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 545
00639,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 546
00640,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 547
00641,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 548
00642,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 549
00643,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 550
00644,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 551
00645,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 552
00646,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 553
00647,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 554
00648,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 555
00649,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 556
00650,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 557
00651,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 558
00652,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 559
00653,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 560
00654,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 561
00655,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 562
00656,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 563
00657,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 564
00658,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 565
00659,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 566
00660,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 567
00661,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 568
00662,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 569
00663,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 570
00664,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 571
00665,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 572
00666,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 573
00667,1980/01/06 00:00:00.000,C3091400,RESET=HARD,COMMENT=Count 574
00669,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 575
00670,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 576
00671,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 577
00672,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 578
00673,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 579
00674,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 580
00675,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 581
00676,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 582
00677,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 583
00678,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 584
00679,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 585
00680,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 586
00681,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 587
00682,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 588
00683,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 589
00684,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 590
00685,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 591
00686,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 592
00687,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 593
00688,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 594
00689,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 595
00690,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 596
00691,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 597
00692,1980/01/06 00:00:00.000,C3091100,RESET=HARD,COMMENT=Count 598
DONE
Seems no crash information in FLOG
That is odd, the device certainly loses serial connection and i can hear the USB enumerate. I would assume it’s a crash.
Is it possible that the device is messed up to a point that it wouldn’t log crashes?
