I have an issue with an EM9191 modem through PCIe interface. The communication with the modem works fine via QMI, MBIM or AT commands if the SIM PIN is not entered or the antennas not connected. Upon network registration, the firmware crashes with messages in dmesg like :
mhi-pci-generic 0000:01:00.0: firmware crashed (7)
mhi mhi0: Did not enter M3 state, MHI state: M0, PM state: SYS ERROR Detect
mhi-pci-generic 0000:01:00.0: failed to suspend device: -5
mhi-pci-generic 0000:01:00.0: firmware crashed (6)
I upgraded the modem firmware to SWIX55C_03.14.10.01. I tried different linux kernel versions. And I still have the same error messages.
I just looked at the modem dump error message, here is the report :
AT!GCDUMP
Src:  FatalError
File: lte_LL1_resource_cfg.c
Line: 988
Str:  Device FUSE doesn't support more than -801039208 layers in FW
0000000A 47FFAE8A 0000000A 00000000
Prc:  MPSS
Task: NONE
Time: 0004BB79
 R0: 00000000  R1: 00000000  R2: 00000000  R3: 00000000  R4: 00000000
 R5: 00000000  R6: 00000000  R7: 00000000  R8: 00000000  R9: 00000000
R10: 00000000 R11: 00000000 R12: 00000000 R13: 00000000 R14: 00000000
R15: 00000000 R16: 00000000 R17: 00000000 R18: 00000000 R19: 00000000
R20: 00000000 R21: 00000000 R22: 00000000 R23: 00000000 R24: 00000000
R25: 00000000 R26: 00000000 R27: 00000000 R28: 00000000 SP:  C9AF4370
FP:  C9AF4380 LR:  D9B9D170
PC: 56A8740B
CPSR: 00000000
Mod: Unknown
Ctr: ARM, IRQ dis,FIQ dis
TOS
C9AF4390 4EC1D33F 00FE8F1F 00003800 C9AF43D0 56A8740B C8F84444
C8F84466 00000000 00000000 00000000 CF800000 62E18BBC C8F84438
62E18CC9 C9AEA3E8 00003800 0000000E C8F8454C EB1A8050 C9AF43E8
4EEB40B3 C08227C0 00000000 C9AEA3BC C9AEA3B8 C9AF4480 56F4A983
C9B15350 C9AE8D40 C9AE8D44 00000000
BOS
App ver: SWIX55C_03.14.10.01
Src:  FatalError
Str:  Internal error:
00000000 00000000 00000000 00000000
Prc:  APSS
Task:
Time: 00000000
PC: 00000000
CPSR: 00000000
Mod: Unknown
TOS
00000000 00000000 00000000 00000000 00000000 00000000 00000000
BOS
  262.807842] ipa ipa3_dma_enable:426 Already enabled refcnt=1
<4>[  262.814421] ipa3_dma_disable: 11 callbacks suppressed
<3>[  262.814437] ipa ipa3_dma_disable:485 Multiple enablement done. refcnt=2
<4>[  262.835894] ipa3_dma_disable: 1 callbacks suppressed
<3>[  262.835902] ipa ipa3_dma_disable:497 There is pending work, can't disable.
<4>[  268.991727] ipa3_dma_enable: 11 callbacks suppressed
<3>[  268.991752] ipa ipa3_dma_enable:426 Already enabled refcnt=1
<4>[  268.998232] ipa3_dma_disable: 11 callbacks suppressed
<3>[  268.998250] ipa ipa3_dma_disable:485 Multiple enablement done. refcnt=2
<4>[  269.020775] ipa3_dma_disable: 1 callbacks suppressed
<3>[  269.020782] ipa ipa3_dma_disable:497 There is pending work, can't disable.
<4>[  274.762944] ipa3_dma_enable: 11 callbacks suppressed
<3>[  274.762966] ipa ipa3_dma_enable:426 Already enabled refcnt=1
<4>[  274.769423] ipa3_dma_disable: 11 callbacks suppressed
<3>[  274.769437] ipa ipa3_dma_disable:485 Multiple enablement done. refcnt=2
<4>[  274.792587] ipa3_dma_disable: 1 callbacks suppressed
<3>[  274.792594] ipa ipa3_dma_disable:497 There is pending work, can't disable.
<4>[  280.852678] ipa3_dma_enable: 11 callbacks suppressed
<3>[  280.852703] ipa ipa3_dma_enable:426 Already enabled refcnt=1
<4>[  280.859191] ipa3_dma_disable: 11 callbacks suppressed
<3>[  280.859207] ipa ipa3_dma_disable:485 Multiple enablement done. refcnt=2
<4>[  280.881186] ipa3_dma_disable: 1 callbacks suppressed
<3>[  280.881193] ipa ipa3_dma_disable:497 There is pending work, can't disable.
<4>[  287.227182] ipa3_dma_enable: 11 callbacks suppressed
<3>[  287.227204] ipa ipa3_dma_enable:426 Already enabled refcnt=1
<4>[  287.233754] ipa3_dma_disable: 11 callbacks suppressed
<3>[  287.233768] ipa ipa3_dma_disable:485 Multiple enablement done. refcnt=2
<4>[  287.254302] ipa3_dma_disable: 1 callbacks suppressed
<3>[  287.254310] ipa ipa3_dma_disable:497 There is pending work, can't disable.
<4>[  293.447219] ipa3_dma_enable: 11 callbacks suppressed
<3>[  293.447244] ipa ipa3_dma_enable:426 Already enabled refcnt=1
<4>[  293.453885] ipa3_dma_disable: 11 callbacks suppressed
<3>[  293.453901] ipa ipa3_dma_disable:485 Multiple enablement done. refcnt=2
<4>[  293.474364] ipa3_dma_disable: 1 callbacks suppressed
<3>[  293.474372] ipa ipa3_dma_disable:497 There is pending work, can't disable.
<4>[  299.563057] ipa3_dma_enable: 11 callbacks suppressed
<3>[  299.563081] ipa ipa3_dma_enable:426 Already enabled refcnt=1
<4>[  299.569561] ipa3_dma_disable: 11 callbacks suppressed
<3>[  299.569577] ipa ipa3_dma_disable:485 Multiple enablement done. refcnt=2
<4>[  299.591051] ipa3_dma_disable: 1 callbacks suppressed
<3>[  299.591058] ipa ipa3_dma_disable:497 There is pending work, can't disable.
<3>[  306.897367] Fatal error on modem!
<3>[  306.897503] modem subsystem failure reason: lte_LL1_resource_cfg.c:988:Device FUSE doesn't support more than 10 layers in FW.
<6>[  306.899762] subsys-restart: subsystem_restart_dev(): Restart sequence requested for modem, restart_level = SYSTEM.
<3>[  306.914518] Ramdump(ramdump_microdump_modem): No consumers. Aborting..
<6>[  306.922591] microdump_modem_notifier_nb: do_ramdump() failed
<0>[  307.030530] Kernel panic - not syncing: subsys-restart: Resetting the SoC - modem crashed.
<4>[  307.030633] CPU: 0 PID: 1271 Comm: kworker/0:1 Not tainted 4.14.206-perf #1
<4>[  307.037733] Hardware name: Qualcomm Technologies, Inc. SDXPRAIRIE (Flattened Device Tree)
<4>[  307.044634] Workqueue: events device_restart_work_hdlr
<4>[  307.052957] [<c010e658>] (unwind_backtrace) from [<c010b3e4>] (show_stack+0x10/0x14)
<4>[  307.057986] [<c010b3e4>] (show_stack) from [<c0121498>] (panic+0x180/0x3b4)
<4>[  307.065884] [<c0121498>] (panic) from [<c0454df4>] (subsys_remove_restart_order+0x0/0x80)
<4>[  307.072571] [<c0454df4>] (subsys_remove_restart_order) from [<ca4b8800>] (0xca4b8800)
<3>[  307.087822] ipa ipa3_active_clients_panic_notifier:300
<3>[  307.087822] ---- Active Clients Table ----
<3>[  307.087822]
<3>[  307.087822] Total active clients count: 3
<3>[  307.087822]
Should I downgrade the modem firmware version?
