I was using EM9191 for quite some time with DEV KIT. Did not experience problems. However, as of today device started behaving weird in sense that it reboots “itself” for no known reason. Interestingly enough I’m able to use the device normally (e.g. attach to network) till the point it reboots “itself”. EM9191 FW version: 03.09.11.00_GENERIC.
Question: Any idea on why it might be happening or what should I check in order to figure it out?
I’m attaching output of dmesg:
[95216.788200] usb 4-1: new SuperSpeed USB device number 32 using xhci_hcd
[95216.819362] usb 4-1: config 1 has an invalid interface number: 4 but max is 3
[95216.819395] usb 4-1: config 1 has no interface number 2
[95216.821739] usb 4-1: New USB device found, idVendor=1199, idProduct=90d3, bcdDevice= 0.06
[95216.821812] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[95216.821950] usb 4-1: Product: Sierra Wireless EM9191
[95216.821994] usb 4-1: Manufacturer: Sierra Wireless, Incorporated
[95216.822007] usb 4-1: SerialNumber: 8W1164011203A121
[95216.950151] cdc_mbim 4-1:1.0: setting rx_max = 16384
[95216.952404] cdc_mbim 4-1:1.0: cdc-wdm0: USB WDM device
[95216.955140] cdc_mbim 4-1:1.0 wwan0: register 'cdc_mbim' at usb-0000:03:00.0-1, CDC MBIM, ce:d2:8a:93:a2:77
[95260.296042] usb 4-1: USB disconnect, device number 32
[95260.296227] cdc_mbim 4-1:1.0 wwan0: unregister 'cdc_mbim' usb-0000:03:00.0-1, CDC MBIM
[95274.410511] usb 4-1: new SuperSpeed USB device number 33 using xhci_hcd
[95274.439598] usb 4-1: config 1 has an invalid interface number: 4 but max is 3
[95274.439611] usb 4-1: config 1 has no interface number 2
[95274.442314] usb 4-1: New USB device found, idVendor=1199, idProduct=90d3, bcdDevice= 0.06
[95274.442325] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[95274.442358] usb 4-1: Product: Sierra Wireless EM9191
[95274.442367] usb 4-1: Manufacturer: Sierra Wireless, Incorporated
[95274.442375] usb 4-1: SerialNumber: 8W1164011203A121
[95274.585864] cdc_mbim 4-1:1.0: setting rx_max = 16384
[95274.588635] cdc_mbim 4-1:1.0: cdc-wdm0: USB WDM device
[95274.591245] cdc_mbim 4-1:1.0 wwan0: register 'cdc_mbim' at usb-0000:03:00.0-1, CDC MBIM, ce:d2:8a:93:a2:77
[95318.510072] usb 4-1: USB disconnect, device number 33
[95318.510179] cdc_mbim 4-1:1.0 wwan0: unregister 'cdc_mbim' usb-0000:03:00.0-1, CDC MBIM
[95319.873863] usb 4-1: new SuperSpeed USB device number 34 using xhci_hcd
[95319.900468] usb 4-1: New USB device found, idVendor=1199, idProduct=90d2, bcdDevice= 0.00
[95319.900481] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[95319.900490] usb 4-1: Product: Sierra Wireless EM9191
[95319.900498] usb 4-1: Manufacturer: Sierra Wireless, Incorporated
[95319.900506] usb 4-1: SerialNumber: 8W1164011203A121
[95319.964326] usbcore: registered new interface driver qcserial
[95319.964361] usbserial: USB Serial support registered for Qualcomm USB modem
[95319.964432] qcserial 4-1:1.0: Qualcomm USB modem converter detected
[95319.966270] usb 4-1: Qualcomm USB modem converter now attached to ttyUSB0
The rebooting/restarting of EM9191 stopped. What I did (but don’t know if it is related) placed the SIM card of 2nd ISP (however the 2nd ISP uses network infrastructure from 1st ISP as it is sister company) and it worked just fine. And at!gcdump gives: No crash data available. Afterwards I switched back to 1st SIM card and it also worked just fine.
I don’t know what may be cause of problem . It may be related to doing attach/detach too often. If anyone can confirm it or how to check this I would preform activity on my side so we can keep track of cause. Any help most welcome.
