EM9191 remains in WCDMA and does not latch to LTE
I am not sure what I did(possibly something with system selection preference, but can not recall), Now EM9191 remains in WCDMA when at!band is set to all band (0) and at!selrat=0(Automatic)
at!gstatus?
!GSTATUS:
Current Time: 636 Temperature: 41
Reset Counter: 1 Mode: ONLINE
System mode: WCDMA PS state: Not attached
WCDMA band: WCDMA 2100
WCDMA channel: 3015
GMM (PS) state:NULL —
MM (CS) state: IDLE NORMAL SERVICE
WCDMA L1 state:L1M_PCH_SLEEP LAC: a172 (41330)
RRC state: DISCONNECTED UTRAN Cell ID: 019db3f7 (27112439)
RxM RSSI C0: -78 RxD RSSI C0: —
RxM RSSI C1: — RxD RSSI C1: —
When forcing it to LTE:
at!selrat=04
at!gstatus?
!GSTATUS:
Current Time: 703 Temperature: 41
System mode: Unknown PS state: Not attached
Unknow System Mode
It was working few days before as normal. But, possibly I did something silly. And, now not able to recover it.
at!reset and complete power off/on does not help.
Any lead what has caused this issue and how to recover it?
does upgrading FW help?
does “AT!RMARESET” help?
@jyijyi
You are expert and life saver. AT!RMARESET did help. Putting the logs below for reference. Have a nice weekend…
at!entercnd=“A710”
at!RMARESET?
!RMARESET:
0 Factory
1 Provision
at!RMARESET=1
!RMARESET: DEVICE REBOOT REQUIRED
Items Restored: 1273
Items Deleted: 33
Items Defaulted: 0
Items Skipped: 5
at!reset
at!gstatus?
!GSTATUS:
Current Time: 172 Temperature: 40
LTE band: B7 LTE bw: 20 MHz
LTE Rx chan: 2850 LTE Tx chan: 20850
RRC state: RRC Idle
IMS reg state: REGISTERED IMS mode: Normal
IMS Srv State: FULL SMS,NO VoIP
PCC RxM RSSI: -81 PCC RxM RSRP: -113
PCC RxD RSSI: — PCC RxD RSRP: —
Tx Power: – TAC: 8601 (34305)
RSRQ (dB): -12.4 Cell ID: 04ccee04 (80539140)
SINR (dB): 0.8
NR5G band: — NR5G bw: —
NR5G Rx chan: — NR5G Tx chan: —
NR5G RSRP (dBm): — NR5G RSRQ (dB): —
NR5G SINR (dB): —
