EM9191 not appearing in linux usb
I just got a new EM9191 which I embedded into an M.2 board (https://www.amazon.com/EXVIST-Industrial-Applicable-Applications-Raspberry/dp/B089SPQJT6?th=1), however when I connect it into my Fedora via usb, it does not appear. It is not even listed. I installed the linux drivers but I believe that the device should be at least listed, or the /dev folder should change size. I have found some related topics, but I have not been able to solve it with those.
Let me know if you need any further information.
Thank you
see if this helps:
