Hmm… Today I’m at the different location, about 30km from the original. 4x4 MIMO seems to be working here. How can that be? Could this be related to base station that the device is connecting to? Or what? Below are the outputs you requested. Not sure if they are of any interest now that 4x4 MIMO is working at the moment.
AT!RATCA?
!RATCA:
CA: 0
ENDC: 1
SA: 1
AT!RFCID?
!RFCID:
CMW_HWID: 1007
CMW_BID : 0
MMW_HWID: 0
MMW_BID : 0
AT!RFCMBNSCAN?
1003_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:77
1004_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:76
1007_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:77
1008_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:77
1090_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:74
1091_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:76
1100_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:77
1101_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:78
1102_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:77
1103_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:77
1104_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:78
1105_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:77
1200_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:68
1201_0_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:68
1500_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:1
1501_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:1
1502_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:1
1503_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:2
1504_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:1
1505_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:3
1506_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:3
1507_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:3
1508_0.mbn: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23 rfctag: rfcver:3
2000_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:3
2050_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2051_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2100_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:4
2101_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:2
2102_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2103_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2150_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2200_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2201_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:2
2202_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2250_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2300_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2350_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2400_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2450_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2451_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
2500_0.mbn: SWIX55C_03.14.10.04 1972b0 jenkins 2024/03/01 08:05:19 rfctag:001 rfcver:1
AT!RFDEVSTATUS?
instance,manufacture id,product id,device status
0 ,0x217 ,0xfed ,PRESENT
1 ,0x217 ,0x35 ,PRESENT
2 ,0x217 ,0x1c3 ,PRESENT
3 ,0x217 ,0x412 ,PRESENT
4 ,0x217 ,0x35 ,PRESENT
5 ,0x217 ,0x1a8 ,PRESENT
6 ,0x217 ,0x418 ,PRESENT
7 ,0x217 ,0x337 ,PRESENT
8 ,0x217 ,0x1ad ,PRESENT
9 ,0x217 ,0x338 ,PRESENT
10 ,0x217 ,0x1ac ,PRESENT
11 ,0x217 ,0x338 ,PRESENT
12 ,0x217 ,0x142 ,PRESENT
13 ,0x217 ,0x417 ,PRESENT
14 ,0x217 ,0x338 ,PRESENT
15 ,0x217 ,0x26f ,PRESENT
16 ,0x217 ,0x26f ,PRESENT
17 ,0x217 ,0x26e ,PRESENT
18 ,0x217 ,0x4d0 ,PRESENT
19 ,0x217 ,0x26e ,PRESENT
20 ,0x217 ,0x4d0 ,PRESENT
21 ,0x217 ,0x253 ,PRESENT
22 ,0x217 ,0x253 ,PRESENT
23 ,0x217 ,0x263 ,PRESENT
24 ,0x217 ,0x254 ,PRESENT
25 ,0x217 ,0x254 ,PRESENT
26 ,0x217 ,0x260 ,PRESENT
27 ,0x217 ,0x255 ,PRESENT
28 ,0x217 ,0x26e ,PRESENT
29 ,0x217 ,0x4d0 ,PRESENT
30 ,0x217 ,0x253 ,PRESENT
31 ,0x217 ,0x263 ,PRESENT
32 ,0x217 ,0x254 ,PRESENT
33 ,0x217 ,0x253 ,PRESENT
34 ,0x217 ,0x254 ,PRESENT
35 ,0x134 ,0x17 ,PRESENT
36 ,0x134 ,0x14 ,PRESENT
37 ,0x134 ,0x15 ,PRESENT
at!gstatus?
!GSTATUS:
Current Time: 143 Temperature: 33
Thermal Mitigation Level: 0
Reset Counter: 1 Mode: ONLINE
System mode: ENDC PS state: Attached
LTE band: B3 LTE bw: 20 MHz
LTE Rx chan: 1825 LTE Tx chan: 19825
RRC state: RRC Connected
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
PCC Rx0 RSSI: -57 PCC Rx0 RSRP: -80
PCC Rx1 RSSI: — PCC Rx1 RSRP: —
PCC Rx2 RSSI: — PCC Rx2 RSRP: —
PCC Rx3 RSSI: — PCC Rx3 RSRP: —
PCC Tx Power: -17 TAC: 71c1 (29121)
RSRQ (dB): -3.1 Cell ID: 0018a702 (1615618)
SINR (dB): 22.6
SCC1 NR5G band: n78 SCC1 NR5G bw: 100 MHz
SCC1 NR5G Tx Power: 19 SCC1 NR5G Tx chan: 639332
SCC1 NR5G Rx chan: 639332
NR5G RSRP (dBm): -99 NR5G RSRQ (dB): -11
NR5G SINR (dB): 16.5
