Is there a way to change NSSAI SST default value with AT+C5GNSSAI or any other command?,
Model: EM9190
Revision: SWIX55C_03.09.06.00 340b2d jenkins 2022/03/16 00:37:53
Model: EM9190
No I had not tried that. Was using at+cgdcont . Are these commands in the manual?
it is in the 3GPP spec: (e.g. v15.9.0)
https://portal.3gpp.org/desktopmodules/Specifications/SpecificationDetails.aspx?specificationId=1515
And can we use the same command to change the default SD values?
I think SD is set by +CGDCONT
