EM7590 running firmware 04.00.04.00 won't download ephemeris data, no GPS sync
I have a new EM7590 that won’t get a GPS fix.
AT!IMPREF:
preferred fw version: 00.00.00.00
preferred carrier name: AUTO-SIM
preferred config name: AUTO-SIM_000.000_000
preferred subpri index: 000
current fw version: 04.00.04.00
current carrier name: VERIZON
current config name: VERIZON_004.000_000
current subpri index: 000
It sees satellites with good SNR using AT!GPSFIX=1,255,1000:
at!gpssatinfo?
Satellites in view: 9 (2026 07 28 1 17:19:23)
SV: 10 ELEV: 0.000 AZI: 0.000 SNR:31.500
SV: 15 ELEV: 0.000 AZI: 0.000 SNR:39.300
SV: 18 ELEV: 0.000 AZI: 0.000 SNR:30.400
SV: 23 ELEV: 0.000 AZI: 0.000 SNR:37.500
SV: 24 ELEV: 0.000 AZI: 0.000 SNR:34.900
SV: 29 ELEV: 0.000 AZI: 0.000 SNR:40.700
SV: 32 ELEV: 0.000 AZI: 0.000 SNR:39.200
SV:133 ELEV: 0.000 AZI: 0.000 SNR:41.000
SV:135 ELEV: 0.000 AZI: 0.000 SNR:40.100
The SNR values are very good so I don’t think it is an antenna problem.
Google told me:
Your EM7590 is running firmware 04.00.04.00, which has a known bug in its GPS/GNSS subsystem where tracking sessions crash, fail to download ephemeris, and repeatedly time out with FAILCODE = 4.
But this is the latest version of the firmware, published only last month.
The module is in an embedded PC running Linux, Ubuntu 24.04, and I have disabled ModemManager to debug this (the modem does get a good connection to Verizon with the ModemManager running).
how about using other firmware?
https://source.sierrawireless.com/resources/airprime/minicard/75xx/em7590/em7590-approved-fw-packages/#sthash.QuzdpHaC.K1Su9oj3.dpbs
I tried using the GENERIC, but it is the same version SWIX12C_04.00.04.00 as the Verizon, and it wouldn’t connect to the cell network (got provider mismatch).
The original version was 02 but it also wouldn’t get a GPS fix, so I downloaded the 04.00 Linux binaries and updated the firmware.
at!image?
FW 1 GOOD 1 0 0 ?? 02.02.03.00?
FW 2 GOOD 2 0 0 ?? 03.01.02.00?
FW 3 GOOD 3 0 0 ?? 04.00.04.00?
Max FW images: 3
Active FW image is at slot 3
PRI FF GOOD 0 0 0 002.000_002 02.02.03.00_GENERIC
PRI FF GOOD 0 0 0 002.001_002 02.02.03.00_ATT
PRI FF GOOD 0 0 0 002.000_002 02.02.03.00_TMO
PRI FF GOOD 0 0 0 004.000_000 04.00.04.00_VERIZON
Max PRI images: 25
ati
Manufacturer: Sierra Wireless
Model: EM7590
Revision: SWIX12C_04.00.04.00 2026/05/05 15:32:04
SVN: 10
IMEI: 357999720307729
FSN: DX4516038101H1
TS.25: 2026.1.12
+GCAP: +CGSM
How about the version 03?
You can try other PRI version as gps fix is not related to any network
It seems that the problem is caused by the M.2 to mini-PCIe adapter holding the modem. It has a SIM holder and a USB 3.0 interface for the SIM that we believe was causing RF and/or power noise that interfered with the GPS signals. Still working on a solution.
