Please I would like to know how I can make my EM7565 module card to work on my dell Latitude 7280 windows 11 64bit.It was working when I had windows 10 64bit installed. I had to upgrade to windows 11.
I have installed the latest firmware and driver installed but still not working.
I was able to do it and it’s working now. I used build 4836, but I can not get band 7 to work on the EM7565 so what do you think I should do? Or I can give you TeamViewer access to assist me with it. The band 7 here is an LTE service only and does not support 3G or 2G fallback.
On the source page, only the latest firmware is available. If you need any older firmware, please indicate the firmware name.
I will search locally on my computer and give it to you.
Sure, I want the last two firmwares that was released before this latest one on the website.
Also on windows 11 the modem is working fine and perfect. After RESTART, I do not have to ON airplane mode and OFF again before the modem starts working. Its start working right after RESTART when Wifi is OFF.
