EM7565 Low Power Mode RFCAL:1
Model: EM7565
Revision: SWI9X50C_01.07.02.00 6c91bc jenkins 2018/06/13 23:08:16
IMEI: 001027009999999
IMEI SV:  7
FSN: UF841188380310
+GCAP: +CGSM
State: Low Power Mode
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0, RFCAL:1
LPM persistence - None
Hello
Doesn’t know about this LPM: RFCAL.
What is that and how to fix that?)
Thanks!
Where did you get this module?
seems this is calibration problem of your module
have you updated to latest FW and see if it can be fixed?
Just recieve from my friend
I have update this EM7565 to the lastest FW, this LPM is still here
How to make this calibration?
I have programs like QXDM, QRST, a bit work with them.
Can you help me to fix my module?
where did your friend get this module?
It is not a production module from the IMEI
Normally the calibration is done in factory…
This value of IMEI shows when module fw is a bit broken
not quite sure what that means…
but the calibration should be done in factory…
Is there a way that i can copy calibration settings from another modem?
No, you cannot do that, calibration can only be done in factory
AT!OPENMEP="63C5DCB4D2385148"
at!CALINFO?
ERROR
AT!CALINFO="SWI9X50C_00.03.03.00 8e4663 jenkins 2017/05/25 23:16:24"
AT!CALINFO?
AT!PCINFO?
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0, RFCAL:1, ATNV_CRIT:0
at!reset
ati
Model: EM7565
Revision: SWI9X50C_01.14.13.00 883709 jenkins 2022/01/05 07:08:35
IMEI SV: 14
FSN: UF841188380310
+GCAP: +CGSM
AT!PCINFO?
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0, RFCAL:0
Module works fine with bad signal
