We are using a EM7565 on an embedded Linux System, running on an i.mx8. We have issues with the USB ports recognizing.
Most of the time three USB-interfaces are recognized.
But sometimes only one interface is recognized.
In that case it is not possible to use AT-commands to communicate with the module.
Do you know this error? Can you point me into a direction where to find a solution of the problem
When only one port works /sys/kernel/debug/usb/devices gives:
T: Bus=02 Lev=02 Prnt=02 Port=02 Cnt=01 Dev#= 3 Spd=5000 MxCh= 0
D: Ver= 3.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 9 #Cfgs= 1
P: Vendor=1199 ProdID=9090 Rev= 0.00
S: Manufacturer=Sierra Wireless, Incorporated
S: Product=Sierra Wireless EM7565 Qualcomm Snapdragon X16 LTE-A
S: SerialNumber=UF94119009041546
C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr= 8mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=qcserial
E: Ad=81(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
lsusb -d 1199:9090 -v
Bus 002 Device 003: ID 1199:9090 Sierra Wireless, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x1199 Sierra Wireless, Inc.
idProduct 0x9090
bcdDevice 0.00
iManufacturer 1 Sierra Wireless, Incorporated
iProduct 2 Sierra Wireless EM7565 Qualcomm?? Snapdragon??? X16 LTE-A
iSerial 3 UF94119009041546
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 44
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 8mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 3
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 3
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 22
bNumDeviceCaps 2
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 10 micro seconds
bU2DevExitLat 2047 micro seconds
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000002
HIRD Link Power Management (LPM) Supported
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0000
(Bus Powered)
dmesg | grep -i usb | grep 2-1
[ 4.416469] usb 2-1: new SuperSpeed USB device number 2 using cdns-usb3
[ 4.448984] hub 2-1:1.0: USB hub found
[ 4.806657] usb 2-1.3: new SuperSpeed USB device number 3 using cdns-usb3
[ 4.837705] qcserial 2-1.3:1.0: Qualcomm USB modem converter detected
[ 4.844516] usb 2-1.3: Qualcomm USB modem converter now attached to ttyUSB0
When all ports work it looks like this:
/sys/kernel/debug/usb/devices:
D: Ver= 3.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 9 #Cfgs= 1
P: Vendor=1199 ProdID=9091 Rev= 0.06
C:* #Ifs= 4 Cfg#= 1 Atr=a0 MxPwr=896mA
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=qcserial
E: Ad=83(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=82(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=qcserial
E: Ad=85(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=84(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
I:* If#= 8 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=86(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
E: Ad=8e(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=0f(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
[ 4.433822] usb 2-1: new SuperSpeed USB device number 2 using cdns-usb3
[ 4.486647] hub 2-1:1.0: USB hub found
[ 8.727947] usb 2-1.3: new SuperSpeed USB device number 3 using cdns-usb3
[ 8.752775] usb 2-1.3: config 1 has an invalid interface number: 8 but max is 3
[ 8.760175] usb 2-1.3: config 1 has no interface number 1
[ 8.797834] qcserial 2-1.3:1.0: Qualcomm USB modem converter detected
[ 8.804735] usb 2-1.3: Qualcomm USB modem converter now attached to ttyUSB0
[ 8.814004] qcserial 2-1.3:1.2: Qualcomm USB modem converter detected
[ 8.820806] usb 2-1.3: Qualcomm USB modem converter now attached to ttyUSB1
[ 8.828448] qcserial 2-1.3:1.3: Qualcomm USB modem converter detected
[ 8.835127] usb 2-1.3: Qualcomm USB modem converter now attached to ttyUSB2
lsusb -d 1199:9091 -v
Bus 002 Device 003: ID 1199:9091 Sierra Wireless, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
idProduct 0x9091
bcdDevice 0.06
iProduct 2 Sierra Wireless EM7565 Qualcomm? Snapdragon? X16 LTE-A
bLength 9
bDescriptorType 2
wTotalLength 226
bNumInterfaces 4
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 896mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 3
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
** UNRECOGNIZED: 05 24 00 10 01
** UNRECOGNIZED: 05 24 01 00 00
** UNRECOGNIZED: 04 24 02 02
** UNRECOGNIZED: 05 24 06 00 00
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x000a 1x 10 bytes
bInterval 9
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 3
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 9
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 8
bAlternateSetting 0
bNumEndpoints 3
iInterface 7 rmnet-qmap-0
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 9
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x8e EP 14 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 2
bLength 7
bDescriptorType 5
bEndpointAddress 0x0f EP 15 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 2
bLength 5
bDescriptorType 15
wTotalLength 22
bNumDeviceCaps 2
bLength 7
bDescriptorType 16
bmAttributes 0x00000000
(Missing must-be-set LPM bit!)
bLength 10
bDescriptorType 16
bmAttributes 0x00
wSpeedsSupported 0x000f
Device can operate at Low Speed (1Mbps)
bU1DevExitLat 1 micro seconds
bU2DevExitLat 500 micro seconds
(Bus Powered)
