I am trying the EM7565 development kit on windows 10. I have ATT SIMS activated through Sierra. I am getting an error when I try to connect, “Can’t connect to this network” “Cellular data isn’t working properly. Try again later.”
I am powering my device off of a powered USB switch and I have both of the provided antennas connected along with the short cables to connect the radio ports to the devkit board’s ports.
It turned out I needed an APN. Now that I have that, I can connect but I can’t get a DNS server. I also can’t ping the gateway.
To send AT commands, I assume I connect to the DM Port above (happens to be COM12 on my system). Is it 9600 8n1 with no hardware flow control? I tried that with PuTTY with no luck.
AT!IMPREF?
!IMPREF:
preferred fw version: 01.14.02.00
preferred carrier name: ATT
preferred config name: ATT_002.047_000
preferred subpri index: 001
current fw version: 01.14.02.00
current carrier name: ATT
current config name: ATT_002.047_000
current subpri index: 001
I’m trying to establish data connection with my EM7565 on window 10 but having similar issue as well. I don’t have the GSM antenna installed yet but the AT!SCACT =1,1 return error. It seemed like the data network cant be turned on in window.
AT+CPIN?
+CPIN: READY
AT!IMPREF?
!IMPREF:
preferred fw version: 01.08.04.00
preferred config name: GENERIC_002.011_000
current fw version: 01.08.04.00
current carrier name: GENERIC
current config name: GENERIC_002.011_000
AT!GSTATUS?
!GSTATUS:
Current Time: 1847 Temperature: 30
Reset Counter: 1 Mode: ONLINE
System mode: LTE PS state: Not attached
LTE band: No band LTE bw: 1.4 MHz
LTE Rx chan: 0 LTE Tx chan: 18000
LTE SSC1 state:NOT ASSIGNED
LTE SSC2 state:NOT ASSIGNED
LTE SSC3 state:NOT ASSIGNED
LTE SSC4 state:NOT ASSIGNED
EMM state: Deregistered No Cell
RRC state: RRC Idle
IMS reg state: No Srv
