I want to confirm that my EM7565 module has B48 capability. The wireshark trace when I latch on to a cell at e.g. band 3, does not show B48 in the UE capability list. I am unable to latch on to a B48 cell. How can I confirm that I have the correct HW / Fiirmware for B48 operation?
Please check by at!band?
I have a test AP radiating in B48 and the module does not see it in at+cops=? scan. It sees operator networks.
at!band?
Index, Name
00, All bands
at!band=?
Index, Name
00, All bands
01, Europe 3G
02, North America 3G
06, Europe
07, North America
08, WCDMA ALL
09, LTE ALL
ati
Model: EM7565
Revision: SWI9X50C_01.07.02.00 6c91bc jenkins 2018/06/13 23:08:16
IMEI: 359260080179911
IMEI SV:  7
FSN: UF823389550210
+GCAP: +CGSM,+DS,+ES
then that means it can work on B48.
testing on my side:
ati3
Model: EM7565
Revision: SWI9X50C_01.11.00.00 5ba42f jenkins 2019/06/28 09:51:52
IMEI: 353533100134710
IMEI SV: 10
FSN: UF913580100215
+GCAP: +CGSM
at!entercnd=“A710”
at!band?
Index, Name,                        GW Band Mask     L Band Mask 1    TDS Band Mask    L Band Mask 2    L Band Mask 3    L Band Mask 4
00, All bands                     100600000EC00000 0000A700BA0E19DF 0000000000000000 0000000000000002 0000000000000000 0000000000000000
at!band=?
Index, Name,                        GW Band Mask     L Band Mask 1    L Band Mask 2    TDS Band Mask    L Band Mask 3    L Band Mask 4
00, All bands                     100600000EC00000 0000A700BA0E19DF 0000000000000002 0000000000000000 0000000000000000 0000000000000000
01, Europe 3G                     0002000000400000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
02, North America 3G              0000000004800000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
06, Europe                        0002000000400000 00000000000801C5 0000000000000000 0000000000000000 0000000000000000 0000000000000000
07, North America                 0000000004800000 000001000200185A 0000000000000002 0000000000000000 0000000000000000 0000000000000000
08, WCDMA ALL                     100600000EC00000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
09, LTE ALL                       0000000000000000 0000A700BA0E19DF 0000000000000002 0000000000000000 0000000000000000 0000000000000000
        0000000000000002 - B66
                                               0000800000000000 - B48
                                               0000200000000000 - B46
                                               0000040000000000 - B43
                                               0000020000000000 - B42
                                               0000010000000000 - B41
                                               0000000080000000 - B32
                                               0000000020000000 - B30
                                               0000000010000000 - B29
                                               0000000008000000 - B28
                                               0000000002000000 - B26
                                               0000000000080000 - B20
                                               0000000000040000 - B19
                                               0000000000020000 - B18
                                               0000000000001000 - B13
                                               0000000000000800 - B12
                                               0000000000000100 - B9
                                               0000000000000080 - B8
                                               0000000000000040 - B7
                                               0000000000000010 - B5
                                               0000000000000008 - B4
                                               0000000000000004 - B3
                                               0000000000000002 - B2
                                               0000000000000001 - B1
                              1000000000000000 - B19 (850)
                              0004000000000000 - B9 (1700)
                              0002000000000000 - B8  (900)
                              0000000008000000 - B6  (800)
                              0000000004000000 - B5  (850)
                              0000000002000000 - B4 (1700)
                              0000000000800000 - B2 (1900)
                              0000000000400000 - B1 (2100)
Thanks, I entered the commands and do not see B48:
ati3
Model: EM7565
IMEI SV:  7
FSN: UF823389550210
at!band?
00, All bands                     100600000EC00000 00002100BA0E19DF 0000000000000000 0000000000000002 0000000000000000 0000000000000000
at!band=?
00, All bands                     100600000EC00000 00002100BA0E19DF 0000000000000002 0000000000000000 0000000000000000 0000000000000000
09, LTE ALL                       0000000000000000 00002100BA0E19DF 0000000000000002 0000000000000000 0000000000000000 0000000000000000
                              0000000000400000 - B1 (2100)So the PTS states B48 is supported so it will be. You need to make sure that you have a ‘recent’ unit (so less than 12 months old) to make sure it is enabled by default. As it is part of CBRS and when the device was launched FCC had not formalised the bands we had to completely disable it in the flash and you need a one click updater to enable them.
Once enabled then the unit should just see it as a.n.other network.
If you need this then please go to your support channel (distributor/FAE).
You can try my Fw…
Hi Colin,
I’m assuming you’ve likely solved this by now, but as I’m just going through the same issue I thought I’d post here as well to try and help others.
I have just purchased an EM7565 from digikey (Sep '20), and have seen exactly the same issue as you describe (no band 42/43/48, and the same firmware version in the supplied unit (01.07.02.00).
Updating to latest firmware (01.11.00.00) per jyijyi’s suggestion does not help; those bands still remain disabled.
While these could be old/early units which had CBRS disabled, Digikey have quite a number, so it is unclear whether the disabled version has been continued as a part for production reasons perhaps. In any case, I note that there are two EM7565 parts available from Digikey, with manufacturer part numbers EM7565_1103520 and EM7565_1104207. From elsewhere on the forum, I found a separate query relating to these, suggesting that the former is non-CBRS, and the latter is CBRS; I’ve not been able to confirm this, but since the part I ordered was the former, this might be correct.
I have contacted Digikey to ask for the “one click update tool” to enable CBRS - I just hope they know what I am asking for and have it available. Ordering the latter part may be the necessary alternative, though it would be good to know this without having to make speculative purchase.
Following up, I can confirm that the enable-CBRS software does enable the bands on the EM7565_1103520 device I had purchased. End-to-end testing not yet performed, but the bands now appear in the AT!BAND=? listing, so I believe all is good.
