EM7455 - disable modem or device provisioned APN on Windows 10 and Vodafone SIM
Is it possible to disable modem/device auto provisioned APN on EM7455 modems (Running Windows 10). Have tried firmware WI9X30C_02.38.00.00 and SWI9X30C_02.24.03.00. Need to restrict access to a Private Vodafone APN and the auto provisioned APN connects to Vodafone’s Public APN.
didn’t you can change the APN here?
Also have you changed the APN by AT+CGDCONT=1,“IP”,“xxx” command?
BTW, have you tried in VMware Linux to make sure it works on the private APN?
Thank you for your reply. The problem is not creating a user generated APN but to stop the modem/device automatically creating a default APN in windows 10.
are you using MBIM or RMNET mode?
you can check by:
AT!ENTERCND="A710"
AT!USBCOMP?
Hello
Did you find a solution for this?
Resolved. Used this article … Windows 10 Enterprise APN lost after SIM change or MBN adapter error - Windows Client | Microsoft Learn
that was fast! Thank you very much :slight_smile:
