CAH1982
1
So I bought a adapter off ebay and installed it, this shows in device manager as per the below
Why is there the bottom 3? and how do i resolve it.
I keep seeing things about send AT commands and i know how to use putty, but theres nothing to say what com port its on
Also how can you tell if it is carrier locked e.g. Vodafone / EE?
thanks
jyijyi
2
Did you download and install the usb driver from source.sierrawireless.com ?
CAH1982
3
Yes, I installed them, but it still doesnt pick up the bottom 3
I tried firmware update but get the bellow
but im using a dell tablet?
Installed lenovo drivers and get the bellow but them 3 say code 10 failed to start
jyijyi
4
which driver did you install in source.sierrawireless.com?
CAH1982
5
just the generic one
ive installed the lenovo one and the modem and netowrk now show as working
but if i try and connect to the modem come port it opens but i cant type any thing in the command box
seen something where it says boot to ubuntu to run some codes, but as its a taplet i have no keyboard to type them in terminal
jyijyi
6
You can use usb keyboard
CAH1982
7
Yeah i found the onscreen one,
but its still same, tried drivers from that page both lenovo and dell, both say not intended for this PC even though its a Dell
tried to extract them and manually put them on and get “code 10” device cannot start
jyijyi
8
How about the driver in source.sierrawireless.com?
CAH1982
9
Finally done it
So first off from the below, make a bootable Ubuntu USB
Then open terminal and run sudo minicom -s
Change the serial settting to /dev/ttyUSBX2
save changes to default and exit
Now type these, the text wont appear on screen but jsut pres enter after each and it should return OK
AT!ENTERCND=“A710”
AT!USBPID=9071,9070
AT!USBVID=1199
AT!USBPRODUCT=“EM7455”
AT!PRIID=“9904802”,“001.001”,“Generic-Laptop”
AT!RESET
then reboot to windows and install generic drivers and firmware
