I have an EM7411 with a Verizon SIM. The generic firmware that comes with the device (after doing at!rmareset) registers on the network successfully:
at!impref?
!IMPREF:
preferred fw version: 01.14.03.00
preferred config name: GENERIC_002.036_000
preferred subpri index: 000
current fw version: 01.14.03.00
current carrier name: GENERIC
current config name: GENERIC_002.036_000
current subpri index: 000
at!gstatus?
!GSTATUS:
Current Time: 78 Temperature: 33
Reset Counter: 22 Mode: ONLINE
LTE band: B13 LTE bw: 10 MHz
LTE Rx chan: 5230 LTE Tx chan: 23230
LTE SCC1 state:INACTIVE LTE SCC1 band: B4
LTE SCC1 bw : 20 MHz LTE SCC1 chan: 2300
LTE SCC2 state:NOT ASSIGNED
LTE SCC3 state:NOT ASSIGNED
LTE SCC4 state:NOT ASSIGNED
RRC state: RRC Connected
IMS reg state: No Srv
PCC RxM RSSI: -65 PCC RxM RSRP: -97
PCC RxD RSSI: -65 PCC RxD RSRP: -96
SCC1 RxM RSSI: -87 SCC1 RxM RSRP: -118
SCC1 RxD RSSI: -84 SCC1 RxD RSRP: -108
Tx Power: -- TAC: d802 (55298)
RSRQ (dB): -17.3 Cell ID: 034c3902 (55326978)
SINR (dB): -6.6
However, after downloading the Verizon firmware into the device, the registration no longer succeeds. The device will continue to register and deregister in infinite loops and never complete any registration:
at!impref?
!IMPREF:
preferred fw version: 01.14.07.00
preferred carrier name: VERIZON
preferred config name: VERIZON_002.045_005
current fw version: 01.14.07.00
current carrier name: VERIZON
current config name: VERIZON_002.045_005
at!gstatus?
!GSTATUS:
Current Time: 55 Temperature: 36
Reset Counter: 27 Mode: ONLINE
System mode: LTE PS state: Not attached
LTE band: No band LTE bw: 1.4 MHz
LTE Rx chan: 0 LTE Tx chan: 4294967295
LTE SCC1 state:NOT ASSIGNED
EMM state: Deregistered Attach Needed
RRC state: RRC Releasing
IMS reg state: No Srv IMS mode: Normal
PCC RxM RSSI: 0 PCC RxM RSRP: 0
PCC RxD RSSI: 0 PCC RxD RSRP: 0
Tx Power: -- TAC: ffff (65535)
RSRQ (dB): 0.0 Cell ID: ffffffff (4294967295)
SINR (dB): 0
Why would the Verizon firmware not connect to the Verizon network? Is it safe to continue with the GENERIC firmware?
